You can do a free rental of a spring compressor from Advance Auto (You buy it and return for full price when you're done). This is not slimy, it's their enticement for you to buy other stuff for your project from them. They do the same thing for alternator wrenches and some other less commonly used tools
Kelvin
Anyone willing to loan a fender roller in the Exton/ Downingtown/ Westchester area? I will be in the are until Sunday, let me know!
Does anyone have the subframe bushing tool for the e30 subframe? Need to replace the bushing in my M coupe.
Anyone in southern Maryland have an OBDII Peake Code Reader?
I'm throwing the P0420 code from a generic OBDII scanner but would like a more specific answer to what is causing it. I have emissions inspection coming up soon and would rather figure out the issue before that.
Toledo E53 X5 | LeMans E90 335d
1991 bmw 325I <e30>
First 8 second full body BMW with BMW independent rear suspension in the USA
8.69 @160mph in a 1/4mile on slicks.
drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
2003 Ford Expedition
1998 M3
1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
would anybody happen to have the tools needed to remove the fan clutch?
I'm pretty low on cash right now so hopefully I could borrow them for a few hours without much of a charge.
Yeah, I have them. I live over by UMBC. Drop me a PM if you want to borrow them
Thanks! I sent you a pm
Got the BavAuto version of the Peak tool that plugs in under the dash for OBDII, but I'm up by BWI airport
I could make a trip up that way this week to get it read. Possibly meet you somewhere. You ever do any traveling south of Baltimore?
Looking to have my airbag light reset. Don't mind driving. Anyone out there have one?
Paul P.
1981 Camaro getting prepped for CP
I don't give "advise".
Help Stop Lung Cancer
Maryland's Premier Autocross Team
Hey all, I'm looking for two rear subframe bushing tools. One removes/installs the differential-to-subframe bushings and the other removes/installs the subframe-to-body bushings. I'm basically looking to replace everyone bushing you see here. E46 non-m rear subframe.
-Gary
Does anyone have the fan clutch tools for E36 M50 near West Chester, Pa? I have the 32mm wrench, I just need the tool to hold the pulley still. I keep snapping screwdrivers in half trying to do it without it...
I going to be redoing my head gasket soon. I need the cam locking tool, torx for the head bolts, and the little locking pin thingy. Any one have this stuff.
I have a peake code reader, ramps, jack stands, tools, and a garage to work in.
1969 GTO Warwick Blue/Parchment
2000 740i Sport 6 speed
Hi - I could use some help next weekend on a 1996 318ic if someone has the SRS scan tool near Vienna. I can pick it up within driving distance. Thanks
Bryant
RTAB tool near Tysons Corner?
Anyone near north east PA have the tools for removing the fan clutch? In particular, something to hold the water pump pully still. I could probably find the 32mm wrench on my own if I need to
Does anyone have an RTAB puller/press I can borrow in two weeks?
-Gary
Great, thanks for the heads up. I'll see if I can't get a hold of him to rent that tool.
-Gary
Does any one have a RTAB tool for rent that is near south Jersey?
