Page 7 of 9 FirstFirst 123456789 LastLast
Results 151 to 175 of 204
Thread: OBC pixel and button fix DIY...
  1. #151
    Apr 2009
    Quebec City, Canada
    98 M3, 96 Stratus
    Hi guys, I'm doing the trick and I'm wondering how high I can put the rubber strip ?
    This stupid board does not allows me yet to put on pictures
  2. #152
    Oct 2002
    Chicagoland
    '00 528iA, '01 325iA
    Quote Originally Posted by Walkman View Post
    I'd say 2, maybe 2.5 mm max.
  3. #153
    Mar 2005
    San jose,ca
    98 328is,99 m3,gs430
    I followed all the steps, now the background lights of the obc don't come on! bulbs and the connections are fine.any ideas?
  4. #154
    Sep 2009
    Germantown, Maryland
    1991 BMW 850I
    I tried the procedure last week, Once I installed it, I had 85% of the pixels the next day it dropped to about 60%. the 3M tape eventually compresses and much of the added force on the connector is lost. Has anybody tried installing a new ribbon? what glue do they use, does it provide better results?
    Thanks for the write up! It was easy to follow.
  5. #155
    Aug 2002
    San Jose, CA
    E36/E46 M3 - E46 323ci
    I've read through this several times and I'm having a difficult time figuring out where exactly are you supposed to put the tape. Is this something that will become more apparent once I open up the OBC?
  6. #156
    SD
    330Ci
    Quote Originally Posted by JetBlackE46 View Post
    Yes. You will see exactly what's all going on once you have it apart in front of you. I was quite confused also untill I commited and completely pulled mine apart. Easy just delicate.
    05 BMW X5 - 09 Yamaha R6 - 04 Ski-Doo mxzX 440 lc race sled - 04 Ford F350 SCrew PSD
  7. #157
    Dec 2009
    Hopewell, NY
    E36 323IC
    Quote Originally Posted by thefarmyard View Post
    Hello again. Sorry about the crazy post. I was tired myself and it made perfect sense at the time. I'll try again without the kook.
    I have a 1997 E36. The digital odometer appears to be LED's as opposed to an LCD. When I start the car, the bottem half of the characters do not display properly. After some time driving, they do display correctly.
    Is this a bulb issue or are the LED panels known for failure?
    'Smiling odometers'... My OBC's LCD panel appeared to be smiling after your fix. Well I was anyway. Just wondering what advice you have for the odometer. Are there bulbs specically for the odometer/service indicator panel, or is it in fact an LED display panel?
    Thanks very much...
    there are 2 bulbs in the odometer, have replaced tham recently... those are the small 1.5 watt bulbs with the brown like pastic bottom...
    you can find tam on bavauto.com
    i bought tham from http://www.pelicanparts.com/bmw/cata...ELlite_pg7.htm
  8. #158
    kahunagirl Guest
    Hi Ivopivo Kakosi?
    if i were to remove the orange strip or tab and replace it with say blue lights would my obc display be blue?
    if so i will attempt it, but only if you say it can be done
    Kahunagirl
  9. #159
    Socal
    2005 E46 M3
    I did this diy today, and wanted to comment that this was a very good write up, pics helped a lot.
    I put about 5 layers of tape (i didn't use 3m double sided tape, just some beige/clear opaque tape we had lying around), and one column of pixels still don't come out the bright orange like it should, but i figure another layer or two of tape would fix that problem, but after taking out the obc twice, the edges of my fingers hurt from pulling apart the obc, so i'll live with what i have. But it fixed all the other pixels that weren't coming out.
  10. #160
    Mar 2010
    Wilmington, NC
    1999 323is
    Pics
    Am I the only one who can't see the pics now?
  11. #161
    Maryland
    95 M3 TT Stg 1
    Quote Originally Posted by Mathieu18 View Post
    No, they don't show up for me either...hate dysfunctional threads!!
  12. #162
    Jul 2010
    Indianapolis, IN
    1994 BMW 325i
    I used this tutorial to fix my OBC yesterday. It's amazing. It's like brand new. The pics I posted aren't the greatest, the first one was taken when the OBC wasn't even displaying text but you can see that most of the orange pixel lines are out. The second one shows the result after the first attempt. It's night and day. In that pic, the screen is dim in the middle and there's still 1 line not working but that was when I just sliced up a credit card and placed in on top of the rubber strip inside. I later opened it back up and used the tape as suggested and it's 100% working now. I think the dimming was because the board was bowed a little in the center.
    Before Pic
    After Pic
    The bulb for the clock still isn't lit. I tried swapping it with one of the working bulbs but that didn't fix it. All my bulbs work so I tried cleaning the contacts in that area with 91% alcohol. No go. Any ideas here?
    1994 BMW 325i
  13. #163
    Jun 2010
    Texas
    2005 325xi (E46)
    I did this repair and the pixels on the left side are all lit up and clear...
    The right side pixels seem to be there but I'm not sure because it's dimly light. Also, I can only see the clock/date during certain times of the day.
    Sound like the bulbs are out? Part number for the bulbs? Thx.
  14. #164
    Jul 2010
    Indianapolis, IN
    1994 BMW 325i
    Yes, the bulbs are out. I had the same problem on mine and changing out the bulbs fixed it.
    I assume all of the bulbs for the 7, 11 & 18 button OBC's are the same. I have the 11 and the part number for the bulb is 62111391260. Might as well replace them all while you're in there. They're only $1.25 each from Pelican Parts so replacing the set only sets you back $5.
    1994 BMW 325i
  15. #165
    Jun 2010
    Texas
    2005 325xi (E46)
    Thank YOU!!!!!!!! You sir are the man.
  16. #166
    Nov 2009
    Denver, CO
    1999 BMW 328is
    I did this fix today and it was a great write-up. I did pull the "connector strip" from my circuit board on the left side. I was afraid this would totally break it, but it didn't. The part where it came apart is now not 100%, but better than before. The part that didn't pull apart is 100%. I used two layers of new double sided mounting tape, it was on there pretty thick, but it wasn't a problem.
    Thanks again.
  17. #167
    Apr 2002
    Saratoga, CA
    1995 BMW M3 Coupe
    HOLY CRAP! I never thought I'd see the temperature clearly again. It works!! Thanks.
  18. #168
    Nov 2010
    Leesburg, VA
    E36 2D
    Just did this.... GOD!! thank you so much!! almost bought a "newer" one....spent 1 hour, 2 tries, and now i only have one row out (right side of second O in CONTROL) i can actually read my temp instead of looking it up in the "Predator" dot dictionary. A million thanks!!
    98 323is
  19. #169
    Aug 2002
    San Jose, CA
    Can you just add to the existing "cushion"? In other words, in stead of removiing the old cushion and putting a new one on and building it up to the correct height, can you just put a piece of tape on top if it to make it thicker?
  20. #170
    Jun 2010
    Texas
    2005 325xi (E46)
    I would say yes.
  21. #171
    May 2010
    Hernando, MS
    1993 Nissan 240sx
    http://www.amazon.com/Self-Adhesive-.../dp/B0035G9DKE
    would this trimmed down work as the cushion?
  22. #172
    Mar 2003
    Lyons, Colorado
    98 328i
    Great write up, fixed my display in about 15 minutes
    Check out my all Organic clothing line: www.BonsaiApparel.com
  23. #173
    Peoria,IL
    1992 E36 4 door
    Crazy question...Too satisfy my own curiosity, will a 18 button obc work in an a car that has an 11 button obc? Obviously without the extra functionality.
  24. #174
    Atlanta, Ga
    1995 BMW 318i Convertibl
    Bump...fixed my display! Now to figure out how to use it other than outside temp! lol
  25. #175
    Mar 2011
    south africa
    1996 323i
    Awesome perfect fix. 100% of pixels functioning.
