If it still has the stock 95 midpipe you're losing an easy 20+ hp. Especially with all the other mods on the car. Going to even some cheap headers (euro supersprint reps or similar) and a 3" exhaust on a car with as many mods as you've already got would probably be closer to 30whp up top.
Chris
97 M3
94 325is
12 Jeep SRT8
1995 M3
S54 swap (CA-legal), ~71k miles
5 speed trans + 3.15 diff (long gears are long)
Stock S54 US headers/Cats
Stock Z3M air intake
Factory tune
Bimmerworld Y-pipe + Active Auto 3" Race Exhaust
JB Racing 10lb flywheel + clutchmasters clutch
287/241 whp/wtq. I am a little bummed that the dyno operator didn't go below 4k, but....some data is better than no data!
SAE and AFR vs RPM. Lots of room for improvement!
S54 above vs prior S50 (Turner Shorty headers, 3" AA Race exhaust, TRM tune + 21.5lb injectors, 3.5" intake, BW boot, LTW fly)
Zoomed of same:
Good baseline. Now time for mods.
"Fear disturbs your concentration" -Sabine Schmit
1995 BMW M3/2/5-- S54 + Mk60 DSC, California Smog Legal (Build Thread)
1998 BMW M3/4/5 Alpine/Modena, Z3 Rack, otherwise stock-- DD without burbles
2017 Chevy SS, Orange Blast Metallic, 6MT -- DD with burbles
I thought I should finally update this after installing the S52.
Build Date: 10/94
BSP Legal S52
Mods:
- aFe 'Euro' Cold Air Intake
- Euro 3.5" Bosch HFM / Mass Air Sensor
- 3.5" BW Silicone Throttle Body Boot
- STOCK Throttle Body
- 21.5lb Fuel Injectors
- VAC Stage 1 Cylinder Head
- TMS Performance Chip
- TMS Power Pulley Kit
- Fan Delete
- Raceland Euro Headers with Custom Exhaust
- JBR Aluminum Flywheel
Date: June 13, 2015
Dyno Type: DynoJet (Carb Connection - Kirkland, WA)
Dyno Conditions: Temperature 69 °F, Humidity 49%
Gear Dynoed: 4th with 3.38 Differential
Peak HP: 233.37 SAE
Peak Torque: 222.45 SAE
Finally got my 'new to me' E36 dyno'd.
Build Date: 12/96
E36 M3/4/6 (swap from E46 M3)
Mods:
- aFe Dry Intake
- Porsche 803 3.5" MAF
- 3.5" BimmerWorld Intake Boot
- Bored Throttle Body
- M50 Manifold
- 24lb Fuel Injectors
- TRM OTS Tuned ECU
- Fan Delete
- JP Shorty Headers
- Lightweight Flywheel
- Racing Dynamics Axleback Exhaust
Date: October 8, 2016
Dyno Type: DynoJet (BPC Raleigh, NC)
Dyno Conditions: 70 °F, Raining
Gear Dynoed: 4th with 3.73 Differential
Peak HP: 240.82 SAE
Peak Torque: 232.17 SAE
Year: 1997
Build Date: 4/97
Mods: Remus Cat-Back, Electric Fan conversion, possible tune (unknown by previous owner)
Dyno Type: Dynocom AWD 5000
Dyno Conditions: 64F, 23% Humidity
Gear Dynoed: 5th with 3.23 diff
Peak HP: 222.2whp (255.6bhp) @ 6400rpm
Peak Torque: 207.2ftlbs (238.3ftlbs engine torque)@ 4200rpm
Not sure if these are SAE numbers or how accurate the engine hp/tq estimation is (first time at the dyno). Saw that the printout contains a CF (correction factor?) of 1.00, but I'm not sure if that means it's a true hp representation or if it wasn't adjusted.
Not sure how accurate the reading is but if it's at least close I'm pretty happy that I haven't lost too many ponies over the course of almost 20 years
20161125_194921 by [url=https://www.flickr.com/photos/139048655@N07/]
Sure did lol, fixed.
Dyno chart is here: http://imgur.com/W8dBdFZ
232whp/216wtq
Power mods are:
Cosmos 3.5" intake
ASC delete
M50 manifold
Becker long-tube headers
Modified midpipe/stock cats
B&B Triflo catback
Markert Motor Works dyno tune
Needless to say, I'm a very happy man. The car now makes as much or more power from 5500-7000rpm than it did at its peak of 6500rpm pre-tune. And keep in mind, this tune was applied after the DME had 150+ miles to get used to the M50 manifold and headers, so realistically it probably jumped from 215ish to 235ish with the manifolds and the tune.
I'm really curious to see what I could make at the top end with no cats... but I like being street-legal.
'96 M3 - M50 Manifold - Markert Motor Works Tune - Becker Headers - Cosmos CAI - ASC Delete - B&B Triflo Exhaust - Carbotech XP24 Pads
SS Brake Lines - Understeer SSK - BBS RX204 - Turner Fuel Pump Upgrade - Schroth Harnesses - Fluidyne Radiator
Samco Hoses - Stewart HFWP - Ebay Strut Bar - Meyle Bushings - Brey-Krause Harness Bar - Ground Control Coilovers & Camber Plates - UUC front sway - X-brace
Turner Adjustable End-Links - Euro 3-spoke Steering Wheel - Braum Racing Venom seats and 5-pt SFI Harnesses
240whp/220wtq
So just gut them and weld the heat shields back on 😇
The older i get, the faster i was !
As is the fact that what must be wild cams are making 235 lbs at 2750 rpm and peaking at 287 lbs. This is exceptional based on everything I have read over the past decade about modding these motors, but img knows what he is doing so I would enjoy reading about how he is achieving these results.
Thank you !
Riot racing BBTB, might try the bimmerworld for fun. Cams have been sitting in the shelf for over 3 years. They were ordered by my business partner who built the motor and never got around to installing them.
Thank you !
i will do a write up at some point if I can remember all the details. Engine was built back in 2003 and has over 150k since the build but always made power.
I'm about to switch to a VAC75mm from my RRBBTB to see if the top end pics up at all. I'm also about to receive my custom header build from Zack at 22RPD.com. I'd be VERRYYY interested in cam info. I'm down 200cc from your motor, but if I could see another 20ft/lbs+ in the lower rev range, I'd be all over that! Is the motor solid lifter or still hydraulic?
1998 s52 190xxxx miles
Mods:
M50 mani
24lb injector
Dinan cold air intake
803 maf
Fan delete
Bbtb riot racing
Ebay headers
Cat delete
Rouge engineering exhaust
Rk tunes
SAE corrected
237 whp
222 wtq
unfortunately jordan said his dyno is reading low due to him not being to recalculate the weight of the roller
but the car feels amazing no complaints
1998 M3
108,xxx miles
S52
Dinan CF 3.5" intake
Stock MAF
ASC delete, otherwise stock throttle body
M50 Intake
Unknown long tube headers
Bimmerworld conversion pipe
AA track pipe
AA Gen3 exhaust
Epic Motorsports tune
Stock cams
UUC underdrive pullies
Dynojet, corrected for altitiude, dyno done at 6000ft above sea level
236.41 rwhp, 227.80 wheel torque
'03 911 Turbo 6MT fun car
'18 Toyota Land Cruiser Daily driver/Ski Machine/Off Roader
'15 Cayenne Diesel Wife's DD
'17 KTM 690 "Adv" 2 wheeled Adventurer
I have been waiting years to post onto this section... I have read, I have guessed, I have hoped.. Quick introduction before I get to my numbers. I recently graduated college and have had my 98 m3 since the start of college and have always dreamed of making more power and throwing it on the dyno. Turns out, all I needed to do was money shift and bend all the exhaust valves (plus a job to make money and then throw it all into the car of course!). But to do this, I had to sit and wait 5 months to have the money to throw at this thing. And simply put, I am a very happy camper! The car is a beast and the tuning done by Dave Markert at Markert Motorworks in Atlanta was solid. So here are the mods and numbers!
(I'm going to post this and update with videos and dyno graphs as I get them loaded!)
Year:
-1998 M3/2/5
Build Date:
-4/98
Mods:
-K&N Filter
-3" Autozone 45' elbow
-stock MAF
-3" silicon elbow
-stock throttle body
-Schrick 276/270 cams
-Supertech Springs
-Raceland Headers to custom 3" exhaust w/ Vibrant Resonator and straight through muffler
-Markert Motorworks tune
-Fidanza? Flywheel to stock clutch
Dyno Type:
-DynoJet
Dyno Conditions:
-83 F
-37.x Humidity
-600ft of elevation
Gear Dynoed:
-4th
Peak HP:
-263.99whp
Peak TQ:
-239.75wtq
Note that these numbers were achieved with the stock MAF maxing out at 6k rpm and then tuning the gap between 6k-7.2k rpm. With a euro MAF, 3.5" intake, and BBTB, I'm hoping for 5-10whp more than this!
Also, Dave was able to tune in launch control and burble tune (just for fun and can be turned off and on). Videos to come!
Graph:
Exhaust Clip:
https://youtu.be/eNFeWX7DECU
Burble Tune Exhaust:
https://youtu.be/w4fmp6H5iHA
Launch Control Video:
https://youtu.be/47avLEhO-zQ
Current:
1998 US m3 coupe.. Home-made Short Ram Intake with heat shield, BMW Factory X-Brace, Eibach Prokit Springs, Whiteline Front Swaybar, Sparco Front Strut Bar, Depo Headlights, Raceland Headers to full 3" with Vibrant Resonator & Muffler, m50 manifold, Markert Motor Works Custom Tune, Schrick 276/270, supertech springs, 24 lb injectors, all sitting on square Style 42s.
264whp/239wtq
Sold:
1995 E34 525i ($400 daily)
Seems like a few suspicious things being omitted. It's definitely not a 3.2L engine you dont make that torque from 3.2l with those specs. The s54 requires a built stroker 3.4/3.5L custom cams or not . Also with only 24lb injectors must be running them at higher pressure than stock ?
