I need a nice -10 drain flange to fit my GT35.
Found one on ATP but $29 seems high
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
well you said a few things that dont add up to "cheap"
-10
turbo
lol.... just pony up and get them. sorry im no help..lol
This space for rent.
$29 doesn't seem high to me. That's a complicated part to machine.
No PMs. Email through forum please.
Ebay and get 1/2" internal Threads? unless you have already made your drain line... Most people dont use externaly threaded fittings there..
there are alot of other options out there, but if you want a flange with the male -10 your options are pretty small.
If you don't want to spend the $29 for the cnc'd flange, then just get a piece of aluminum bar stock and cut it to make a flange, drill some holes, buy a -10 male fitting and cut it, and then ship it to me and i'll weld it for $25
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
I use this piece on my GT40 turbo
from Function - 7
20.99 pus 4.88 shipping. so the price is close to ATP. Function was the first to have this piece, then ATP started producing them. both are about the same build and price wise.
http://cgi.ebay.com/ebaymotors/Funct...7338QQtcZphoto
This fitting work on the following turbochargers:
T3 Series Turbo
T4 Series Turbo
T04B Series Turbo
T04E Series Turbo
Hybrid T3/T4 Turbo
GT32 Series Turbo
GT40 Series Turbo
T60, T61, T60-1 Series Turbo
T70, Super 70 Series Turbo
The bolt-to-bolt spacing on this flange is 50.8 mm (2.0")
a good place to go is like an air supply store for all an fittings a store close to my house has all types of fitting for cheap..about 1/3 the cost the only downside is that they are the cheap lookin brass color
I actually bought the cheaper version of this from ebay and saw this one.
It is too big, the hole spacing is bigger than the GT35 fit. Too bad caz the fully machined -10 fitting is cool in a one-piece flange.
[QUOTE=CosmoE36;10000501]I use this piece on my GT40 turbo
from Function - 7
[url]http://cgi.ebay.com/ebaymotors/Function7-T3-T4-10AN-Turbo-Oil-Drain-
QUOTE]
