Does anyone have an SRS reset tool for an E90?
Anybody in the Hummelstown/Harrisburg area have a spring compressor or fender roller?
SLOWnSexy318: I have a spring compressor (this is the style: http://i.imgur.com/C0ZLs.jpg) and I'm in Mechanicsburg. You're welcome to borrow them, but I will tell you that stores like Autozone and Advance Auto Parts will rent them to you for free... (Put a deposit down, gets refunded when you return them.)
Anyone in the DC area have a B90 bearing remover/installer to rent or loan?
I need to replace my rear bearings asap.
If anyone needs a clutch alignment tool, cam shaft holding tool, vanos wrench tool, Peak engine reset/oil reset tool, and also a flywheel locking pin please PM. $150 down and $120 back.
Anyone with fender roller that I rent ????
PM me.
anybody have the 5th gear detent tools?
thanks
Kendrick
96 328i ITR Racecar
95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
2002 325XiT - daily
Anyone in the Mechanicsburg/Harrisburg with an engine hoist and engine stand for rent? I'm hoping to do some engine work this week or weekend if possible. Thanks!
Edit: I would consider an engine support bar as well!
I'm looking for a fender roller to borrow in the DC/MD/VA area. My zip is 20601. Anything less than an hour and I'm good.
Toledo E53 X5 | LeMans E90 335d
New guy here... just bought an E36 and it has the airbag light issue. Does anybody in the Richmond area have an SRS reset tool I could use? I'll come to you.
does anybody have the tools to do the fan clutch in the Baltimore area? I'll be able to pick them up sometime sunday.
You might need to replace the seat sensor or buy the dummy sensor online to reset the light. DAMHIK.Originally Posted by jrotola
2000 BMW 740iL | 225,XXX miles | VW MAF | Bavarian Auto Coils | Timing Chain and Guides DIY Complete | M60 Manifold | BDC Polished Throttle Body| Custom Tuned | Performance Gearing 3.46 LSD| Magnaflow mufflers |
|1997 ///M3/2/5 | 104,XXX miles | Boston Green Metallic|2006 X3 3.0 SAV|121,XXX miles| Silver|
I got:
fan clutch tools (32 mm wrench and counter-holder)- 60 deposit, you get all back when you return
time-cert kit (M14x1.25 extended kit 4412E ) to repair damaged spark plug ports.
$200 deposit, get 180 back when you return it.
Lazy Saturday drive in my E34: https://www.youtube.com/watch?v=TnzvZgPnOos
Poquoson/Hampton Roads area
DIS Machine
Peak FCXII
Vanos wrench
TDC Pin
M5 flywheel removal tool
Modified wrench for cam timing(won't hurt the head)
Head removal socket
Fan removal wrench.
Plus more, just ask!
Adam
- External spring compressors
- N54 thin-wall spark plug socket
- SRS scan tool for 1994-2002 cars (Peake R5/SRS)
- Engine code scan tool for 1987-2002 cars (Peak FCX3)
- Crapcan racing expertise
I'm in North Arlington. Feel free to email me, drew at <my username> dot net
Drew | Dinomite.net
1997 Boston Green ///M3 Coupe Lightweight wheels, non-luxury, no sunroof.
1994 Volvo 940 Race Wagon
Anyone in DC/MD/VA have a modified ball joint separator (~3" tall) that can remove a e39 v8 lower control arm?
Better yet, anyone got one of these "sawed off" pickle forks?
I'm in Alexandria...does anyone have a fan removal tool?
Does anyone have a fender roller or know someone who will do it?
wrong section.
Redline smoke pro, for smoke analysis..
In Herndon:
I have a peake tool that resets oil change and inspection light. No charge to use, just want to help fellow members.
Sport | M5 Headlights | M5 Style Front | Intake Resonator delete | H&R/Bilstein | Euro Armrest | M5 Rear Sway | Thule | 3-Pedals | Fully Maintained | 190K Daily Driven
