The baro is the issue. That barometric pressure would be normal for about 13,000 - 14,000 ft. ASL. More likely it should be in the 29.5 - 30.5 range.
The dyno isn't worthless, contrary to what's been said. It's probably within 2% of accurate.
As for the guy who said uncorrected numbers are always higher, that is absolutly incorrect. Any time you have a correction factor greater than 1 your actual power is lower than your corrected power. Up here at altitude we frequently see 1.2 - 1.25 correction factors. Uncorrected = 200 whp, Corrected = 240 whp.
Chris
97 M3
94 325is
12 Jeep SRT8
Car: 95 M3
Production Date: July-95
Mods: Bav auto chip, Cosmo CAI, Custom Borla XR1 2.75" single pipe exhaust and track track pipe, UUC LTW/M5 clutch.
Dyno Type: Dynojet SAE
Dyno Condition: 55F
Gear Dyno: 3rd
Max Power: 227
Max Torque: 215
Year: 1997
Build Date: 07/97
Mods: ECIS 3.0 CAI, M50 manifold (Eric's kit), Stromung exhaust, AA software, 91 octane gas
Dyno Type: Dyno Jet
Dyno Conditions: 65 F; 29.06 in-Hg; Humidity 27%
Gear Dynoed: 4th
Peak HP: 232
Peak Torque: 220
A/FR is from tailpipe sniffer, 82,000 miles.
There is an odd misfire at 6500, the original redline. It runs fine right up to that point, then misfires badly, as seen in all three runs. I have not figured it out yet, but if anyone has any ideas, please PM me. The AA software, which I have had for about four years now, is supposed to rev limit at 7000.
97 Estoril/Black M3/4/5
"Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
Road & Track May 1997, testing the M3 Sedan
i really need to go dyno mine now that i have the AA software, it should be just about the same as yours + a few extra ponies. hopefully tomorrow i will have a chance
that misfiring is very WEIRD. you say you've had the software for four years now, have you ever noticed the misfiring before (ie. on the street) your was it just while you were dynoing? i would call AA and email them the dyno files...
LOST POWER AFTER NEW SOFTWARE UPGRADE???
http://forums.bimmerforums.com/forum....php?p=8530214
here's an update to my previous reply in this thread on how my car is coming along:
taken from another thread i made in the e36 M3 section: http://forums.bimmerforums.com/forum...d.php?t=687627
please post all comments/replies in there.
This is from the recent dyno day we had at Church Automotive. the dyno my car ran on was a dynapack 4000. i had run there before with my current mods minus the track pipe and was decently content with the results, but my A/F was all messed (too rich) and my car was misfiring. after lots of troubleshooting i came up with the idea to unplug my MAF...yes, you heard right. so i've been driving the car around without the MAF plugged in for quite some time and wanted to get it dyno'd...here's what i got (note: this dynapack typically reads between 10-15 higher than dynojets):
as you can see i actually gained power...quite a bit actually. you'll also notice that there is absolutely no drop in torque anywhere with the addition of the track pipe.
wanna see why unplugging my MAF actually helped me? here:
look at my A/F differences between having the MAF plugged in and not having it plugged in (plugged in is the lighter lines).
something else to notice is that after around 5500rpm my rwhp line kinda flattens out. i was talking to Church and he mentioned that it seems like the car is having breathing issues (either on the exhaust side or the intake) at higher RPMs. sounds logical to me, so i'm thinking i need to clean my air filter and possibly get some headers.
ignore where it says flywheel hp, it's not flywheel numbers they are measured at the wheel hubs which is why it's 10-15 higher than dynojets. this is discussed briefly in the other thread i made (listed above).
My current mod list:
M50 Intake Manifold
Conforti 3.5" CAI
AA Custom Software
3.5" HFM
Fan Delete
Strömung Exhaust
UUC Stg2 Ltw Flywheel w/ Stg1 Clutch
AA Track Pipe
UPDATE: new dyno numbers found on page 9, reply #206... or click here here: http://forums.bimmerforums.com/forum...48#post9468248
UUC EVO III SSK | M50 Intake Manifold | Conforti 3.5" CAI | AA Software | 3.5" HFM (unplugged)
Fan Delete | Strömung Exhaust | UUC Stg2 Ltw Flywheel | X-Brace | AA Track Pipe | 3.46 Differential
1/4 mile: 13.3@104.2mph; 8.6 in 1/8; 2.04 60' | Best 1/8 mile: 8.3@83mph; 1.81 60'
Dyno: 242rwhp/232rwtq SOLD
Stock S50
1995 M3 BMWCCA IP car w/ original S50
125k miles on the bottom end
AA Headers w/ 3" exhaust
Eurosport Schrick Cam package w/ 540 MAF, 24# injectors, and Conforti chip
BW silicone intake boot
93 octane gas
NGK BKR6EK plugs (stock)
245 HP 213 TQ on a DynoJet
Just did a compression test on the motor day after dyno and all cylinders are ~210psi (+/-5)
Cold Tires + Wall = Suck
I am new to this forum, just getting started. I just installed an AA Stage 1 s/c kit using the Rotrex C-38. (1998 M3/4). On a dynojet I posted just about 300 whp and 251 wtq at about 38 degrees ambient temperature. Exhaust is still stock. Check engine light goes on and off every couple of hundred miles, so I still may have an issue with the engine tuning. My car was also tested in 4th gear. Was not able to get A/F check which is important. Some of these A/F posts are all over the place which doesn't sound right.
would it be possible for somebody to get all these entries into some type of lists (turbo - NA) and this way we can see the year then Hp. for comparsion reasons.
Reason why, is i would love to see where i stand when it comes to dyno power in this forum. (yet i understand people are on diffrent dyno's and weather conditions play a factor) The margin of error will be taken into concideration.
Year: 1999 E36 M3 S52, 72K miles
Build Date: 03/1999
Dyno Type: Dynapack
Dyno Conditions: 69.3F/20.7C, 29.53 in/999.9hPa, 32% humidity
Gear Dynoed: 4th
Peak HP: 215.2
Peak Torque: 227.0
(Sorry, system won't let me post images or links)
useful conversion from dyno dynamics to dynojet, or dynojet to dyno dynamics
http://www.to4r.com/calcs/pwtq.php
cheers, Alan
1/4 mile-12.92 @ 108.64mph-NA 3.0L m3 daily driver
Year: 1995
Build Date: 04/95
Mods: Eurosport/Conforti/Schrick package, shorty SuperSprint headers, stock cats, Stromung exhaust, underdrive pulleys, fan delete, 91 octane
Dyno Type: Dyno Jet
Dyno Conditions: ?
Gear Dynoed: 4th
Peak HP: 244.8
Peak Torque: 221.3
Compare - pre-cam to post-cam.
M50 * Bilstein PSS9 * UUC Sway's * PFlex LCABs/RTABs * TMS Delrin/Alum Diff Bushings * X-Brace * Stoptech SS Brake lines * CDV delete * DEPO with 55W 5000K HID's * 35W 5000K HID fogs
Stock dyno: 201.7rwhp SAE corrected
[QUOTE=speedinfusion;8684104]Stock S50
clearly states on the graphs "flywheel torque" and "flywheel horsepower"
cheers, Alan
Here's my old engine:
Year: 1997
Build Date: unknown (transplant from totalled car)
Mods: OBD1 conversion, Sunbelt alt. pulley, underdrive pulleys, stock 3.0" HFM, K&N FIPK intake, AA chip, stock manifolds and cats, Borla cat-back exhaust, fan delete, 93 octane. No internal work.
Dyno Type: Dyno Jet
Dyno Conditions: cold outside - warmer in shop, probably 45 degrees
Gear Dynoed: 4th
Peak HP: 242
Peak Torque: 223
Will post new engine when it gets done and dyno'd.
2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
Does anyone have a link to a dyno of an s50 with:
Euro HFM, intake, Software, Stock injecters (otherwise stock)
VS./OR
Stage 3 cam kit (Euro HFM, intake, software, 24lb injectors, cams, otherwise stock)
I know that many companies have their own dynos, but Id like to see 3rd party dynos for realistic comparitive purposes, especially seeing numerous examples of HFM kits (even with 24lb injectors) only putting down around 15 WHP.
Thanks for any help
Car: 95 M3 Euro
Mods: GT35R ball bearing turbo,Herrera chip,3,5" exhaust,Monster intercooler,HKS blow-off valve,Greedy gauges,Schrick cams.
Dyno Condition:n/a
Max Power: 540
Max Torque: 515
Gear: 4th
1995 Avus Blue Euro ///M3 - Garret GT35 - Giant intercooler - Schrick cams - 10.000k xenon eyes - 619whp dyno tested - R.I.P M6! 1996 740i 20" wheels and E30 318is with M3 upgraded engine.SICK!!http://forums.bimmerforums.com/forum...d.php?t=743415
nice numbers.
ESS 625RAGE AGAINST THE MACHINE
Heres mine.
Dynoed in 3rd gear.
I actually made 208.2wtq on the first run. They printed out the third run but as shown I made 228.39 whp/207.42wtq. Mods in sig.
Year: 1999
Build Date: 11/99
Mods: Custom CAI, M50 manifold
Gas:93 shell
Dyno Type: Dyno Jet Research
Dyno Conditions: 50.78 F; 29.37 in-Hg; Humidity 20%
Gear Dynoed: 4th
Peak HP: 229.08
Peak Torque: 221.66
CF:SAE
update 4/07
Year: 1995
Build Date: 04/95
Mods: Eurosport/Conforti/Schrick package, shorty SuperSprint headers, stock cats, Stromung exhaust, underdrive pulleys, fan delete, 93 octane update 4/07: Samco intake elbow, AA track pipe replaces cats
Dyno Type: Dyno Jet
Dyno Conditions: update 4/07: 65.9 F, 29.87 in-HG, Humidity 34%
Gear Dynoed: 4th
Peak HP: 244.8 update 4/07: 246.0
Peak Torque: 221.3 update 4/07: 227.58
