Page 1 of 13 1234567891011 ... LastLast
Results 1 to 25 of 315
Thread: MAR loaner tool thread
    Arlington, VA
    A few phone calls from fellow BFc'ers this weekend has inspired me to start this loaner tool thread. The idea will be to post what tools you have that you think others might need to borrow occasionally, and an approximate location where they can be picked up and returned to. If this thread gets big enough, I'll edit it (and get Preppy to help) and make this post for links to subthreads for the various metro areas within the MAR - Ballamore, Philly, DC, Middle Of Nowhere, etc.
    I'll start-I've got:
    pressure bleeder that's great for one-man brake and clutch bleeding
    Internal torx drivers in just about every size
    e10 and e12 external ratching Trox wrench (good for replacing window regulators on e39s)
    I've got other stuff too, but that's all I can think of for the unusual tools. My location is info above.
    DC
    323iT
    I've got a 37mm socket for the oil filter cap on newer BMWs.
    Jul 2002
    Strat Airlift
    88 M3's, 90 325i, 95 M3
    Peake R5-FCK reset tool
    Flair wrenchs
    Vanos Tool for cam hold down
    Cherry picker
    Typical variety of hand tools and air tools.
    Brake caliper tool.
    S14/S38 cam lift tool for shimming the head.
    Torque wrenches in inch/lbs and feet/lbs
    Nov 2002
    Maryland
    DSP E46 330Ci
    I have all the usual metric tools (5mm-26mm combo, metric and SAE flare, tons of sockets, crow's feet, etc etc). A couple interesting things that most folks might not have:
    Hammer driver / impact driver: This is essential for getting out stuck screws (such as brake rotor retainer screws)
    One-man brake bleeding setup (no pressure bleeder needed, just a one way valve and a catch can)
    Phoenix Injector (essential for bleeding and flushing BMW clutch hydraulics)
    Oxygen sensor tool
    Feeler gauges for spark plug gap / valve adjustment
    Manometers for synchronizing motorcycle carbs (non-mercury type)
    May 2003
    MD
    2010 335d
    I got a sawzall
    Actually, before this gets all out of whack, maybe someone can park it and have a single post that's editable and categorized.
    Aug 2001
    Ellicott City, MD/ York, PA
    332is, 95 M3
    Quote Originally Posted by jkuper
    I got a sawzall
    Jason, I went ahead and parked this thread and we will wait and see how this turns out.
    May 2001
    Denver, CO
    2013 335i xdrive msport
    Quote Originally Posted by Lance325is
    Holy crap, you're still alive....
    ~Chris
    Los Angeles
    E36, E6, G80
    I have:
    torque wrenches
    Victory RTAB tool
    tie rod puller
    compression tester
    2 ton press
    brake line pliers
    clutch alignment tools for most if not all BMWs
    fan clutch tools
    AutoEnginuity OBDII tool /w BMW enhancements (would appreciate any donations for use)
    I'm in the Philadelphia area
    1974 BMW 2002 Touring
    1996 Alpina B3 3.2 Touring
    1996 Alpina B8 4.6 Touring
    2023 BMW M3
    Aug 2001
    332is, 95 M3
    Quote Originally Posted by Preppy
    Yeah, schools been keeping me busy.
    Philly
    95 M3, '86 Grand Marquis
    I have the Victory RTAB Tool, in Philly suburbs.
    Also have an O2 sensor socket and a big arse 32 MM wrench I bought for the Fan Delete. Don't forsee using this anytime soon.
    Alexandria, VA
    Yes
    i have a BFH and i'm not afraid to use it
    James
    '88 M3 (track and weekends) | '01 540i/6 (daily) | '95 4Runner (lifted and armored)
    Harrisburg, PA
    1999 M3 Coupe
    I've got:
    All manner of wrenches, sockets, box ratchets, etc (including a 32mm combo for fan clutches)
    Spring compressor
    Flare wrenches
    One-man bleeder tube
    O2 sensor socket
    Lots of other miscellaneous stuff.
    Garage space for doing work if needed.
    I'm in Harrisburg, PA.
    Greg ///Martin
    The MAR: We're a drinking club with a BMW problem...
    Dec 2003
    cubical
    4 old ones
    R5/FCX-II Scan/Reset Tool for BMW
    Sparkplug torque extension
    Available in Germantown and club events
    Be nice if moderators kept on topic.
    ...steven BMWCCA 146825
    http://318ti.org | http://bmwcca.org/forum
    1995 318ti Club Sport - 1996 328ti Sport - 1991 325iC - 2003 Mini Cooper S
    Baltimore, MD
    TBSS, 90 348, 65 Mustang
    I've got a Torch!!!!
    Dec 2002
    Silver Spring, MD
    #199 IP BMWCCA
    fender roller... when not out on rental.
    Eric WONGer
    2012 NASA Nationals GTS3 First Loser
    EX-#121 IP/GTS3 M3 SOLD
    Now-#121 GTS3 E46 M3
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    Quote Originally Posted by Phat Ham
    Thats actually a 36. I have no prollem with anyone using any tool of mine for a weekend. however due to the high cost of the tools I would need a deposit. Oh yeah I have every tool anyone would ever need to use on a bmw.
    The Original GoldMember!!
    DC
    323iT
    Quote Originally Posted by Thewiseguy
    I'm sure you're right. Whatever the size it's the one you use for the oil filter cap. I also forgot to mention I have an R5/FCX-II-16.
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    O.T. hey chris whats going on with my sig?
    Nov 2002
    MD
    996, S13, E46 E36, C4
    If anyone needs the Craftsman Bolt-Out set to remove stripped bolts, let me know. I have the 10 pc set. Looks like this:
    Dec 2004
    Philadelphia
    1986 528e/2000 528i
    Anyone have the 46MM socket for a front wheel bearing retaining nut of an e28 front wheel hub assembly?
    thanks in advance!
    From eta to Vanos...and beyond!!!!
    Oct 2003
    Manassas, VA
    '95 silver M3 coupe
    I believe it is actually a 36 mm.
    Dec 2005
    stranger in a stange land
    1999 328ic, manual tranny
    I have 32mm fan delete wrench...Baltimore, MD.
    Dec 2005
    central pa
    '08 535xi
    flux core mig welder, compressor, and accompaning tools; ratchet, impact gun, cutting wheel, sand blaster, paint sprayers, metal sheers...
    i have a ton of tools.... to many to list.
    Jul 2003
    Arlington, VA
    1997 M3 Coupe
    I think that should be proper etiquette, as most of us only know each other through the internet; if I loan out tools, I would have the same stipulation.
    To the point, I'm in North Arlington and I have:
    Full wrench and socket set
    Ramps
    4 Jack stands
    2 floor jacks
    Vacuum bleeder
    Drew | Dinomite.net
    1997 Boston Green ///M3 Coupe Lightweight wheels, non-luxury, no sunroof.
    1994 Volvo 940 Race Wagon
    Dec 2005
    Arlington, VA
    Teh Bimmer
    I'm basically right in Tysons Corner and have:
    Top Side oil extractor
    Full socket set
    BMW sizes deep wall impact sockets
    all kinds of stuff for wiring misc parts (like headlights, AEs, 18 button OBC's (kill me.))
    The end is near.
