if the image does not load i will change the location please be patient i am in the frigin middle east right now and this internet sucks)
98 Euro E36 M3 (ExSMG)/99 M3 Daily Driver/93 M3 (S54) TBD-hp/TBD-tq ) Current NASA track record holder TTD on street tires @ 3450lbs (Eagles Canyon 2:05.3, MSR-Houston 1:47.08)S52E36 TWS CCW 1:54.8, COTA 2:30.6 Race Lap 3yr old 245/40/18 Hankook Z214 C51)
You have some serious issues with that motor, such as a monstrous vacuum leak, engine wear, fouled plugs? It should pull 260+ whp in Shootout Mode. I just saw a 3.0 Euro motor (minor mods) pull 240+ whp at 7,400 rpm on a DD in Shootout Mode, so your larger motor with hotter factory cams defintely should be higher. Maybe a dyno error, but those machines are mostly bulletproof I hear.
Better yet, send that motor over the pond to me for, ummm...diagnosis....
Well guys I think im going to try and straighten out this conforti intake kit thing. I have a 95 s50 freshly rebuilt head valves, seals, head gasket the whole thing. Longtube headers, uuc u system catback. Im getting ready to install the conforti stage 2 intake system so im going to see what kind of numbers it will put down. Do you think that since I rebuilt my haed it will make a diffrence??
What do you all think my car will dyno at with a fresh built head (P&P, 3 angle valve job all new gaskets) and the schrick cam kit. I was thinking 240-250whp. We will see. Anybody want to take bets?
Ha thanks. I'll make sure to make it over 240whp.
Mods AA trackpipe 214whp, and about 200wtq. I was told the correction factor was alittle off. It should have made another 5-8whp. The Shop also only had 1 fan pulling on the car, in between the rad and the fog light.http://forums.bimmerforums.com/forum...d.php?t=801132
― George Orwell
Year: 1999
Build Date: 01/1999
Mods: M50 Intake Manifold, Conforti 3.5" CAI, AA Software, 3.5" HFM (unplugged), Fan Delete, Strömung Exhaust, UUC Stg2 Ltw Flywheel w/ Stg1 Clutch, AA Track Pipe
Dyno Type: Dynojet 248C
Dyno Conditions: 85 degrees
Gear Dynoed: 4th
Peak HP: 242rwhp (SAE Corrected)
Peak Torque: 232 rwtq (SAE Corrected)
compared to stock ( http://forums.bimmerforums.com/forum...80&postcount=9 ):
videos of the runs:
dyno vid 1 (18mb)
dyno vid 2 (4.4mb)
dyno vid 3 (4.4mb)
I have made another thread for any comments/questions on my results, please post there instead of here. the dynojet files are also available there. that thread is here: http://forums.bimmerforums.com/forum...d.php?t=801802
UUC EVO III SSK | M50 Intake Manifold | Conforti 3.5" CAI | AA Software | 3.5" HFM (unplugged)
Fan Delete | Strömung Exhaust | UUC Stg2 Ltw Flywheel | X-Brace | AA Track Pipe | 3.46 Differential
1/4 mile: 13.3@104.2mph; 8.6 in 1/8; 2.04 60' | Best 1/8 mile: 8.3@83mph; 1.81 60'
Dyno: 242rwhp/232rwtq SOLD
Year: 1995
Build Date: 08 / 95
Mods: Dinan St. 1 Chip, AA Track Pipe, UUC Sys. U Ex., Cosmo CAI
Dyno Type: Dynojet
Dyno Conditions: 92 Deg. / 36% Humidity / 29.x mmHg
Gear Dynoed: 4th (Blue Line) / 3rd (Red Line)
Peak HP: 217
Peak Torque: 204
A little under what I expected, but oh well. Correction factor was 1.05
95 m3. 8/94 build. JC intake, 3.5 HFM, turner tuning, 24lb injectors, borla track pipe, AA Gen 3
224.95 / 206.31
227.02 / 204.84
96 degrees outside!
'95 M3, 04/94 build, 117K miles
Max HP-209
Max TQ-199
Mods- TMS Chip
93 octane, 96.5 degrees, 29.39 in-Hg, 29% humidity
STD Correction Factor: 1.05
Video footage courtesy of loonibab///M3:
http://www.e36-tech.com/dynoday/reborn.AVI
Year: 1997
Mods: See sig
Dyno Type: Dynojet
Dyno Conditions: 103 degrees, dont remember the rest, very humid
Gear Dynoed: 3rd and 4th
Peak HP: 4th gear pull, 242rwhp
Peak Torque: 4th gear pull (same pull as above) 226 rwtq
Just redyno'd my 95 m3 with the following mods; 21.5 lbs injectors, cosmosracing intake 3.5 inch, 540 hfm, AA trackpipe, and a AA tune for all the mods including the trackpipe(7,300rpm new redline). 229whp, and 212wtq. Stock with just a trackpipe it made 214whp, and 200wtq. Here's a link to the thread http://forums.bimmerforums.com/forum...6#post10453616. I cant get my dyno sheet uploaded. BTw; i think this shows 21.5 lbs injectors make more tq then the 24lbs injectors.
― George Orwell
Year: 1998
Build Date: 05/1998
Mods: Conforti CF Intake, Eisenmann Race Exhaust, ASC Delete, & Mobil 1 93 Fuel
Dyno Type: Dynojet 424x Chassis Dyno
Dyno Conditions: 88.64 degrees F, Humidity 32%, 30.24in-Hg
Gear Dynoed: 4th Gear
Peak HP: 228.19whp (SAE Corrected)
Peak Torque: 228.70wtq (SAE Corrected)
Mike... aka Track Junkie
'98.5 M3 Coupe Titan Silver
autotragic, intake filter, euro hfm, dinan TB, ASC delete, fan delete, UUC tse
that automatic just rapes it, ill go back after the 5 speed swap. we think i can get another 10 with that. which would be nice.
this is what happens when you dyno an autotragic lol :
that was the first run, we did in drive and it was a pig the whole way. discovered manual mode and made it MUCH smoother. obviously everyone i know is getting the second one
Might as well post my dyno #'s from another auto, mods in sig. First 2 pulls were in 3rd gear and third pull done in 4th gear which got the highest hp/tq readings.
Hella EURO XENON Angel Eye Headlights
ASC delete/Samco elbow
3.91 LSD
Dinan Transmission chip
UUC RSC36 exhaust
HP 208/TQ 203
Year: 1995
Build Date: 08/1995
Mods: Dinan Exhaust, 3.5 HFM, 3.5 intake w/ heatshield, TMS chip, Samco 3.5- 3" reducer
Dyno Type: Dynojet
Dyno Conditions: 78.4 degrees F, Humidity 71%, 29.83 in-hg
Peak HP: 227.35(SAE Corrected)
Peak Torque: 218.45wtq (SAE Corrected)
charts coming soon
-Garret -
95 M3 Dinan Exhaust, TMS chip, 540i HFM, Conforti CAI, Bilstein f/r, Depo 6k HIDs, Clear Corners/Turns, 18" CSL wheels, MTech pedals, ZHP shiftknob - 227whp 218 wtq
Previous -
02 SVT Focus AEM intake, SCT software, CFM big bore throttle body, CFM engine/trans mounts, MSD Ignition, Steeda SSK, CFM polymounts SOLD
93 Corrado SLC all motor VR6 - Race-Shop Big Valve Head/Ported Manifolds, Schrick 268 cams, Mk4 headgasket, Turn2 CAI/Underdrive pulleys/Stg. 3 engine mounts, Techtonics chip, Borla Exhaust, Dieselgeek shift kit, Carbon fiber hood, Schroth 4 pt harness, 16x7 Borbet Type E, Biltstein/H&R - SOLD
I had done a dyno test before I turbocharged my European version of M3:
Year: 1993
Build date: 07/1993
Engine: European version of S50B30
Mods: stock engine except for SuperSprint front exhaust without catalytic converter
Peak HP: 283.1 HP
Peak Torque: 314.4 Nm
first time dyno today.
Year: 1998 (automagic)
Mods: AFE intake (dirty filter), Shark chip, Catback. 72,XXX miles
Dyno: Dynojet
Conditions: 91.53F humidity 31%
Gear Dyno'd: 3rd
Peak HP: 207.11
Peak TQ: 195.12
Doe these numbers seem about right to you guys? i was hoping for a little more. the car runs great and pulls hard, so i still love it. but these numbers seem a little low to my noobness.
whithin the month when i dyno next i should have a recharged filter, AA race headers and the AA track pipe. how much of a difference will these mods make?
New dyno:
97 M3
Rebuilt IP Race engine with OBDII Sunbelt cams/full Ferrea valvetrain
Stock headers to AA Track Pipe to B&B Tri-Flo
Diffsonline 3.64 with polished gears
Chris
Thanks!
The tuning is Bimmerworld OBDII "remote" tuning, second try. The first/default flash ran to 7400 RPM and that did not work out so well for the engine. After the rebuild, Bimmerworld received my ECU with my old dyno and A/F, adjusted accordingly, and reset my limiter to 7200 RPM. I do not know who Bimmerworld uses, but they pretty much nailed it this time around.
Unfortunately, I am unsure which injectors I am running. It is something that I can find out though!
Chris
Sorry if my stuff isn't very detailed.
Year: 1999
Mods:
-Schrick Cams 264 Intake, 256 Exhaust
-Conforti Software
-Conforti 3.5" Carbon Fiber Cold-Air Intake
-ITG Foam Filter
-TMS HP High-Flow Mass Air Meter
-24LB Bosch Fuel Injectors
-UUC Power Pullies
-M50 Intake Manifold
-Active Autowerke Long headers/custom race-cat mid-pipe/ Gen III cat-back
-Denso Iridium IK22 plugs (Not installed for the dyno session) I wonder if it will make a difference?
-E39 M5 Blue Water Metallic Paint
-M3 Lightweight Carbon Fiber Interior
-ACShnitzer Pedals
-LeatherZ M-tech Shift Knob
-Alcantra Leather Shift boot and E-brake boot
-Carbon Fiber front lip
-ZKW Projectors w/ ProLumen HID and UmNitza Angel Eyes
-Ground Control Coilover Suspension
-Koni Yellow Adjustable Shocks
-TMS Sway Bar Set
-Rear-Trailing Arms
-Front Strut Bar
-E46 Rear Shock Mounts w/MZ3 Reinforcers
-TMS Stainless Brake Lines
-Brembo Gas-Slotted Rotors
-Axxis Metal Master Pads
-UUC Short Shift Kit
-UUC Double Shear Selector Rod
Dyno Type: Dyno Dynamics
Dyno Conditions: Hot Mid-August summer day in Dulles, Virginia
Gear Dynoed: No idea.
Peak HP: 253
Peak Torque: ~230
Year: 1993
Build date: 06/1993
Engine: European version S50B30
Mods: intake manifold,alpha n chips
Peak HP: 322,7 HP / flywheel
Peak Torque: 336,8 Nm / flywheel
Dyno: maha lps3000
Best regards
Sami
There's a lot of nice dyno's in here! Good stuff!
'00 Honda S2000 - I/E/H, VAFC2, Exedy Clutch/Flywheel, Carbon Fiber Driveshaft, Rick's 4.57R's, Hondata IMG, AEM Fuel rail and FPR, a few other fine Spoon Products to go along with some weight reduction (~2650-2675lbs - No driver) and all the fuel I need...Best Stock 1/4 mile time, 13.71@101.83, 1.9 60ft. Best time to date - 13.14@107.23 - AEM EMS on the way. Looking for high 12's N/A.
'09 Infiniti G37s Coupe - 6 speed - Best time stock - 13.51@105.07, 2.0 60ft.
'04 Infiniti G35 Coupe - Sold - 6 speed - Sports Package with Brembo's, Best time with CAI - 13.81@102.68, 2.0 60ft.
