Results 1 to 7 of 7
Thread: Any lightweight flywheels for 328s that work with the stock clutch?
    Houston
    1994 BMW 325i, 1996
    Anyone, anyone?
    If not, are there any flywheel/clutch combos where the clutch is as heavy or lighter than the stock 328 clutch?
    http://www.framesdirect.com/sunglasses/ - Sunglasses!
    1994 BMW 325i - GUTTED,
    AD shocks, eibach race springs, motorforce camberplates, stud conversion, and RTAB limiters, tunnel exauhst, CAI/chip, underdrive pullies, fan delete, AC delete, sparco race seats, 18x9 Superlegerras, GC swaybar, 2.8L engine with M50 intake manifold
    AND
    1996 BMW 328 - daily driver
    Sep 2004
    FL
    2017 F250
    the most common combo is the UUC stage 2 lightweight flywheel and m5 clutch.
    the clutch is a little heavier but the flywheel is lighter than normal to make up for it.
    Houston
    1994 BMW 325i, 1996
    Quote Originally Posted by Lavalamp
    yep, and since I'm not making big power that just doesn't make sense to spend a bunch of money and dilute the weight savings with a clutch I don't need, hence my post.
    AND
    Queen Mary's Land (MD)
    08 328i|01 530i|96 328s
    You can get the Fidanza flywheels which looks INDENTICAL to one sold by another popular BMW tunning co. (i hear it really the one they sell) for like $425 from Cox Imports and an M3 clutch from either bimmerparts or Autohausaz for about $300. Thats what I did and I am am VERY happy w/ this setup.
    ~Phil
    Madeiraviolett Bf.C club member #001
    1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
    3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
    CCA Member #382557
    Jan 2002
    Raleigh, NC
    since the 328 flywheel is heavier than an m3 stock flywheel, any extra weight from the clutch disk and PP won't matter. a m3 flywheel/clutch/pp is lighter than 328 flywheel/clutch/pp stock.
    If you need an m3 clutch/PP/TO bearing i have one BARELY used from my car b4 i went to a SPEC clutch. Im going to put up a FS thread soon, let me know if you're interested; i'm not looking for much.
    -Dan | '99 911 C2 | '02 M3 | '91 318i
    Sep 2004
    FL
    2017 F250
    Quote Originally Posted by jmott
    how are you diluting the weight savings? the flywheel is like 2lbs lighter than the ones made for the m3 clutch to make up for the weight difference of the m5 clutch, not to mention the m5 clutch would hold more power and such.
    i had a completely stock 328i when i put in the stage 2FW/m5 clutch and it made a big difference.
    Jun 2004
    Knoxville, TN
    2001 BMW 530i
    The reason for replacing the clutch is not for weight savings, but because the clutch has to be the same size as the flywheel. AFAIK, you'll need a M3 clutch to match up with a Fidanza LW flywheel.
    The UUC Stage II kit is a e34 M5 clutch kit and a fw that is lighten further to make up for the heavier e34 clutch.
    Steve
    2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
    BMWCCA Member #337964
