Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: How to restore black trim moldings?
  1. #26
    Aug 2011
    Vancouver, BC, Canada
    99 M3 Vert
    Did you use the spray stuff?
  2. #27
    Oct 2003
    New Zealand
    1996 E36 M3 Evo
    I used spray cans, yes.
    Took all the moldings off, cleaned them with a mild degreaser, dried them thoroughly and then sprayed them all. I gave it heaps of coats (maybe 6) to be sure they held up to abuse. In hindsight that probably wasn't necessary, 3 or 4 coats would be fine. IIRC I used two cans for the side (not window) moldings.
    The good thing with dip is it's easy to remove if you need to and the texture of the base material is preserved so they look like OE.
    '96 M3, S50B32, 6MT
    + good stuff
  3. #28
    Nov 2017
    Adairsville GA
    1994 BMW 325is
    I put M3 Moldings on mine, but left the rear bumper strip which was faded. I used Ultimate Black on it. Every time I use it the color stays black longer. Those products aren't something that makes them stay black with one application. Repeated applications get good results.
  4. #29
    Oct 2012
    Detroit, MI
    E36, E70, i3
    My trim is falling off so I'm just replacing with OE. Bit of a money pinch since we just bought a house, so only replacing what is falling off right now. Will finish up the rest when I can.
  5. #30
    Nov 2017
    Adairsville GA
    1994 BMW 325is
    You can get a full set of OEM M3 side trim for $180 which includes the clips and grommets pre-installed.
  6. #31
    Wisconsin
    98 328IS 03 325xi
    I usually use Forever Black, but I haven't done it in a few years
    Gave away my BMWs, driving a VW and an Audi now.
  7. #32
    SanDiego,Dallas,Miami,Orl
    Too Many
    Trim black spray paint. Available at most automotive paint supply stores
