Bavarian Soundwerks
Results 1 to 9 of 9
Thread: Aftermarket radio harness for M Roadster & other questions
    Los Angeles
    2000 M Roadster
    1. I have a Pioneer radio I want to put in a 2000 M Roadster. Crutchfield has not researched the wiring harness plug for this car, but they do have one for a Z3. Anyone know if the wiring would be the same or know where to get one?
    2. Any special problems with the amps?
    3. I understand I'd also need the antenna adapter as well, but there seem to be several on different sites and I don't know which to pick. It looks like I have an amplified antenna.
    4. What do the radio removal tools look like for the existing BMW radio? Blunt or sharp angle?
    5. Any other out of the ordinary items I need to take into consideration before installing?
    Thanks.
    Jan 2005
    Oklahoma City
    s52 e30, e36Ms, e46M
    i woulkd assume that its the same harness as every bmw, they only have one aftermarket harness
    Los Angeles
    2000 M Roadster
    Ok, thanks. Found a wiring harness at Car Domain. Found out about the radio removal.
    Dec 2004
    Louisville, KY
    1997 BMW 328is, 1992 Isuzu Rodeo XS
    there's two bmw harnesses. one is like metra 99-8520 or something like that, which is for 1992-1999 three series i believe, and one is a HUGE 99-9001 or something like that for new bimmers and volkswagens.
    do you have a pic of your dash?? i haven't seen the dash on a 2000 m roadster, but if i see a pic i can tell you what kit it is.
    antenna adapter is probably gonna be like a met 40vw10 or met 40eu10 from metra.
    Alpine IVA-D300 * JL Audio VR6 Components * 12' Alpine Type R Subwoofer * Alpine MRP-F240 4 Channel Amplifier * Alpine MRD-M301 Mono Amplifier * Sirius Satellite Radio * Optima Yellow Top Battery * Bilstein Shocks * H&R Race Springs * 18 Inch OE Creations E46 M3 Replicas * Kumho MX 225/40/18 Tires * 5% Window Tint * UUC Shortshifter * more to come.....
    Jan 2005
    Oklahoma City
    how new of a bimmer and vw? just did a e46 i think it was an 01 and had the same harness has mine. dunno
    Greenville, SC
    '04 ZHP
    The huge harness may be the Logic 7 harness. Well, that's my best guess anyway.
    Rockin the woo WOOO exhaust!
    Oct 2003
    Cali
    Street Missile/Track Weapon
    It uses the same harness as the E36. I've swapped headunits from my 318 to my M Coupe and back before.
    Dec 2004
    Louisville, KY
    the package says 2002 and newer bimmers and volkswagens.
    http://audioetc1.com/product_info.ph...ucts_id/203483
    couldn't find a pic.
    Los Angeles
    2000 M Roadster
    Cardomain has a wiring harness they list as fitting my car so I'll probably get that one. I've asked them to try to figure out which antenna adapter will work because their listing is for one that works without an amplified one and mine is amplified.
