these were off a dynapack(chasis dyno) not dynojet..here, from teh church automotive website...
"Let's work through a comparative example for the same car on a Dynapack and Dynojet.
Car A produces 205 hp to the hubs on the Dynapack. This would equate to between 225-230 hp at the flywheel. The same car produces 195 hp to the rollers on a Dynojet. This would equate to 222-226 hp at the flywheel. Furthermore, the difference in power matches up very well with our calculated difference due to inertial losses. And interestingly enough, we have tested just such a car on our Dynapack and a Dynojet back to back with the same results (actually 196 vs. 206 hp)."
no no, there is a conversion on sean churches website
http://home.earthlink.net/~spchurch/...ting/id12.html
also see above post
1995 M3
3.0L, CP Pistons, Groden Rods, Sunbelt Cams, AA Intake/Inj./Chip, AA Exhaust, Etc....
NOS Six-Fogger, 22 Nitrous, 14 Fuel
System activates at 3300 RPM, the A/F readings are super delayed.
damn^
OBD1 S52
TMS Euro 3.5" Intake
TMS Euro 3.5" HFM
24# Injectors
TMS/JBR 10.5# Flywheel
TMS Power Pullies
TMS/JC Software
SS Race Resonator/Midpipe
Remus Sport Titanium Cat-Back
Update on my previous reply in this thread ( http://forums.bimmerforums.com/forum...79#post8680479 )
since replacing my head gasket and replacing all of my exhaust valves (they were all slightly bent due to a mis-shift a while ago) i got re-dyno'd at the same place and picked up 10rwtq and 5rwhp.
mods are same as before:
M50 Intake Manifold
Conforti 3.5" CAI
AA Custom Software
3.5" HFM (unplugged, refer to previous reply here for explanation)
Fan Delete
Strömung Exhaust
UUC Stg2 Ltw Flywheel w/ Stg1 Clutch
AA Track Pipe
again, yes it is a dynapack and no it's not flywheel hp like it says. it does read a bit higher than a dynojet because hp is measured at the wheel hub, without the drivetrain loss of the tire/wheel.
for the sake of comparison a stock e46 M3 dyno'd at the same place and pulled 246rwtq/296rwhp. from what i've seen i believe it reads around 15-20 higher than a dynojet, there's an equation to figure it all out on their website like speedinfusion listed: http://home.earthlink.net/~spchurch/...ting/id12.html
UUC EVO III SSK | M50 Intake Manifold | Conforti 3.5" CAI | AA Software | 3.5" HFM (unplugged)
Fan Delete | Strömung Exhaust | UUC Stg2 Ltw Flywheel | X-Brace | AA Track Pipe | 3.46 Differential
1/4 mile: 13.3@104.2mph; 8.6 in 1/8; 2.04 60' | Best 1/8 mile: 8.3@83mph; 1.81 60'
Dyno: 242rwhp/232rwtq SOLD
Yes, 22 NOS and 14 FUEL, in each fogger, thats with 45 psi fuel pressure, and an avg. of 1050 bottle pressure. It is definitely running rich I could probably clean it up by drilling my own .135 (the bit is available in the NOS drill set) fuel jet but I will be increasing the NOS instead.
Stock 98 M3/4.
Year: 1998
Build Date: 3/98
Mods: none
Dyno Type: Dynojet
Dyno Conditions: 68F 12% humidity
Gear Dynoed: 4th
Peak HP: 213.3 SAE
Peak Torque: 215.7 SAE
RLTW
Year:1995
Build Date: 04/95
Mods: Fan delete, URI crank pulley, OBD2 mid-pipes, Dinan V2 exhaust, Cosmos 3.5" CAI, Euro MAF, 3.5" Samco TB boot, TMS chip
Dyno Type: Mustang Dyno
Dyno Conditions: 85 degrees, 40% humidity, correction factor of 1.042
Gear Dynoed: 4th
Peak HP: 203.9rwhp
Peak Torque: 185rwtq
Am I running too rich? Average A/f is 13.1, highest A/F is 13.8 and lowest is 11.6
somethings wrong, my 328 put down 190pds with just an intake
96 328is: eurospeed M50 intake manifold with AA M50 Manifold software
rogue eng. pullies
ecis cai
M3 exhaust
M3 rear spoiler
5 spoke ROH's 235/40/17front 245/40/17rear
UUC clutch stop
motorsport X Brace
94 325- 5 speed
borla exhaust
96+ side skirts
zender front air dam
97+ nose panel
yea on a mustang dyno down at currys in VA with an ecis cai i came out with 173hp and 190 tq
rogue eng. pullies
ecis cai
M3 exhaust
M3 rear spoiler
UUC clutch stop
motorsport X Brace
94 325- 5 speed
borla exhaust
96+ side skirts
97+ nose panel
Just took my car to the dyno. Here are some numbers i'm content with.
My mods are...
Intake
Exhaust
Fan delete
Flywheel
I've got 110,000 on the odometer and it has factory software
Strong numbers for those mods
1988 E30 M3-Garage Queen
1995 E36 M3-Track Car
2004 330i ZHP- Daily Driver
///M3 Cc #1
"Gotta Pay to Play"
$In Debt Racing$
Year: 1995 M3
Build Date: 10/1994
Mods: OBD-1...Euro 3.5" HFM, Euro JC Intake w/ ITG Filter, 24lb Fuel Injectors, JC Software, Custom Track Pipes, Eisenhaus Racing Cat-Back Exhaust
Dyno Type: Dyno Jet
Dyno Conditions: 86.5 Degrees F. June 7, 2007.
Gear Dynoed: 3rd and 4th
Peak HP: 3rd-224.4 hp. 4th-228.1 hp.
Peak Torque: 3rd-212.6 tq. 4th-215.2 tq.
These numbers are SAE Corrected for hp/tq.
Car: 1997 E36 M3 evo - 321BHP - UK car spec. (STOCK)
Just had Dyno Dynamics standard shootout mode results - real bad..
check these out and let me know if you also think these numbers are dreadful.
wheel torque: 210 ft/ib
wheel HP: 195.9 HP
Crankshaft HP: 239.8 HP
BMW say they cant run any diags on the engine to see why this is? cop out i say. they spend all my hard earned money on part changing if i let them.
thanks for any replies.
sounds like its not an evo buddy,
WHp is even lower than the avg US M3
National Capital Chapter BMW CCA #367673
I dyno\d my M3 before i went to race SCCA. I had been driving the car for at least 2 hours and it was 95 deg F with 35% Humidity. I am using this as my baseline performance for comparison after i finish the turbo project on it.
98 Euro E36 M3 (ExSMG)/99 M3 Daily Driver/93 M3 (S54) TBD-hp/TBD-tq ) Current NASA track record holder TTD on street tires @ 3450lbs (Eagles Canyon 2:05.3, MSR-Houston 1:47.08)S52E36 TWS CCW 1:54.8, COTA 2:30.6 Race Lap 3yr old 245/40/18 Hankook Z214 C51)
