- door panel HELP...
door panel HELP...
how do I take the rear door panel off? (97 4dr M3 )
pls help....
Rear Door Panel removal
From Bentley page 411-4
Open door and pry out power window switch, disconnect harness connector
Remove ash tray
Pry off trim cover from inside door handle
Pry off concealing plugs from armrest. Remove door panel retaining screws
Unscrew door locking knob
Unclip panel from door perimeter starting at the top of the door
My experience is that you may break a few clips so be sure to get new ones. They want you to go from the top of the door else you will deform the door if starting at the bottom and it will not fit well
Good Luck
- You may not post replies
- You may not edit your posts
Forum Rules
