You must not have the item bushings then cause they have a flange...
To answer your question that's probably what I would do is press the bushing in so its flush as you said with the carrier on each side just put it in like the ones that are already in there... Take some pics would like to see what you end up doing good luck...
Lee
Ya I'm going to press them In so they're centred in the housing - a little edge on each side showing
Funny because when I removed them last night, one was pressed in so the edge so it was flush on one side and the other had all the extra hanging out. The bushing casing was cracked badly once I removed it. The other rtab which was centred, no crack. Maybe a coincidence but I'm going to centre them
For anyone trying to remove the RTAB, google the diy subframe bushing tool. You can pull these out with the same tool. No yelling no sawzal no swearing, 2 minutes per side and out
- Jeff
I like the idea of the subframe tool however at the time I was a grad student and could not afford the special tools hence I wrote up this DIY "without special tools" but agreed looking back and now where I am in life if I had to do it myself id buy the tool, however i just pay people to do it for me now because I don't have time to get my hands dirty anymore.
Glad it worked out for ya
Lee
