Sometimes it's worth fixing the problem instead of just covering it up.
it's not a problem, dumbass.Originally Posted by Ben Carufel
173rd ABN
-12/14/2005
Originally Posted by e36bokes
Yes, it is; It's a problem that the light is stuck on.
If I were to buy an E30 advertised as no problems, repalace bulbs in the instrument cluster as regular maintenance, and find that the brake light warning bulb had been removed because it was faulty, I would be pissed.
ben, had you not replaced the SI board in that car yet?
if its not fixed once replacing the sensors, then the problem should be either low battery (on the SI), corroded battery contacts, or some other problem on that board that is possible too.
i had the same issue, replaced sensors which didnt fix it and changed the board to the new version and all good.
Exactly
Funny how a lot of us e30 guys have barely any pads left.
Pads are fine; SI board is brand new.
Still get a brake lining light.
ditto on the problem. i was gonna go the route of getting rid of the bulb, but it really doesnt bother me that much. it will eventually go out just like how the ABS light died about a year ago after being on since '90. like bokes said, you dont need a computer to tell you that your pads are low.
the brake lining light doesn't cause the "check" engine light to blink does it?
I think the brake pad wear sensor falls under the "good design idea" but "bad design implementation" category! Or maybe BMW likes to sell brake jobs!
ok...pull the insturment cluster out, and ditch the light; what does this equal? NO MORE BRAKE LINING LIGHT!!!! Simple as that.
I simply disconnected the sensor....actually I cut the wire off and that took care of the light. I didn't need the sensors, since I flush my system twice a year and check my pads visually once a month when I change my tires for autox. All that sensor will tell you is your pads are worn. However, I guess if you don't flush your system or physically check your pads, then you need it.
My brake pad lining light doesn't come on!
But on the other hand, my "low beam" warning light sometimes comes on, and I know all the lights are good. oh well.
Hi chaps I had this issue with one of my e30's. It had low pads so I replaced them AND the sensors. All good for a few miles then the light came back on. So back to the sensors and found the problem. Because the pads were worn so were the rotors, they had small ridge on the outside of the rotor which after turning a few times had worn through the wire end of sensor pad enough to set the bulb off again. I would of course never do this but out came the grinder and very carefully ground of that lip which was only about 0.5-1.0mm. Placed blob of superglue over the small wear mark on the sensor, problem solved. It should be remembered that at every second pad change the rotors should be changed as well.
It along with most of the overhead check panel are worthless... For people not afraid to pull the dipstick, rotate regularly and get visuals on everything. God forbid any of you others swapped any builds to LED Hahaha.
I'm looking at replacing my overhead panel with something a little more useful
You can take out tons of wiring and the car will still run. Just open the harness cover and cut out the wires you no longer want
No e30s again.
Superj, do you mean the overhead harness? When those warning sensors light up they also turn on the flashing light in your instrument cluster. So if you cut those wires will the flashing light still go on and then how do you turn off the flashing light, that button is wired to the overhead unit? Some of the sensors give warnings on an closed circuit and some on an open circuit, is that a problem?
Sorry, i was talking about the whole car harness. I took out power window wires, power sunroof wires, idle control system, all kinds of stuff. I didn't mess with overhead check panel, other than move it to the floor next to where i remounted the ecu.
So i am not sure about that overhead panel but since the car still runs when you unplug it, i imagine you can delete it. Try driving without it and see if your check light flashes on the gage cluster.
And this was not on the current cars. It was one were using for the lightest e30 thread, back in the day.
No e30s again.
dammit.... i have tried 2 times to fix the solder points on the brake lining resistor, and it still does it. Thinking of just pulling the bulb out, but my ocd wants to fix this also....
anyone have a picture of the solder points of this resistor? I followed the e30 wiki for pics, and now wondering if i got the correct ones.
1987 BMW 325i Convertible
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Jeremy Clarkson
none of your sensor wires under the car are worn through by abrasion or some other reason?
No e30s again.
no.. brand new. maybe 300 miles on them. Brakes are completely new.
Jeremy Clarkson
ok... took the cluster out AGAIN and went through and reflowed the solder on the connections around the temp gauge. We will see if that finally works. I have to order new handle for passenger door first. yay
Jeremy Clarkson
well it seems to have worked this time... i panicked when i got it together and the tach wasnt working. Turned out that i had a fuse not plugged in completely. *whew*. I hope this is the last time to have to do this.
Jeremy Clarkson
Hey doc..can u supply a pic of which solder joint you re did to get the lining light to go out. I know mine is the issue. I tap the cluster and goes out and comes back on..thanks
