Awesome GIZMO! Now, the ferious-est m42 is on the road.
So! Can U list up all the mods done on your m42?
Because, U mixed so many stuffs around, ie, m42, m44, m47, s50, blaaaaaaar
awesome. btw gizmo, what have you done about the vibration damper? apparently they can sheer the nose off the crank at 7,200 rpm
Currently my rev limiter is set at 6800rpm. Once the cams+ITBs setup is in then I will spin her to +-7500rpm.
As for the damper, I have a spare damper that I must inspect and see what the big deal about the thing is, probably get a machine shop to built me a new solid billet aluminium one.
Amazing. I'll admit I was wondering if this was actually going to happen, but you've made a believer out of me. I can't wait to see the dyno charts for this thing once it gets tuned.
I call BS - there's no bmw driver that can't run his car faster than any magazine has ever done before.
-Joe
must admit i find all the hype over the vibration damper quite intriguing. have a spare m42 on its way to me soon which i'll take a look at. figure a solid pulley will probably resolve the issue, but want a better understanding of the purpose and problems associated with the pulley in the first place.
I accidentally spun mine to about 8600 for a few seconds. It wasn't running smoothly, however, the only problem was the power steering pump running too fast and blowing a hose.Originally Posted by ts295
Do you know how high you could go with different valve springs + retainers on your setup this spring? What exactly is the problem with the damper? Does it just fall apart at high speeds or what?Originally Posted by Gizmo318i
I've got to say that this is the most informative thread on the buildup of the M42/44 engine I have ever seen. I look forward to reading it, just to see if anything new is up. Thanks to all who are contributing to the new breed of BMW power. I support your efforts and look forward to the benefits of your trials.
THANKS,
John B.
Im really having fun with this new motor now, its really opening up!
No-one believes me its a 318i any more...
I've had a good couple runs lately, beat a late 1980's 500SL Merc last night, and whipped a Subaru 2.5 RS tonight all the way to topend. I definitely need that 6 speed gbox, my car runs outta legs quickly now (144mph @ 6800rpm, 5th gear)
I managed to get a Euro M3 cluster today but I need to import a module that will make the 6cyl tach work with the 4cyl signal. Gotta get one of these: http://www.dakotadigital.com/index.c...rod/prd127.htm
I don't claim to be an expert on crankshaft harmonics, but I don't think a solid billet v. damper would absorb much vibrations. I would hate to see disaster strike with this unique project...careful with this.Originally Posted by Gizmo318i
What I want to know is how us over here in the states get ahold of the m47 crank? This all reminds me of the "hybrid" engines I have built for my vw's
Hey Giz, most of us only dreamed on what you just achived but if you have documented what you have done it would be a great help for every one. I would like to ask you personally to share the great M42 project as i have been dreaming of having more power on my 318i.
Thanx a lot,
any updated info on this, anyone have any lines on the m47 cranks?
cant wait for they dyno!
you're probably going to have to order one through BMW (expensive) or find someone in europe or possibly SA that can find you a used one and mail it to you.Originally Posted by //m320is
-Joe
since you want one, ill be nice and trade ya, i just live down the street anyway.Originally Posted by RedV
You can get the M47 crank from a US dealer for about $800. This is through my local dealer, which is always substantially higher than Pacific or pretty much any other.Originally Posted by GDB
Ok, I had my car dyno'ed by Steven at Rob Green Motorsport today. He was VERY impressed!!!
168whp@6000rpm, this is with the stock cams and stock head....The 328i MAF conversion did help alot though...
I should see 200whp with the headwork, big cams and throttle bodies next year...
A stock E36 328i makes around 144whp on RGM's dyno...
wow, you must be well happy! what fuel were you on?
Pump fuel, 93 leaded.
Those are great numbers, for a N/A motor. I was running 160rwhp at 6.5 psi of boost on TT Stage 2 setup and a DASC. I've got TT Stage 3 setup and a smaller pulley now, running 11 psi. I haven't dynoed yet, so I'm not sure of the gains.Originally Posted by Gizmo318i
Keep up the work and good luck on the 200 rwhp. Keep us posted.
Before the board went down, a few of us had asked what the chances of getting a crank from you were. Any thoughts if you would be interested in looking into this?
Thanks,
John B.
Looks like I may need to build on of these engines Great numbers break the 200whp!Originally Posted by Gizmo318i
What did the S42 motors put to the wheels? Also, wut kind of dyno was this? (144whp seems low for what most 328s dyno at in the US - wondering if you're using a dyno similar to the guy in AU with the 318TI thats turbo'd...)Originally Posted by Gizmo318i
'03 E46 M3 - "Brittney"
'92 E34 525i - "Ivanka"
