I just bought a sont cd player and use the harnedd that came with the cd player and a adapter for the bimmer and solders everything any reason it dosent work.
Car-BMW Harness-Small Harness-Sony Deck
white(#16) - blue(#16) - blue/white(remote turn-on) - deck
Thats how it should be connected
Here are some pictures...
http://forums.bimmerforums.com/forum...ght=blue+white
Was your factory system HK, otherwise you should just get crappy reception. It seems that everyone is having that problem. It took me 3 installs to get my headunit in for good, the first time it didn't work, the second time I forgot my input wires, the third time I promised I would never do it again because squeezing the headunit in with the wires was such a PITA.
You need to insure remote amp flead rom head unit is attached to power antenna lead on car harness. If not the head unit will work in radio mode but as soon as you switch to cd mode the OEM amps shuts off and you will have no audio. Do a search its a very common mistake when wiring up after market head units.Originally Posted by jhsoccerodp
1996 328iC Boston Green
