1995 M3
Mods: Turner chip, CAI, AA Gen 3, ODB2 exhaust manifolds
Unmods: Automatic transmission
Dyno: Dynojet (Bavarian HyperSports)
Dyno Conditions: Cool, rainy
HP: 201 SAE
Tq 190 SAE
Tested in 3rd or 4th.
Had problems with it downshifting on accelleration
Year: 1995 M3
Build Date: 06/95
Mods: OBDI S50 Rebuilt Motor Bored w/ 2nd Oversized JE Stock (Stock Compression), 540 HFM, AA Intake, EuroSport Chip, URI CP, 3" Custom Midpipe w/ 3" Magnaflow High Flow Cat, OBDII 98 M3 Exhaust
Dyno Type: DynoJet (Dyno Xtreme)
Dyno Conditions: 76*F 19% Humidity, Sunny/Cool
Gear Dynoed: 4th Gear
Peak HP: 231.72 SAE
Peak Torque: 228.42 SAE
R.I.P.
95 Daytona Violet TURBO M3/2
Dove Alcantara/ Dark Grey Leather
Where in SD did you dyno, Crawford?Originally Posted by cstang68
Steve
Year: 1995 OBD1
Build Date: 10/95
Mods: US S52 3.2L, (had less than 3k miles when tested), JimC Schrick Cam kit, 3.2L Flywheel, SuperSprint headers, Custom track pipe, B&B Tri-Flo & 3.38diff
Dyno Type: DynoJet
Dyno Conditions: 80 degrees & muggy, April 05
Gear Dynoed: 4th
Peak HP: 256.9 SAE Corrected
Peak Torque: 236.1
I could squeeze a little more HP out with custom tuning but I really don't have the urge to mess with it. I'm embarrassed of my dyno results because I was a dyno n00b (First time evaR) and screwed up my first run.. anyway.
He who hesitates is not only lost, but miles from the next exit.
Originally Posted by jmargo
One of my favorite things about your car is definitely the License Plate. MPOSTER Its tight
Year: 1995
Build Date: 9/95
Mods: Turner Motorsports Chip (Euro HFM and 24lb Injectors), Cosmos CAI, Euro HFM, GC Gizmo, 24lb Injectors, AA Headers, AA Trackpipe, AA Catback, UUC Pulleys
Dyno Type: Dynapack hub/chassis dyno
Dyno Conditions: Dynoed inside facility, but outside was 45* clear and dry midday during month of December
Gear Dynoed: 4th
Peak HP: 222.1rwhp @ 6000 RPM
Peak Torque: 219.16rwtp @ 4250 RPM
All numbers are SAE corrected.
The before and after are with the GC Gizmo
Ignore the lean map here.
Turner Chip|Cosmos CAI|Euro HFM|GC Gizmo|24lb Injectors|AA Headers|AA Trackpipe|AA Catback|UUC Pulleys|UUC/Fidanza LTW Flywheel|M5 Clutch|Corbeau A4s|ZKW 6000K 50watt HID|ZKW French Fogs|Smoked Corners/Sides/Tails
*DYNAPACK* 222.1rwhp @ 6000/219.16rwtq @ 4250
it says it was dynoed in third gear. I dont have much experience with dynomometers so I dont know if it will make that much of a difference.Originally Posted by SleepRM3
Year: 1999 (97 motor)
Build Date: Unknown
Mods: Cosmos CAI, Dinan Stg 1 ECU, URI Crank Pulley, Custom Magnaflow Catback, Moly Coated JE Pistons, 3-angle Valve Job
Dyno Type: Dynojet
Dyno Conditions: 2/26/2006, 9am, 69F, 38% Humidity
Peak HP: 227 SAE @ ~5900rpm
Peak TQ: 236 SAE @ 3970rpm
Car was running on 1 of 4 O2 sensors, and spark plugs were fouler than Hilary Clinton's you know what. AFRs were probably in the high 10s to low 11s (car SPEWED black smoke, so much so that the entire building filled up over the 2 runs)
'03 E46 M3 - "Brittney"
'92 E34 525i - "Ivanka"
Went to Wayne's Dyno too xeler8. I'm not sure if this is normal. Seems a little low for my mods. And running full tank, 1/4 of it 110 octane.Originally Posted by xeler8
Year: 1995
Mods: 3.5 HFM w/conforti intake setup. B&B triflo exhaust.
Dyno: Dynojet.
Dyno conditions: 60 F
Gear dyno: 4th
Peak hp: 215 whp
Peak Tq: 200 ft lbs.
Mileage: 111k
The guy also left the freakin' oil cap off during the runs too, wasn't happy about that. It sounded like a monster with 3.5 intake but I was a bit disappointed with the numbers. Do these stats sound normal?
Don't have the chart to scan. Just wanted some info....
Originally Posted by fast95m3
Sounds a little low.. did you get an A/F reading? .. chances are you are running too rich.
If it was properly tuned I bet you put down well over 220.
Bring MoneyWith you.
Year: 95
Build Date: 3/95
Mods: Turner chip, 24lb injectors, Euro HFM, Cosmos 3.5 CAI, AA Gen 1 catback, LTW flywheel, URX pullies
Dyno Type: Dyno-Dynamics (reads lower than Dynojet)
Dyno Conditions: 65 degrees
Gear Dynoed: 3rd
Peak HP: 216.1
Peak Torque: 200
Just like Bav///Man (1st dyno posted) i'm running way too lean from 3000-4500 and then i go pig rich from 4750+. I am convinced this is directly related to the Turner chip, Conforti is notorious for tuning rich and Turner chips are also known for running lean down low. I'm going Stickley when i get the cash.
VIDEO: http://forum.vwsport.com/pics/data/3061/dyno.avi
If you talk to Jim C though, he'll tell you that the AFR graph isn't supposed to be a straight line. The chips are tuned that way for a reason.
If you'd like to know more about it, there is a great thread with numerous posts by him. Search his username.
Congrats on the #s! Same as mine!
-Dave
i'm not saying it should be flat, but richer than 12:1 on a lightly modded NA car is horrendous.
Year: 1999
Build Date: Early 1999, I think...
Mods: Click the website in my sig.
Dyno Type: DynoJet
Dyno Conditions: 70-80 Degree and Low to Mid Humidity
Gear Dynoed: 4th
Peak HP: 262.5
Peak Torque: 243.9
"We are the music makers...and we are the dreamers of dreams."
Year: 1994
Build Date: car 7/94, motor 1/95
Mods: 3.0l M3 engine, jim c chip, autothority intake, borla catback
Dyno Type: DynoJet
Dyno Conditions: 94 degrees
Gear Dynoed: 5th
Peak HP: 229.86
Peak Torque: 212.11
'94 325is #94 IP/GTS3 Mauritius Blue Metallic
"And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high." - Ayrton Senna
nice numbersOriginally Posted by 94is
ESS 625RAGE AGAINST THE MACHINE
Year: 1995
Model: M3
Engine: 3.0 OBD1
Performance Mods:
Conforti chip
3.5 Euro HFM
Remus Catback
Conforti intake
Dyno: Dynojet
Temp: 77 degrees
Humidity: 29%
3rd and 4th gear pulls
91 octane with 1 can of booster
Brand new plugs
Cleaned HFM
10-40 Castrol Synthetic
Peak Horsepower: 208.65
Peak Torque: 201.81
I'm really shocked at these numbers. They seem VERY low to me. The same as a stock engine. Turner claims 32hp with this kit. What say you? Help is greatly appreciated.
They do look a little low....especially for those mods on a dynojet...hmmm
-Dave
Sonofa FAKE TMS CHIP!!!!!! That explains it.Originally Posted by Bav///Man
I want to call out Projekte36 for this fake TMS chip.....nice job man, nice job
Year: 1998
Mods: Dinan CAI, TB, HFM, exhaust, stg. 4 s/w, m50 manifold
Dyno Type: DynoJet
Dyno Conditions: 76 degrees
Gear Dynoed: 4th
Peak HP: 236.8
Peak Torque: 218.1
http://www.duke.edu/~jkh10/dyno_4-22-06.pdf
Year: 98
Build Date: 4/98
Mods: VFE SC 6psi. Stromung.
Dyno Type: Dynojet
Dyno Conditions: 70 degrees
Gear Dynoed: 4th
Peak HP: 303
Peak Torque: 257
hamada
Italian Twin Webers 40DCOE||Ireland Engineering 292 Cam||MSD 6A Ignition||Euro tii Raised Bathtub High Compression Pistons 9.8:1||IE SS Headers and Exhaust Modified to Twin Tip Center exit||Custom Recurved Dist||Curt Ingraham 3 Core Rad||Bilsteins||ST Springs and Sways||IE tii Strut Bar||Parker Performance VDO setup||Italian Blinkers||Original Old School Hella 160 Fogs|| Trap Mirrors|| 14x6 Superlites || Aardvark Racing Recaros
Just dyno'd my M the other day....
Year: 1995, 145k miles
Mods: CAI, Dinan Chip, Track Pipe
Dyno Type: Dynojet
Dyno Conditions: 87 degrees, 20% humid
Gear Dynoed: 4th
Peak HP: 219.4
Peak Torque: 210.5
I noticed a decent spike in TQ right around the 3,700 RPM range... I think a new vanos selenoid is in order. Also... I'm running lean down low, not to bad in the middle, and lean again past 6k. Although.... someone told me that not having cats could throw the AFR off. thoughts?
