Vik, if that size fits then I'd recommend one of the following, all for 15" wheels. You may need to change your rear and front calipers to fit 15" wheels. Just do it, don't even think twice about it.
Mickey Thompson ET Street Radial part number 3752R -> 235/60 R15
+ Sidewall width: 9.5"
+ Tread width: 8.0"
+ Height: 26"
Mickey Thompson ET Street part number 3752 -> 26"x10.50"-15
+ Sidewall width: 10.5"
+ Tread width: 8.3"
+ Height: 26.1"
Mickey Thompson ET Drag part number 3052 -> 26"x8.5"-15
+ Sidewall width: 9.9"
+ Tread width: 8.1"
+ Height: 25.9"
The ET Drag would give you the best short times, followed by ET Street and lastly ET Street Radial.
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
PEI (Sorry I've forgotten your name)
Can you please confirm you have fitted the following with modifications to the OEM calipers and fenders:
E46 coupe on 16" rim:
Mickey Thompson ET Street part number 3792 -> 26x10.50-16
+ Sidewall width: 10.3"
+ Tread width: 8.4"
+ Height: 25.9"
Kenny,
Part # is correct.
Wheels are Centerlines with a custom offset,and a GM 5 by 4.75" bolt pattern which is very close to 5 by 120mm.
My fenders have been rolled a lot, and the fender liners removed. This was done to fit my road racing wheels; there seems to be more clearance with the forementioned slicks. (E46 Non-M coupes have smaller rear fender wells than E46 M3s. (Non-M coupes have a limit of 265mm tires, where M3s are able to fit 285s) Pictures below show the car launching with MTs:
My best 60 ft times were in the 1.7s with 230rwhp, so the tire definitely works.
Going with smaller rear brakes to run 15" wheels is a great idea, especially with the power that you guys are making. I think Vik is looking to be in the 8XX area to start... (Correct me if I'm wrong Vik)
Regards,
Adam
This space for rent.
Will the 8" width's be sufficient enough? I wonder what 15" wheel i can get to fit these. The offset must be right or it would be hard to fit the tire on the car. I will look into the 15'' inch setup but i might settle with a 17'' setup for the time being. Actually im going to LACR on the 13th but all i have for now is the BFG's in 18's again.
What would be my option for 17''s?
There goes my drivetrain....
Chris from HPF runs 11.666 @ 129 MPH with 610 rwhp
No i don´t thing they fit under stock fenders.
We often use ET street 10.5x26" on E36
9.42@155mph
On that basis George's pass stays under widebody class.
Obviosly I've fitted them (pics). I haven't gotten a chance to race on them because of motor issues. But I weighed down the car (couple of people sitting in the truck proly 350lbs) to see if it would rub and it doesn't, comes close to the little lip on the inside of the body work but has some room.
I did let someone use the wheels on thier M3 at the boosted bimmers unite meet. His car was pretty low and they had to be cambered. Still did not rub much on his.
///Andres
11 X5d sport - daily tow rig
09 335d - evolve tuned 327whp / 490wtq
97 M3 - NASA TTB
95 M3 Turbo - 3.0l s52, PTE74GTQ, AEM EMS & CDI, etc
TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
i asked before, but my post was erased?
where do you get those 16 inch contour rims? i need two
Negative camber + drag racing = no good!
Andrew Ho
GT47-88 Supra MSB 6 Speed (SOLD)
2001 BMW M3 (SOLD)
2004 Acura RSX (SOLD)
Click on the link in my sig for the info for best fitment for drag racing (OEM bodywork and best known):
I wonder if MT ET Drag 26"x8.5"-15 would fit under stock bodywork?With 15" rim:
+ Tread width 8.0" (Can fit on rims 7"-9")
+ 26.0" tall and 82" circumference (VERY tight fit in wheel well)
+ Credit: Alan (morerevsm3)
