Hey everyone. I finally got a new peice of weather stripping for my door, the only problem is I dont know how to replace it. do I need any sort of adhesive, or do the plastic clips alone hold it in? How do I rmeove the clips? Any advice is appreciated
I need to replace that part as well. Just curious about how much does it go for?
1998 M3 | 1992 850i | 1993 325is (R.I.P)AA Track Pipe | Bilstein PSS9 | CDV Delete | X-Brace | AFE 3.5" | 540 HFM | Bimmerworld Silicone 3.5" TB Boot | Stainless Clutch/Brake Lines | UUC Slotted Rotors | Remus Exhaust | Xtec 6000k HID | 3-Spoke Steering Wheel Retrofit | UUC Clutch Stop | DLS UP35 | DLS A5 | DLS MW12 | Pioneer 880 |
to replace that piece you need the complete door seal. around $120 per side from dealer if i remember correctly. i was able to find a used pair in good condition 160 a while ago.
Its s extremely simple install, took 20 minutes to do. All you need to do is remove the plastic trim peice at the bottom by slowing working your way from back to front and prying the piece off the clips. I picked up a used seal for $20 shipped from the forums, best $20 I ever spent. No more wind noise or water leaking in for me!
