I don't have my graph on the internet yet but here's the specs
Year: 1995
Build Date: 9/95
Mods: stock S50 OBD-1 motor with recent head rebuild(dropped valve) and borla catless track pipe, thats it.
Dyno Type: DynoJet
Dyno Conditions: 99.31*F, 29.33 in-Hg, Humidity 32%, SAE: 1.05
Gear Dynoed: 5th gear
Peak HP: 222.64 hp
Peak Torque: 207.49 ft-lb
I'll post the graph when it becomes available to me from Tulsadyno.com
Ted Teten
1995 M3 Coupe - S52'd
Year: 1995
Build Date: 12/94
Mods: AA Chip
Dyno Type: DynoDynamics
Dyno Conditions: 95 ish
Gear Dynoed: 4th gear
Peak HP: 223.4 hp
Peak Torque: 212 tq
RPM is off about 600 RPM at redline... the operator used the rollers to calibrate RPM and his figures where off a bit.
AA Chip, bought on sale during their summer sale...
I think my A/F is wacked... thoughts?
///MONEYPIT MOTORSPORTS
89 M3
00 M5 - DD
Your A/F looks like its leaning out worse than mine. You might look into that.
Ted Teten
Year: 1996
Build Date: 10/96
Mods: Dinan-CAI, BBTB, exhaust, and Stage III SW.
Dyno Type: Dynojet
Dyno Conditions: 70F, SAE corrected
Gear Dynoed: 4th
Peak HP: 206.9 hp
Peak Torque: 205.1 tq
I believe my numbers are a bit low. What things can I work on to improve my numbers?
'03 E46 M3 SMG Silver Gray
///Performance: AFE stage II intake, Magnaflow cat-back ///Interior: Silver CF Royal style paddles ///Suspension: Eibach pro-kit
I don't think your numbers are too far off...I wouldn't think a BBTB TB would help all that much with all the small diameter stuff still in line.
did you romp on it a few good times on the way to the dyno shop to get your fuel trims in line? and was the coolant temp above 200* when they did the runs?
Eric Paul Eviston - 1 Piece Silicone Hose M50 Manifold Conversion Kit
******M50 Manifold Install Trouble Shooting Guide Here: www.m50manifold.com
'98 M3/4 - ECIS CAI, S50 Manifold, Conforti Software, 16" Spal Puller, UUC Pulleys, Fan Delete, UUC Stage 2 Fly w/M5 Clutch, UUC Blacks w/TMEs, X-Brace, GC RTAB shims, GC RSMs,
M Roadster lever, 245x40x17 all 4 corners, Drilled Zimmermans, Motul RBF600 and Redline Synth fluids. My Dyno HERE
My Website: www.m50manifold.com
My Email: info@m50manifold.com
Conditions
Elevation 600'
Temp 88F
Dyno Dynojet
Max Power 292.5
Max Torque 232.7
Comments Running way rich with AFR under 12 at 5400, under 11 at 6000, dipping to 10 at 6500, staying under 11.5 to rev limit. Power and Torque cross at 5300. Max power at max rpm.
Will try to scan sheets ASAP.
Nope, didn't drive it hard before dyno-ing it. Not sure what the coolant temp was, but my car was pretty cold (only idled 1-2 mins before the dyno test). Now that I think about it, the car should be at operating temperature before testing.
Btw, I'm very interested in the M50 manifold kit. Don from modbargains tells me you definitely know your stuff!
-eric
Year: 1998
Build Date: 03
Mods: K&N Intake Short Ram , UUC V.2 Exhaust , Active Autoworks Ecu .
Dyno Type: DYNO JET
Dyno Conditions: 50 degrees HALLOWEEN 06 NJ
Gear Dynoed: 4th
Peak HP: 223.86
Peak Torque: 225.67
NOT SURE whether hp/torque numbers are SAE corrected or not.
Regardless i think there high but alot od members say there not. Car feels good.
Year: 1999
Build Date: 03/99
Mods:New S52 w/ 2K miles, K&N brake duct ram air intake, M50 manifold, 3.5" air intake, stock HFM, Dinan SC, Dinan SC tune(sucks), RMS Aftercooler, Bavarian Autosport coils, NGK Iridium plugs, Dinan exhaust, UUC E34 M5 8.5lb flywheel, I think that's all that would have any effect on the dyno
Dyno Type: DYNO JET
Dyno Conditions: 60 degrees in closed shop
Gear Dynoed: 3rd & 4th, best reading in 3rd
Peak HP: 295.60
Peak Torque: 257.26
I would like to go on record that it doesn't make me happy that I am only making 70hp over some stock cars with over $15K in mods!!!
1999 E36 M3 S54 conversion, Dinan exhaust, Zionville Comp Kit, MCS Coilovers, E46 CSL Brake conversion and ducting, UUC Swaybar, Vorschlag camber plates & rear shock mounts, X-brace, Pflex RTABs/Subframe, MSW engine mounts, Rogue diff, ZKW LEDs, Racebred splitter, 9Lives Big Wang, SPA Fire system, Cobra seats, Schroth 6 pt, Ben Sipson roll bar.
I'm surprised your torque# should be higher consider that you got a SC.
They don't intersect because the scales for tq and hp aren't the same.
If you look carefully, at 5250 RPM, he's got the same value of tq and hp, ~250. It's a mathematical given, when units used are ft-lbs and hp.
just did my dyno to day on my 98 e36m3 at the dyno shop in santee ca..225 max hp and 226 max torque ,,conforti cold air filter,dinan chip ,dinan cat back,irridium plugs,118,000 miles,original o2 sensors,should i spend a fortune and change all 4 of them??...i feel happy with my dyno compared to a lot of other e36s..i had them run it up to 6800 rpm..
Year: 1997
Build Date: 01/97
Mods: AA intake, track pipe, genIII exhaust and Software.
Dyno Type: Dynojet
Peak HP: 222.58 rwhp
Peak Torque: 213.15 rwtq
Is there a conversion for STD correction to SAE?
1997 M3
3.2L Race engine from BPG originally built for BMW club racing (IP), Sunbelt OBDII cams, accessory UDPs, stock compression, stock headers.
Default AA tune for the Sunbelt cams
Latest dyno with track pipe installed:
Chris
'95 330ti Club Sport w/sun roof delete, S50USB30, Schricks, 24# inj, BBTB, Conforti SW, Euro HFM, Samco Silicone Intake Boot, Euro oil cooler, JTD Cold Air Intake Duct, RE DMS exhaust, RE Tranny mounts, CF Valve Cover, LTW flywheel/Kevlar sprung hub clutch, RE SSK, 3.46 Finned LSD (M6) , M3 tranny, Brembos, RE Wheel Studs, SS brake/clutch lines, CF interior, Tilt Steering retrofit, 13.5 lb DynaBatt in rear, LED interior/footwell lights, 4500K ZKW HID, Headlight Aim Control, Rear fog light w/cluster indicator, BMW Traffic Pro/Alpine MP3-CD Changer, Staggered LTW wheels, '95 M3 steering rack, VIS CF Hood, M3 LTW Strut Bar, Aluminum M3 Coilover Front/M Coupe Rear suspension, Red LTW Motorsport Seatbelts, OEM Fire Extinguisher, Z8 Starter button, Auto dim rear view mirror w/Homelink, PDC, Rear Sun Shade, Euro Gauge Cluster w/oil temp/shift light , Headlight Washers, BMW MS Door Handles, CF Grills, French ZKW Fogs, Bimmer Mag 8/2007
New Dyno Numbers!
next i'm sending the DME to Active Autowerks on monday for custom software, i cant wait to see the numbers after that.
Year: 1997
Build Date: 02/97
Mods: M50 Manifold, Custom Intake, Custom Exhaust, UUC Pulleys, Fan Delete
Dyno Type: Dynojet
Dyno Conditions: 57 deg. / 7% hum. / 1150 ft Alt.
Gear Dynoed: 4th
Peak HP: 220.96 SAE corrected
Peak Torque: 221.02 SAE corrected
...and here it is compared to my stock run
your before and after numbers, was this done on the exact same dyno? same place? same temp?
Honda technician
same dyno, same place, similar conditions.
i'm going to wait and see what the dyno chart looks like after i install the AA software.
Heh, I'm glad some of you guys from the dyno day posted up your results.
Mine was basically the same except I had a better afr. 227/205. They said that the reason it was a little but lower than last time could be from my k&n being dirty.
Whatever, hopefully this is my last dyno with my current mods.
'94 325is #94 IP/GTS3 Mauritius Blue Metallic
"And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high." - Ayrton Senna
Got dyno'd yesterday at westech performance in L.A. However, I'm on a Mac and therefore can't use the windows software they gave me to make a proper graph. Here is a link to the data in SFD format: http://veonake.robinsoncove.net/m3/baseline3.sfd
I made 201.7whp SAE corrected, 211 STP, 221 dynojet. This is a baseline dyno as I just received the M50 kit (have not yet installed) from Eric and wanted to know where I was at.
Following the dyno sheet thread:
Year: 1998
Build Date: 11/1997
Mods: No engine mods unless NGBRQUEP count.
Dyno Type: Superflow
Dyno Conditions: 72 degrees F, 29% humidity, 29.13 barometric
Gear Dynoed: 4th
Peak HP: 201.7
Peak Torque: 196.5
Here is an STP graph someone made for me. Can't tell much from A/F based on this graph due to scaling, sorry about that, I've included a seperate A/F graph below. Oh, and I guess the operator didn't adjust for RPM completely properly as it shows redline at 6750 in 4th and I'm not chipped.
Any thoughts?
M50 * Bilstein PSS9 * UUC Sway's * PFlex LCABs/RTABs * TMS Delrin/Alum Diff Bushings * X-Brace * Stoptech SS Brake lines * CDV delete * DEPO with 55W 5000K HID's * 35W 5000K HID fogs
Stock dyno: 201.7rwhp SAE corrected
Year: 1999
Build Date: 1-1999
Mods: stock with 155400 Miles
Dyno Type: Dynojet 248c
Dyno Conditions: 68.15 F, 30.35 in-hg, Humidity 45%
Gear Dynoed: 4th
Peak HP: 208.62
Peak Torque: 215.92
