Page 12 of 33 FirstFirst ... 2345678910111213141516171819202122 ... LastLast
Results 276 to 300 of 815
Thread: E36 M3 Dyno Sheet Library
  1. #276
    Apr 2008
    San Francisco, CA
    1997 M3 Coupe
    So, a basic question, what's the standard cost of a Dyno session?
    Thanks.
  2. #277
    Apr 2008
    UK
    M3 Evo Cab
    My Euro M3 convertible.
    Year: 1998
    Build Date: Not sure
    Mods: None
    Dyno Type: Dyno Dynamics (Thorney Motorsport)
    Dyno Conditions: Bit chilly, done in February
    Gear Dynoed: 3rd
    Peak HP: 271 @ Wheels
    Peak Torque: 290ft/lb
    Not sure how to upload pdf's to this site but the graphs can be found here:
    http://www.m3forum.net/m3forum/showt...=21826&page=27
    post 270
    and here:
    http://www.bmwowner.com/forum/viewto...sd=a&start=255
    Bottom of page 18
  3. #278
    Jan 2005
    Minneapolis, MN
    '99 E36 M3
    Quote Originally Posted by GG///M3 View Post
    Has only ever dyno'd there car in 5th gear?
    All the time. 4th gear pulls are most typical when tuning your car, but I always do a few 5th gear pulls too.
  4. #279
    Jun 2006
    croatia
    BMW m3 e36 1994
    M3 E36 3.0 euro after installing supersprint 784302 decat
    [ame]http://www.youtube.com/watch?v=8F8KIXImWyk[/ame]
    http://www.youtube.com/watch?v=Ocrvaw3d4UM Dont drive over limited speed!!! Drive safely......
  5. #280
    Jun 2006
    croatia
    BMW m3 e36 1994
    Quote Originally Posted by crionna View Post
    Thanks.
    in croatia 40$
  6. #281
    The slum
    95 M3
    ^ you have a 24% drivetrain loss? Thats too much. You should be 243-249 rwhp, have you checked your engine compression, Checked for leaks, or replaced fuel filter?
  7. #282
    Jun 2006
    croatia
    BMW m3 e36 1994
    Quote Originally Posted by ptldM3 View Post
    why you think that engine compression or leak is in connection with drivetrain loose? this no make sense. fuel filter is new.
  8. #283
    The slum
    95 M3
    Quote Originally Posted by foler View Post
    Well your numbers do seem low im not sure if it's possible to have that kind of drive train loss, makes me wounder how accurate that dyno is. I only asked how your compression was because of your low numbers. Stock us spec M3 can put down as much as 217 whp most will put down around 200-209 whp some less so i would think a Euro would put more than that.
  9. #284
    Jun 2006
    croatia
    BMW m3 e36 1994
    maybe is your dyno wrong???????????? maha lps 3000 is high rated dyno machine and porche, vw using it. here is correction factor din 70020 which is used when car is produced. maybe newer correction standards have stronger tolerances.
    http://www.maha.de/en/2193.asp
  10. #285
    SATX, USSA
    ESS 625++
    That's not bad, wasn't stock about 286 or so?
    ESS 625
    RAGE AGAINST THE MACHINE
  11. #286
    Victoria, BC
    1999 M3 Evolution
    S50B32 engine from a 1998 MZ3 Roadster
    JC 3.5" CAI, HIOP DME tuning
    4th gear dyno at sea level
    temp. 60F
    The red lines are the stock numbers (261.8hp and 229.5ft-lbs) before the chip tuning.
  12. #287
    Feb 2008
    Costa Mesa
    06 Z4MR
    with a bad wheel bearing, sae corrected smoothing 5 on a dynojet dyno
    mods: dinan CAI, dinan throttle body, no name exhaust, dinan stage 3 tune
    06 silbergrau Z4MR
  13. #288
    Jun 2001
    NJ
    '01 M5 '82 320i
    Year: 1995
    Build Date: 06/1994
    Mods: VF-Supercharger Kit 6psi, AA Gen III cat back exhaust
    Dyno Type: DynoJet
    Dyno Conditions: 64 Degrees 55% Humidity
    Gear Dynoed: 4th
    Peak HP: 302.62
    Peak Torque: 256.65
  14. #289
    Jun 2001
    NJ
    '01 M5 '82 320i
    Thanks.
    Cost me $75 for three runs...
  15. #290
    Corcoran, MN
    98M3 LSX swap w/boost
    Year: 1998 ///M3/4/5 w/ 198k miles
    Build Date: 10/97
    Mods: cai, m50, cat back, ported head, stock cams and pistons
    Dyno Type: mustang
    Dyno Conditions: 70 degs
    Gear Dynoed: 4th
    Peak HP: 257rwhp
    Peak Torque: 244
    From what I have heard on other bmw forums this is the highest output stock cammed e36 m3 around 13.3 @ 102 in the 1/4 @ full weight
  16. #291
    Jun 2001
    NJ
    '01 M5 '82 320i
    Quote Originally Posted by FAST98 View Post
    Build Date: 10/97
    Dyno Type: mustang
    Gear Dynoed: 4th
    Peak HP: 257rwhp
    Peak Torque: 244
    Where's your dyno sheet?
  17. #292
    Z3speed4me's Avatar
    Z3speed4me is offline Coupe Cartel Forever! BMW CCA Member
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    i dont see how you got 257 on a mustang for that matter, with not much of anything done... you sure everything was calibrated properly
    i would like to see the sheet for certain
    ~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
  18. #293
    Corcoran, MN
    Quote Originally Posted by Z3speed4me View Post
    I will go get it re dynoed again as i dont know where the sheet is after my move but i have it posted somewhere on www.m3forum.net
    There are some additional things that are done to this car as well, 1mm oversized valves, solid lifter conversion, titanium retainers, ported and polished head, radius cut valves, ect... All in all it was a $4500 head build
    The car is tuned to run on e-85 so timing can be bumped way up.
    For anyone that doesnt belive in the mean time lets go race, im always down for some racing
  19. #294
    Jun 2001
    NJ
    '01 M5 '82 320i
    Too bad that the non-believers are in NJ, like 1000 miles away!
    Seriously though, I didn't realize you had all that head work done. That sounds pretty cool. You have a place out there that specializes in BMW engines?
  20. #295
    Z3speed4me's Avatar
    Apr 2002
    Westfield, NJ
    MCoupe, Q3, Tiguan
    now that i see you have head work.... my speculation went down the drain
  21. #296
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    Year: 1995 w/ 97 S52 OBDI (65k)
    Build Date: 9/94
    Mods: Full OBDI conversion, M50, 3.5" HFM, stock 21.5 injectors, CAI, AA Chip
    Dyno Type: Dynojet
    Dyno Conditions: 75F
    Gear Dynoed: 4th
    Peak HP: 225 rwhp
    Peak Torque: 221 lbft
    Tell me if you think this is dangerously lean at all:
    (I only have the lambda and AFR as a numeric list so I wont take a picture)
    Roughly:
    ~mid-low 15s until 3500
    ~high-mid 14s until 5000
    ~high 13s until 7000
    [2004 330xi/6] Orient/Natural :: 117-142k :: ZSP :: ZPP :: ZCW
    [1998 M3/4/5] Cosmos/Black :: 113-125k :: TCKline D/A (500/600) :: GC Plates :: RD Sways :: GC Rear Arms :: ZHP Rack :: 3.64 Diffsonline :: PF FCAB :: BW RTAB :: AKG Subframe :: TMS Pulleys :: AA & Borla :: XBrace :: TRM C2s :: BW lines :: DTC60 :: Safety Equipment
    Past:
    [1995 M3] Avus/Dove :: 141-242k :: S52 OBDI :: M50 manifold :: 3.5 HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport :: Z3 rack
    [1999 M3] Cosmos/Black :: 65-87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Safety Equipment
    [1993 325is] Brilliant/Black :: 135-139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
    [1983 320i] Safari/Brownish :: 219-242k :: homebrew CAI :: some rust :: multicolor body panels
  22. #297
    Jun 2001
    NJ
    '01 M5 '82 320i
    Cool
    I think you need bigger injectors..24# and maybe a retune...but then again, what do I know?
  23. #298
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    I agree with the 24#. I was somewhat surprised to see they were still 21.5.
    Might be nice to have some fun with 24s and the new Conforti setup... birthday is in a month
    Past:
  24. #299
    Corcoran, MN
    In my opinion 24# are a wast till you hit 290rwhp, im still running the 21.5's and im running e-85 so they are just about maxed out but still can make a little more power with them.
  25. #300
    Jun 2001
    NJ
    '01 M5 '82 320i
    Well, if that's the case, perhaps he should contact AA to find out why the tune is causing the motor to run lean.
