My first time ever on the dyno today, pretty happy with how I did. According to the shop owner his dyno reads a bit low although I came in better than I expected. He asked me what they make at the crank stock, and what I had done. I told him I'd be happy with anything over 210 and he asked how I'd feel when it read 195. He was pretty impressed, joking with the other mechanic that me and the other guy there were the only ones that hadn't been disappointed on their dyno. Other guy had an E30 325is that put down 144/144.
Year:1996
Mods: FDM, UUC water pump pulley only, BavAuto coils, debaffled airbox, chromoly flywheel
Dyno Type: DynoJet
Dyno Conditions: 72*F, 45% RH
Gear Dynoed: 3rd runs 1 and 2, 4th run 3
Peak HP: 220
Peak Torque: 227
Vid of the 3rd run:
@M3AMI
96 BG/Magma Lux
Mods. Lots of Mods.
How have all of you prepped your car for the dyno?
I'm running mine tomorrow, 3 pulls, and stock.
Definetly removing whatever is in my trunk, including the spare tire. Anything else?
'98 ///M 3/2/5 - Cosmos on Dove [SOLD]
'08 335i Coupe - SGM/Grey | MHD Stage 2 93oct | Apex Arc-8 18x9.5 Black Chrome | Cp-e Charge Pipe | VRSF C****** Downpipes | VRSF 5" Stepped FMIC | AA BOV | DCI | BMS Cabin Filter | Custom-Mounted Nexus 7 infotainment tablet
How long will it take for it to learn my aggressiveness? Does the DME change if I drive aggressively the night before?
Sent from my DROID RAZR using Tapatalk 2
Model: e36 M3 Cabrio (5-speed)
Build Date: May '98
Mods: ZHP Shift Knob, other than that it's all STOCK
Dyno Type: DynoJet
Dyno Conditions: 66, 67, 69 (in run order), 29.09 in-Hg, Humidity: 40%
Gear Dynoed: 3rd (through all 3 pulls)
Peak HP: 190
Peak Torque: N/A
Speed: 86MPH
$20 for 3 pulls on a mobile DynoJet. Car is completely stock with a new Mann Air Filter in it (if I would have removed it I probably would have had at least 5hp more). Oil change about 1k miles ago, brand new wheels.
Vf stage 2 with methanol on a conservative mustang dyno. Running 9.5lbs of boost. Best run was 361whp/303wtq.
Year: 99
Build Date:
Mods: fdm,Simota intake,asc delete with z3 boot,m50 mani,ebay header(us ss rep),custom dual piping with h-pipe mid pipe(300 cell cats), eisenmann race catback. STOCK tune(car was back on the road a week ago after being batteryless for winter. Not sure what if any change that has to adaptations)
91 shell v power.
Dyno Type: dynojet
Dyno Conditions: 65 F,70% humidity
Gear Dynoed: 4th
Peak HP: 226 whp sae
Peak Torque: 209 wtq sae
Mileage: 98k miles.
pulls were back to back and power dropped each pull(As it did on pretty much every other car.) inadequate fan maybe?
a little misfire on one pull(happens occasionally)
anyways, torque seems a bit low however they called that dyno the "heartbreaker"
torque seems to hold quite flat though especially compared to most.Hp is still climbing all the way till cut off which seems different than other cars with similar mods(they flatten before cut off as torque is dropping more significantly)
vanos seems to work fine though its still original(not rebuilt or changed). original coils and o2 sensors too.
You cant dyno race but last yr(before some other stuff Ive done since) the car trapped 101 mph.
E46 m3 with evolve tuned and ebay headers did 287 whp to give you a comparison. (another stock one did 269).
Hp Im ok with ..torque Im a little confused with. Yes its an s52.
http://www.youtube.com/watch?v=kxa6XvhkMkk
no thoughts on my less than stellar torque ouput?
I'd say it depends on the dyno. If you go back a couple pages, you'll see some dyno results I posted. My friend's M3 with very similar mods to yours made 210tq, and less HP than you did on our local "heartbreak" dyno. My car with more intake mods, a reflash and no headers only made 231/224. This was all in blazing FL heat and humidity though. I'd say if you're on stock tune and a very low reading dyno, you shouldn't be that concerned. Also a stock tune E36 trapping 101 makes me upset mine only trapped 102, almost 103.
Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
very good points. It is a bit of waste to compare dynos. The only mod Im looking for next is a flash/tune of some kind. If it can bring a bit of mid range torque back up Ill be happy.
thanks for the insight.
Year: 99
Build Date: 4/99
Mods: built motor 11.5 comp, 93 pump, Schrick cams, BBTB, Euro SS long tube headers, Catless SS mid section, SS axle back, 809 MAF, LTW flywheel, CAI,Turner pulley, fan delete, Ported & polished head, ASC delete, Custom tune
Dyno Type: DJ
Dyno Conditions:87 F , 49% Humidity
Gear Dynoed:4
Peak HP:283WHP
Peak Torque:256.89WTQ
Ill load the graph when i get them
The older i get, the faster i was !
Nice power. That is S54 power from an S52. Which Shrick cams, the older mild or the newer sport? At what RPM was peak power made and what is the rpm limit?
95 M3, 175k miles
Mods in blue line:
3.5" maf, intake, and BW boot
AA tune
JB 10lb fly
UUC TSE, stock exhaust otherwise.
Red line:
Above with Turner Shorty headers, AA Race exhaust (w/resonator)
21.5lb injectors
TRM tune for mods.
"Fear disturbs your concentration" -Sabine Schmit
1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
Year: 95
Build Date: 6/94
Mods: S52, M50 intake, 3.5" HFM, 24lb injectors, Turner shorty headers, BW carbon LTW clutch/flywheel, CAI, BW boot, fan delete, underdrive pulleys, custom 3" exhaust, 93 pump, Vipec w/ custom tune
Dyno Type: DJ
Dyno Conditions:83 F , 72% RH
Gear Dynoed:4
Peak HP:252 WHP
Peak Torque:232 WTQ
Well....it depends. The torque advantage is too big to ignore. 10whp/20ftlbs is about right, across the board.
I think you could get an S50 with all the bolt ons (no ITBs) to about 235-240whp max, but you will struggle to break 220-225tq.
S52s with same level mods are 245-250whp and 230+tq.
Does anyone know why there is a small flat spot in HP around 4K RPM with these engines? I see it in a lot of the dyno graphs in this thread and I can feel my car have a slight hesitation around that RPM when accelerating. I never experienced this hesitation with my '95 M3 but I feel it in my '97 and have had a couple customers at the BMW shop I work at mention a slight delay in acceleration around 4K RPM with their cars.
1997 Byzanz M3 4 door 5 speed. (1 of 37 factory 5 speeds, 1 of 88 total produced)
TMS power pulleys, V1, E21 trans mounts w/AKG cups, AKG derlin shift tower bushing, 80/88* fan switch & fan delete, Borla XS dual in/out muffler, 4300K HID's in Euro housings, PowerFlex RTAB's, 17x8 ET15 Racing Dynamics RGR wheels, GC coil-overs 375F/475R, 25.5mm M-tech front swaybar, tint
maybe the vanos steppings...
S50B32 341Bhp@7800Rpm, CDA SP03, Supersprint manifold+decat+Rear race exhaust, BMW Performance Brembo 6/2pot brake with E46 M3 CSL discs, KW V3, H&R sways, Motorsport strut bars, fully powerflexed, GT2 optic, 19" BBS RS-GT wheels with Michelin PSS.
Just reviewing the last page here, why are our S52's signing off at 6000 rpm? Is it tuning? Certainly not a pumping issue, we have people with 3" exhausts and 3.5" mafs, M50 intakes and cams. I would think a Shrick cam would be timed for high rpm power right?
Is it tuning? Fuel pressure/volume inadequate? ( I didnt see any upgraded fuel pumps) Does everyone maintain 3.5 bar to 7k?
cause the S52 is a "mid-range" torque engine, you can switch the power to higher rpms with sharper cams like Schricks and Sunbelts, but you will give up the low and mid range. Schricks are the best for street and track, sunbelts give a lil bit more power at top but loose a lot of torque around 3-4k rpm. There are a thread with approx 290cams, as I remember that car has euro M3 power at top end, but useless under 4-5k rpms...so not for daily drive.
Model: '95 M3 (5-speed)
Build Date: May '94
Mods: TMS Chip, 3.5" Intake, 3.5" HFM, BW TB Elbow, Dinan BBTB, 24lb injectors, SSAC Headers (FAIL), AA Track Pipe, AA Exhaust, UR Crank Pulley
Dyno Type: DynoJet
Dyno Conditions: 91 degrees, 29.60 in-Hg, Humidity: 37%
Gear Dynoed: 4th
Peak HP: 227.17
Peak Torque: 208
Miles on Engine: 225k+ (exact mileage unknown)
Car has a non-functional VANOS, as seen by the lack of low end power/torque. The early SSAC headers have an atrocious bend on one of the cylinders that basically makes a 180 degree bend and folds in on itself..it is laughable.
Overall, I am fairly pleased all things considered.
**No wideband was on the car for these pulls**
Video:
1995 M3 - Forged 9.8:1 2JZ, S366, MS3x, E85, LQ9s, 420g/PMC Motorsport kit, 4 clutch 3.15 LSD Large Case 757whp/710wtq
2011 X5 Xdrive35d- Blk on Cinnamon, Towing Pkg, Heat Pkg., etc..the tow rig/DD!
Guys, somebody knows that the DynoDynamics - AWD 450 DS Quad retarder Chassis Dynamometer measures high or low? I will go to dyno my car on this type, because a few days ago I was on an "individually" made dyno and it measured 281WHP and I think its a little bit high for an S50B32 with SS race system, BMC CDA and propably the ECU got chipped cause it redlines at 7800rpm instead of 7400.
^That looks about right
