I'm trying to find out if its possible to replace an e36 std wheel with airbag
with a BMW M-Technic 2 leather steering wheel (non airbag)
i dont see there being a problem with it that some sort of adaptor couldnt fix.
any help would be great. thanks
mike d
This is your one opportunity to do something that no one has ever done before and that no one will copy throughout human existence. And if nothing else, you will be remembered as the one guy who ever did this. This one thing.
97 M3 coupe, 5 spd, Artic Silver/Black Vaders
VF eng. Stage1 SC, UUC Stage 2 Light Weight Flywheel 8.5 pounds, UUC Ultra smooth Cerametallic clutch, Koni Adjustable shocks with H&R springs, SSK
Are you refering to an e30 Mtech non-airbag wheel? If so, it will not work. The splines are different on e30 and e36 steering wheels.
its suppose to be from an e36 m3
Well then, If it's from an e36 it should work.
I though all e36s have an airbag?
Yes.
BMW part # 32 33 2 226 860 steering wheel/horn pad retrofit
# 32 31 1 158 475 horn contact
The wheel bolts right on, but I can't help with the horn wiring.
