Page 13 of 13 FirstFirst ... 345678910111213
Results 301 to 315 of 315
Thread: MAR loaner tool thread
  1. #301
    Mar 2008
    USA
    F80 M3, 95 325is
    I have
    • B800 airbag code reader/ reset tool (only for years between 1994-2003)
    • OBD2 bluetooth dongle (works with torque app) for reading check engine code
    • 32mm fan clutch wrench and counter-holder
    • Motive Brake bleeder
    • ramps, 2.5 ton low profile jack
    Located near Towson, MD area
    Lazy Saturday drive in my E34: https://www.youtube.com/watch?v=TnzvZgPnOos
  2. #302
    Aug 2009
    Falls Church, VA
    E90 LCI M-Sport
    Eastwood fender roller
    Dewalt heat gun
    Motive power bleeder
    Spring compressors
    Jacks/stands
    Lots of other stuff
    RSI, LLC | Fender Rolling | Suspension | Engine | Other Stuff
  3. #303
    Jun 2014
    austin, tx, usa
    2003 bmw s
    re : MAR loaner tool thread
    right now i am also looking SRS tool for for my BMW X3 , i checked in lots of sites and store i didn't got it, so if know what is the best place for SRS tool. then let me know please. Eldersburg MD Locksmith
  4. #304
    Mar 2003
    DMV
    a car
    Hi, does anyone have an SRS code reader for a 92 and 96 E36 near Rockville that I could borrow?
    In terms of special tools, I have:
    Cam lock tool for M52 S52
    Stretch belt tool for E65
  5. #305
    Sep 2014
    maryland
    740il
    Looking to rent or buy OBDII scanner to diagnose a transmission "clunk" on an E38
    Would also like to check actual mileage since dash has burnt pixels
    Willing to rent or buy
    MoCo, NoVa, Harford County or Baltimore MD
    Also: I have ramps, jacks, compressor, stands and all kinds of hand and air tools and I'm available to lend a hand with a week's notice. I've done suspension, steering, head gasket, and exterior trim and lighting on E34, M60B40
    Cheers...thanks
  6. #306
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    I have a MOTIV brake bleeder and transmission drain/filler; I also have most tools needed to work on e30/e36 vehicles, OBD 2 scan tool....willing to help out in the Aberdeen, Bel Air, Abingdon, HDG areas
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
  7. #307
    Northern VA
    LSB E46 M3
    Looking to borrow rtab tool, differential mounts tools, and rear subframe bushings tool. Located in Northern Va.
    2002 M3 | ESS VT1-455 | BW Race Exhaust | Hawk Pads | Ground Control Suspension | Whiteline Swaybars
    Custom Roll Bar | Stripped Interior | Bride | G-Force | SneedSpeed Adjustable Rear Wing | Front Splitter
    SneedSpeed Brake Cooling Ducts | D-Force LTW5 Wheels/Hoosier R6
    Automotive Performance Technology, APTech - Follow us on Google+ or Facebook!
  8. #308
    Sep 2014
    Fairfax, Virginia
    1999 E36 M3 Coupe
    Looking to borrow a rtab tool, and also if someone here has access to a press I was wondering if you'd be able to help me press out my fcab's.
    Located in NoVA but don't mind driving.
    Thanks to much!
  9. #309
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    I have an RTAB tool in Arlington, VA. $80 deposit. $60 returned. So in the end $20 to rent it.
  10. #310
    Feb 2012
    Washington DC
    E46 325ci, E34 535IS
    Hey everyone. I am after a 32mm fan clutch wrench and counter-holder.
    I am based in DC. Need them asap due to failing oil filter housing seal.
    My E34 Race Car Build
  11. #311
    USA
    93' C38 S50, 00' GT28 A4
    Quote Originally Posted by Driftit View Post
    Are you still in need?
    93 E36 S50 c38 stg2
    00 B5 A4 GT2871r
    01 E46 325i - 343,782 (Stolen 3/2021) RIP
    2019 WRX
    auto->manual conversion crew / bf.c motor swap crew
  12. #312
    Chantilly, VA
    335i & 328ci
    Does anyone have for rent a transfer case mount tool? I think they are universal, however if not, looking for one that will fit the E46.
    -Gary
  13. #313
    Dec 2007
    McLean, VA
    1999 BMW 528it,2003 530M
  14. #314
    Aug 2021
    Virginia
    740il
    Anyone one have a certified scanner i can rent out or borrow 1999 740il manassas VA
  15. #315
    Laurel, MD
    1997 328i Sedan
    I am in urgent need of a rear wheel bearing tool. I think it is the B90K, that I need. The axle is already out. This is for a 1997 BMW 328i four door (E36). Clunks from the rear and with the wheel off the brake rotor and flange can be jiggled by hand in ways they should not jiggle. Can anyone help?
    I have a decent set of hand tools, some electric tools and most importantly a laptop with INPA that works on E30, E36 and E46 cars (and probably more). This is unfortunately necessary to really understand the myriad of ways these cars can soft-fail and even though it is necessary it is not enough. <sigh>
    UPDATE:
    I ordered this kit from Amazon that looks like a clone of the B90K.. https://www.amazon.com/dp/B08H82BZ8Y...roduct_details
    After receiving it, there are definitely plates that match the BMW rear wheel bearing and the thrust bearing looks really good too. We'll see if it lasts.
    - E36 328i black - Steel adjustable rear lower control arms, Bridgestone RE-11
    - E46 325ci white
