oh-thats nice--good looking car
Far too much to list
Nice looking car. So it has the m52 in it? I know mustang dynos read low, but I thought it was only by about 10-15% as compared to the dynojets... what are the numbers if they were converted (approx.) to that of what a dynojet would read? I KNOW that 149 rwhp is WAY low for a m52, which is why I'm asking for clarification . I like the car though, and the idea of putting the badge back on... I just took the 325i badge off mine, which makes me smile because it has a single exhaust like yours does .
well i personally don't know! there was a local guy that did a mustang dyno and he got a 138whp and he then went on a dyno jet and made just about 170whp which is almosttly stock but with a intake. so with i would probably say close to 190whp but correct me if im wrong... yeah people get confused when they lose to a 318!!! hahah
95 318is - m52 powered, 97 328is - M-package, 01 540iT/6speed
i got 282 hp out of 328i convertible my mods are: vf supercharger kit 5 to 6 psi puley, m50 intake manifold, supersprint stainles steel header, bilsten performance full suspension kit front and rear, handles realy good at 170 mph thats when i taped out, m3 front beaks swap, 4lbs lighten flywheel, oil i use is royal purple full syntetic 10w30, lsd 3.15 gear ratio, no a/c unit and no ac belt,..its my every day car i drive to work, it has 236k miles on it, im realy happy with it, it kils 07 sti subaru thing on the freeway, also kils shelby mustan 07. my goal is to reach 430+hp by the end of this year. i have standalon engine manegmant system redy to go for custom tooning, cost me 4000$, instad of inter cooler im gona go with methenal straight injection system, and a custom straight out piping exhaust.
do you have an aftercooler-- how much boost are you producing?
ill be puting 11psi pounds of bost, but my machanic thinks its to mutch he realy wanst to go with 10, to be safe, so i had to show him that red 328 that can put out 636hp and still be safe, and my machanic said that, its realy impresive, becouse last time he was tooning m3 and as soon as he went over 500hp at 515hp he bented conecting rods on the dyno, i told him that 328's conecting rods are shorter there for stronger than m3, he looked in to that and said ok. my vortech supercharger can take up to 15 psi, but if you want more than that lets say 50psi. you have to send it back to vortech for them to re do the gears inside.
but right now as i have no after cooler and. im producing 6 psi
Year: 1992
Build Date: 1992
Mods: Engine M50B25 converted to M50B28 with M52b28 crankshaft, pistons, rods, 200 ccm fuel injectors, performance cams from catcams.be(275 intake, 269 exhaust), stronger valve springs and retainers from catcams.be also, ported head, compression ratio 11.4, Pulleys from RUFF, Green filter in standard position, Supersprint(manifold, front and rear exhausts)
Dyno Type: dont know
Dyno Conditions: 60 F
Gear Dynoed: fifth
Peak HP: 248 HP
Peak Torque: 278 NM
sorry guys I am from Europe dont know your USA measuring system
my tuned BMW
Lithuanian Blog
Free UK dating
Dating advice and jokes
BMW E36 320 with M50B25 engine and conversion to 2.8 L with bigger injectors, performance cams, retainers and springs from catcams.be, pulleys, full Supersprint exhaust, all brakes from E46 330. 3.45 LSD. M3 lookalike from outside and inside. 260 HP and 278 NM. VEMS powered.
Very nice numbers
Year: 1998 328is (Jammed Vanos)
Build Date: 07/98
Mods: M50 Manifold, Cold Air Intake, Fan Delete, ASC Delete, Remus Exhaust
Dyno Type: DynoJET
Dyno Conditions: Nov 2nd (Around 10 C)
Gear Dynoed: 4th
Peak HP: 198.3 whp
Peak Torque: 190.3
Nice
1994 325is- M52 swap, Fan delete, AA chip, CAI, TC-Kline DA, H&R 28mm front sway, Kevin Higgins exhaust, kosei k1 17x8.5's with RA1's, DS2's with REO1R's, 3.23 lsd
Just thought I'd add mine up here too.
its the m3 non intercooled kit and i have no other supporting mods
Does anyone have any m50tu 2.5 dynoed
Year: 1993 318is
Build Date: dunno
Mods: S52 8.9:1 CR TRM stage 2 Turbo kit
Dyno Type: Dynojet
Dyno Conditions: +74f
Gear Dynoed: 4th gear
Peak HP: 521 rwhp
Peak Torque: 402.66 rwtq
Comments: 18psi 93oct. on street tires
BMW-PC F80 M3 HotLap │ Formula 1000 Video │ 3 Time NASA-SE GTS2 Champ │ TRM Stg.2, Coilovers & Tuning │ Racing Videos[/CENTER]
Year: 1999 BMW M3 Supercharged
Build Date: 2/99
Mods: AA Supercharger, Bigger injectors, front mount and F1 Racing Flywheel
Dyno Type: DynoJet
Dyno Conditions: 79.35°F
Humidity: 42%
Gear Dynoed: 3rd
Peak HP: 321.46
Peak Torque: 267.12
Last edited by TopEndM3; 02-11-2009 at 08:48 PM. Reason: forgot to put what type of car
I have a 1996 328i. Mods are listed in my sig. I haven't made to a dynojet yet but hope to go to one in the next couple of months. What do you think my estimate whp and wtq? I will update when I finally make it to the dyno.
-'95 E34 540i/6sp (daily driver)
K&N CAI, Dinan Chip, Short Thow Shifter, Eisemann exhaust, Mostly Stock
-'92 B13 Sentra SE-R/5sp (project car)
SR20DET swap and more
-'96 E36 328i/5Sp (Sold)
OBDI Converted 2.8, TRM Chip, S52 Cams, M50 Manifold, M3 3.23 LSD, M3 rear sway bar, Gripforce clutch/ 16lb flywheel, Ark cat-back exhaust, Modified stock air-box w/ K&N filter,Bavauto CDV, Samco intake boot, R1 concept slot/drilled rotors, PBR/Axis UTL pads, Fan Delete Mod, UUC underdrive pulleys, Depo headlights w/ 6000k hids, Depo fog lights w/ 8000k hids, clear corners, Bavauto caliper bushing upgrade, UUC RTAB, Bimmeworld Subframe Mounts, AKG Diff. Mounts, UUC tranny mounts, Custom Interior, FK Coilovers, New Front suspension, SS replica headers, SS resonators, oem rear M bumper,Rebuilt Vanos, Home Depot Lip more to come...
Future mods: Ported throttle body, Custom Tune.328 Mafia #13
-'05 Dodge NSrt-4 (dead)
Too many mods to list.
ok so my car is a 98 328i when i got the car the guy told me that it had m3 cams and a shark tune. now i am begining to think that the tune was a lie or he took it out. if you look at it it looks my my vvt is kicking in to soon since the car seems to like above 4 grand
mods are obd1 intake m3 cams and 5 speed swap, stock clutch and flywheel 3.91 lsd and a shark tune,, i think..... its up in the air, it had a 6500 rev limiter which i thought shark got rid of that. i have stock exhaust, underdrive pullies,
is this hp right? seam really low but i could be wrong. and imput of the afr and drop offs would be great.
Last edited by mustangturbo50; 02-28-2009 at 04:25 PM. Reason: Automerged Doublepost
Year: 1997 328i
Build Date: 5/97
Mods: Dinan SW II, JC intake, AA exhaust, 3.23 LSD
Dyno Type: dynomite dyno
Dyno Conditions: 2007-05-05
Gear Dynoed: ?
Peak HP: 177.8
Peak Torque: 191.8
1997 328i Avus Blue | AA gen3 exhaust | Prolumen 5000K | JC CAI | Dinan Stage 2 SW | Bilstein/H&R Sports | 3.23 LSD
