This is in 5th at 80 degrees and 60% humidity. Stock tire size and gearing. Shark and possibly a special airbox. I don't see the airhorn that some have talked about removing from the US airboxes. Anyone have a pic of a Euro airbox that I could see if that is what i have?
Year: 1995 (120k)
Mods: S52 obd1 with Dinan cai, stromung exhaust, software, 24 pound injectors, 540 mass air, RR throttle body, AA ssk and UUC underdrive pulleys.
Dyno Type: Dynojet
Dyno Conditions: 77F
Gear Dynoed: 4th
Peak HP: 235.6 rwhp
Peak Torque: 225.1 lbft
[OO==[][]==OO]
Year: 1995 (122k)
Mods: UUC System U,AA Track Pipe, Euro Header, Turner Chip
Dyno Type: Dynojet
Dyno Conditions: 103F
Gear Dynoed: 3rd
Peak HP: 209rwhp
Peak Torque: 195 lbft
Seems a bit on the low side....other than temp any other clues on why?
The gear might have been wrong, My car had 225 in 3rd gear, but it still would be too low.
[OO==[][]==OO]
I tried 4th first and it was lower i think i've got an 02 sensor issue as the CEL likes to go on and off for some reason and came on for the 1st time since chip installation on the way to the dyno
this thread depresses me.
swap time, sexy e30
[OO==[][]==OO]
1996 OBD II S52, CAI, Pullies, BBTB, M50, LTW Flywheel, Dinan Stg 3 Tune, Headers, "Track pipe", AA Gen III catback.
Done on a dynocom "Mustang" dyno, about 70 outside.
Year: 1999 M3 (36K miles)
Build date: 10/98
Mods: M50 Mani, CAI and Stromung
Dyno Type: Dynojet
Dyno Conditions: 89.94*F
Gear Dynoed: 3rd
Peak HP: 234.12 rwhp
Peak Torque: 222.92 lbft
wow... not going to lie, most of you have dumped some good money into your cars and i'm not seeing much improvement off stock. f/I is starting to look really nice.
New bumper on order!*TMS Conforti Chip*
*Euro 3.5" MAF(Bosch)*3.5" CAI*Remus Exhaust*97+Center pipe*LTW flywheel*SACHS clutch*
What A/F ratio should I be shooting for? I see other lightly modified cars look like mine - around 13.
-Dr. Seuss
Year: 1998.5 M3 (109K miles)
Build date: 06/98
Mods: Cosmo Short Ram Intake & Borla Gen II Catback
Dyno Type: Land-And-Sea All-Wheel Drive (AWD) 2500 Pro Chassis Load Bearing Dyno ($110k, one of three in USA)
Dyno Conditions: low 80s
Gear Dynoed: 5th
Peak HP: 227 rwhp
Peak Torque: 239 lb/ft
'95 Avus Blue M3|Dinan tune|Cosmos V1 CAI|Recaro|3.23 lsd|Magnaflow| -SOLD
'95 Cosmos M3 |Cosmos Racing V1 3.5" CAI|Samco rep TB boot|740i HFM|Turner Tune|UUC Pulleys|CF Hood|Depo 6000k|Depo french fogs|Depo Tails|Black Wide Kidney Grill|AA exhaust|Zimmerman Drilled rotors|Sparco|B&M SSK|Koni S&S|BMP Bushings|Wahlbro 255|Stewart Thermostat| 240whp -SOLD
'09 135i 6mt |BMS JB4 g5iso| MHD BMS Flash| BMS DCI| BMS Chargepipe | BMS Inlets| RB PCV| N54 Perf 3" DP| Wagner FMIC| Ryan Racing DV Valves| Fuel it Stage 2| e60| 480whp
M52 E30 is still not fast compared to a M3.
E30 Turbo 2.8L - 60ft - 1.70 :: 1/8th - 6.99 :: MPH - 105.47 :: 1/4 - 10.66 :: MPH - 132.53
Daily E36 M3 - 60ft - 1.790 :: 1/8th - 8.20 :: MPH - 84.68 :: 1/4 - 12.81 :: MPH - 107.05
*RIP* E36 M3 - 60ft - 1.944 :: 1/8th - 8.64 :: MPH - 80.00 :: 1/4 - 13.55 :: MPH - 99.95
Cool2seat's TTstg1 E36 M3 - 60ft - 2.123 :: 1/8th - 8.44 :: MPH - 87.71 :: 1/4 - 12.94 :: MPH - 107.95
only mods. it's a beast. the dyno is the most accurate one you can buy too apparently.
for what its worth:
a) there is another guy on the GA forum who has a higher number from same mods. i think +3 hp or something like that. less torque though.
b) the other m3s done in the same week as my dyno were pulling 200/215, 215/220 type numbers using the same parameters as mine. so they weren't all pulling my numbers if you want to attribute it to the dyno.
thats pretty crazy, are you the original owner or what, have you done all your maint?
06 silbergrau Z4MR
3rd owner, but i've had it for over 3 years. First owner was a radiologist, second was a psych grad student. Yeah, all the belts, pulleys, cooling, plugs, filters, etc. Also, I only run 5w30 oil. Never synthetic. Changed every 3k exactly. And everyone says that my engine runs much quieter than average.
But yeah, i'm in grad school (limited funds), so instead of engine mods, i do religious engine maintenance. For most people on here, it's opposite unfortunately.
