Results 1 to 25 of 61
Thread: E39 Glove Compartment Fuse Guide
    Mar 2002
    Michigan, USA
    1998 BMW 540i Sport (84k miles)
    E39 Glove Compartment and Trunk Fuse Guide
    I just thought that this would be nice to have available online when we are diagnosing electrical problems. For record it is from a 1998 540i, but hopefully the majority of the fuse locations apply to more than just that year. The trunk fuse guide is the second post below.
    Later,
    Dave
    E39 - 1998 540iA Sport (11/97 Production)
    E30 - 1989 M3 (44k miles)
    1979 Triumph TR7, still have my first car ;-)
    Past cars:
    E21 - 1980 320i (sold at 130k)
    E23 - 1986 735i
    I am a BMW Car Club of America member, are you? http://www.bmwcca.org/
    Aug 2001
    Lincoln, NE
    '05 997 C2, '15 JKU
    thanks a bunch, I am going to save that one... likely need it some day!
    this space reserved for pissing off liberals...
    ronthebabboonslayer: "helmet guy's post is far from polluting"
    Mar 2002
    Michigan, USA
    Trunk fuse guide as well
    Might as well have the trunk fuse guide too
    Later,
    Dave
    Past cars:
    E23 - 1986 735i
    Fairhope, AL
    Where are fuses 75 & 76?
    saint louis, MO
    1999 528i
    Thank you for this post. It was very helpful. My 99 528i wasn't responding to the key remote. I had to insert the key to lock/unlock and as you might imagine this was unacceptable. I also noticed that the autolock feature wasn't working when I began to drive. I assumed fuse b/c of the two seemingly unrelated malfunctions. It was fuse 53, the Central Locking System fuse in the trunk. I hope someone can use this info.
    Jun 2008
    Roseville, CA, USA
    2003 540i M-Sport
    Trying to find the fuse for the Turn signal indicators
    I don't see which of these fuses controls the turn signals? Does anyone know? My left Turn Signal is not working and I am hoping that it is just the fuse?
    Thank you all for your help.
    East Coast
    Pull n Release
    Nice! Very helpful!
    Another FP5241 Creation
    Parting out M54 Engine. Intake and all. Cats avail as well. PM ME!
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by ajthom1 View Post
    Since exterior lighting is all controlled by the LCM or LM (lamp/light control module)...if any of the fuses that support the LCM are blown...it might cause a problem...check there.
    Nov 2008
    Teaneck, NJ, USA
    2002 BMW 525i
    Re: e39 fuse 75 (50 amp) and 76 (40 amp) — I was at the BMW dealership for some other work and wanted to pick up the 40 amp fuse (my blower is out and just in case it's not the FSU, I wanted the replacement fuse handy), and you know what they said? "Are you sure it's a 40 AMP fuse? We don't carry anything higher than 30 AMP? We don't use anything higher than that on the cars."
    Then...why does the fuse diagram say "40 amp" for fuse 76? Any ideas? Or is this simply dealership being stupid?
    Old Dominion University
    '98 E36 M3 / '88 VW GTi
    printed and is living in my glovebox. thanks!
    California
    2013 BMW F10 M5
    my hazards dont work anymore..the switch still lights up but when i push it down it doesn't engage. before it went out it did go off once by itself then it stopped working ever since..so what would it be under?
    burnaby, bc, canada
    bmw 528i,
    Quote Originally Posted by kowached View Post
    can any one guide me to fuse # 52 where it is. Thanks
    Nov 2008
    Sacramento, CA
    540it-318ti-318ic-Z3
    Quote Originally Posted by trikkieshiit View Post
    Ryan, the switch itself may be broken if it does not engage/catch.
    Thanks! Nice to have it online.
    1999 540it - Schwartz II/Sand Beige, style 5 rims, Conti DWS 235/45 tires, Billy HD/Sports, Stoptech S/S BL, F1 Pinacle 35% tint, Zionsville Cooling kit
    1998 318ti Cali Sport - Schwartz II/Schwartz Anthratz, staggered style 23
    1997 318ti Sport - Schwartz II/Schwartz Anthratz, staggered style 68 ,
    1995 318ti Active - Alpineweib III/Schwartz, squared style 32
    1994 325i - Bostongrau/Tan, Billy Sports, H&R springs
    1991 318ic - Schwarz/Anthratz Stoff, Bilstien HD, Z4 3.0 SS, Magnaflow, S/S Stress bar, x-brace, M20 FW, Elipsoid/HID, K&N
    BMWCCA# 160411
    1995 318ti Sport Schwartz II/Schwartz Anthratz - Sold
    1985 635CSI - Schwartz\Sand - Sold
    1984 533i "Max" - Schwarz/Schwarz, - Sold
    1984 318i - Champagne/Tan, Stock - Sold
    Queens,NY
    e39
    Thanx for sharing . Many people will find this useful when searching.
    Arlington, VA
    M52 5MT Sport 01/98
    These maps helped me diagnose my not-unlocking-gas-door issue. I found a blown fuse in the trunk and replaced it. Viola!
    Rules to live by:
    - Fast, reliable, cheap. You can only have two.
    - Do it right, or do it twice.
    - BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one.
    1998 528i 5-speed sport - sandbeige with technical graphite trim - Jim Conforti Shark Injector - CDV delete - MY2000 M5 Xenon headlights - MY2000 M5 tails - PP M5 front bumper - E46 M3 paper filter - E60 545i shifter w/ E46 ZHP knob - 12" Alpine Type-R & 500w RF - CD53 w/ AUX input
    (northeast) Indiana
    Quote Originally Posted by gurmukhbhogal View Post
    Scroll back up to post #3 and check out the fuse index that was attached in the post. Then look for the fuses in the trunk (above the battery and probably behind the insulation).
    I say "probably" behind the insulation since I have a Touring and mine are behind the subwoofer in the cargo area...but the trunk fuses in my e38 740iL are also in the battery compartment behind the pre-cut slit in the insulation.
    And if you look at the diagram...you'll see that it shows what the fuses are for back there...PLUS...their location within the gang box...AND...the (nbr) and order the fuses are located within the gang box and their amperage.
    (trunk fuses in an e38 located behind the insulation...should be similar in the e39 sedan)
    Keflavik, Iceland
    EY40858 & JE35415
    Thank you!
    This can become extremely useful for me for my E39 was imported for Germany and therefor everything is in German, and I don't understand much in German, only easy stuff.
    Much appreciated.
    1998 Honda Civic 1.5i
    1999 E46 320i
    2001 E46 330i
    2017 VW Polo 1.2 tsi
    burnaby, bc, canada
    bmw 528i,
    Quote Originally Posted by Qsilver7 View Post
    Qsilver!! I must say you are a "GENEIOUS" and I am a "DUMMY", I must have looked at that fuse gang box in the trunk a thousand times to see where the numbers for the fuses might be. It never dawned on me to correspond that gang box to the diagram of the fuses listed behind the cover. (no #s on the gang box) Now I have power in the cigarette lighter, the 30 amp fuse was missing. Thanks a million, I bow my head to you Qsilver.
    Spencer MA
    '02 530i/A
    Is there one of the fuses that involves the radio antennae? Mine isn't working, so I'd like to know if there's a fuse to check before I go ripping out the rear driver's side C-pillar cover.
    Coronado, CA
    2003 BMW 525i Sedan
    Quote Originally Posted by athanasius2k4 View Post
    On your E39: Did you ever find out about Fuses 75 (50 Amp) and 76 (40 Amp). The Post with the Fuse Block Diagram shows 75 as being the Auxilary Fan, but I cannot find it. I think 30 Amp is the biggest BMW puts in the fuse block and these 2 are located elsewhere, probably like 66 another 40 Amp which is the Heated Rear Window. Could these 3 be the larger "Socket Type" fuses hanging off the side of the fuse block in the trunk? If so, is 66 the first, then 75 and 76 as you count downward? I could never find out what 76 was for, could you?
    Amsterdam, NY
    97 528i 87 528e 65/74MG
    Wierd, in my car a copy of this is glued to the back of the battery door for the rear fuses and a copy is attached to the front fuses as well. Am I the only person who has these?
    >'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
    Coronado, CA
    2003 BMW 525i Sedan
    Angry Have the Diagrams - See the Blocks Where's the Fuse?
    In the Glovebox diagram the two blocks run in numbers from 1-20 and 21-45 the 2 additional fuses 75 & 76 are off to the right in the diagram but nowhere to be found in the glovebox. Any ideas?
    Az
    Way too many
    Quote Originally Posted by NNY528I View Post
    I was just thinking the same thing....
    BMWCCA Member: #458927
    Current BMW's:
    2010 X5 Diesel
    2000 M5, Sport, DSP
    1999 540iA Sport, DSP
    Prior BMW's:
    2007 750i Sport, L7
    2007 335i Sport, L7
    2004 X5 4.8iS
    1997 M3 Coupe
    Amsterdam, Netherlands
    1997 E39 523i 5spd
    Exactly the same here.
    Fuses 75&76 should be somewhere behind the glove box, haven't had the time to search for them yet.
    Feb 2009
    Portland, OR
    2001 BMW 525i
    possibly
    hew! I scoured the forum, searched the car, and couldnt find it. I almost accidentally found the missing blower heater fan fuse, numbers 75 and 76. Yes, they are behind the glove box fuses..........sort of. What you have to do is look under, and in front of, the glove box, just above where the passenger feet would be. There is a sliding panel. Just pull it towards the rear of the car. Up under here there are two big fuses, mounted from above, down into their sockets. I don't know why it was such a problem to get the information, hopefully I have been successful in helping you.
    Mine were OK.
