Page 30 of 51 FirstFirst ... 5202122232425262728293031323334353637383940 ... LastLast
Results 726 to 750 of 1258
Thread: The definitive subframe strategy thread
  1. #726
    Dry ridge ky
    2000 M Roadster
    Also, how hard is it taking the rear end out?(do I have to?) etc. I really need to fix this, my wife has been crying all afternoon.
  2. #727
    SW Florida
    99-01 M Cpe & Rdts, X5M
    erandyforbes@aol.com or 419 350 1098
    Just don't call tonight between 10:00PM / 11:00PM EST (Castle is on...).
  3. #728
    Sunnyvale, CA
    98 Z3 M Roadster
    I was wondering if one of you guys (perhaps Randy? ) with more expertise could point me in the right direction here. I too started getting a rather unhealthy creaking from the back whenever I accelerate. After some pointers on another thread I pulled the lining out from the trunk and had a look at the spot welds.
    I've uploaded the album here with the photos from my phone, pictures 3 & 4 seem to show the worrying signs...
    http://cid-7ab188b059908d57.skydrive...B059908D57!153
    I find it hard to believe however that this one little failure could be causing so much creaking, is there somewhere else I should be checking? I find it tricky sometimes trying to translate the close up shots others have taken to the corresponding section of car / trunk they came from. In some it even looks like a piece of the trunk floor has be cut out?
    I haven't looked under the car specifically for this yet either but should hopefully get a chance by this weekend. Any tips appreciated!
    (Oh and I realise my trunk is a bit mucky, a bottle broke in there last week and I didnt realise how far it had got)
    Gareth
  4. #729
    Batavia, IL
    00 M Coupe, 08 335xi
  5. #730
    Sunnyvale, CA
    98 Z3 M Roadster
    How much do I need to remove to give the underside a proper inspection. Is it possible just by lifting or do I need to remove bits (exhaust e.t.c)?
  6. #731
    SW Florida
    Quote Originally Posted by GBPaterson View Post
    Most important, is to be able to safely get your head under there, (and if you're older, at a distance to which you can focus...) and a good, bright light source.
    You'll want to study the area of the actual differential bracket carefully, and look ALL AROUND were the crossmember is spotwelded to the trunkfloor.
  7. #732
    Boston, USA
    2000 M Roadster
    Is it a given that over time all Z3's will develop this problem? I have seen conflicting information where one person says it isn't all that common, then another says there's ample evidence that it's a known defect and they will never buy another BMW (whatever), another person says it only happens when one of these cars gets rear ended and there a whole confusing thread about some class action suit but I don't see any conclusion to that nor do I see any recalls issued from BMW on this.
    Why do I ask? In short, I'm curious.
    I am not worried, I love the car and intend to just drive it and hope never to see any signs of a problem. However it would give me some small peace of mind to know conclusively that not all Z3s develop tuis problem given enough time and without being rear ended. I realize that there may also not be anything conclusive if there has never been anything legal or scientific enough to determine the cause to be just expected metal fatigue in a vulnerable area, an engineering defect, the side-effect of even small rear impacts, or just a small percentage of people who had the same problem because of a combination of these factors.
  8. #733
    Aug 2002
    East Coast
    ///M s52
    Quote Originally Posted by MRoadstar View Post
    Hi Coupe Dejour. I live in WA and am having a problem finding a welder in WA to perfrom work on my 2000 BMW M Roadster subframe issue. How well did Jeff @ Haury's in Seattle perform the job? Also, how much did you pay if you don't mind. Thanks
    Kito autosports. The guy worked for Osh at RMS
  9. #734
    Port Orchard, WA
    2000 M Roadster
    Finally begin Subframe fix
    After a long 9 months of saving, and countless e-mails to Randy Forbes, my Zed will finally go out for repairs today! Thanks to Randy Forbes for his great customer service and willingness to provide expert advice in a timely fashion.
    I live all the way out here in the pac northwest, Washington State. The most difficult part for me (besides saving $) was finding a shop that was willing to do the repairs. Many of the shops cited liability issues, and did not want to take up the task of repairing my subframe
    Luckily, I found a team that was very confident in their work and who ultimately prides themselves on their professionalism & customer service. I will update you guys on the process. Pics to come soon.
  10. #735
    Toronto
    ///M Roadster, Cooper S
    Hmm, I wouldn't mind becoming a Randy Forbes authorized installer for the north east...
    * 19x10 & 8.5 Work VS-XX -Rogue 18mm spacers * Hankook Ventus RS3 * H&R coil-overs * Dinan strut brace * Magnaflow 14815 custom stepped tips. * TT stg2 Turbo -416rwhp * AEM truboost * Mocal / Ireland Engineering oil cooler * Roadstersound 8 with custom set-up * flipped hats *RF Rear Subframe Kit *STG3 F1 Racing Clucth & Flywheel
  11. #736
    SW Florida
    Quote Originally Posted by billyr3d View Post
    There've been a couple done up your way, but nobody that wanted to keep doing them.
    Show me some pictures, and I might recommend you
  12. #737
    SW Florida
    Your profile is set not to accept PMs from members, or I'd be contacting you offline...
    I was just asked this morning about a shop in the PNW who could install the reinforcement package. Can you either post it here, or send me an E-mail?
    Thanks!
  13. #738
    Im about to buy this kit and was just wondering how difficult the DIY was? I am fairly proficient with a welder, and have enough common sense - is it just a matter of lining it up and welding it in or is there more to it than that?
    PRICE CUT on ALL FABRICS
  14. #739
    SW Florida
    Quote Originally Posted by Cheg View Post
    Not much more, there's only one mildly critical measurement, the rest is common sense and above average work standards
    See: http://www.spcarsplus.com/gallery3/index.php/dbr
  15. #740
    Jun 2004
    Atlanta
    98 328 conv (wifes) & 98 M Roadster (mine)
    Quote Originally Posted by blackxs View Post
    I'm a mediocre welder and my wife says I have no common sense. I installed Randy's kit over a weekend and it is still holding strong...Attention to detail is about all it takes
    Chris
  16. #741
    Quote Originally Posted by chgrec View Post
    Chris
    Good to hear
    Just bought it, cant wait to get it in. The rear subframe is the only major weakpoints on these cars imo, now I can finally have some peace of mind
  17. #742
    Qeébec, Canada
    Z3, 2000
    Subframe - Canada
    Do you knomw some place around Montreal where i can repair the subframe of my Z3 2000 ? Thank you everybody.
  18. #743
    Kent, Ohio
    1998 M Roadster
    Mr. Forbes, I sent you a pm yesterday, but I am not at all confident it actually sent--the pm system here leaves a little to be desired. If you did not receive it, please let me know and I will try again.
  19. #744
    Batavia, IL
    Quote Originally Posted by Mr Bingley View Post
    See post # 727 in this thread for contact details
  20. #745
    SW Florida
    I got to it late last, and had a call to jury duty today, so I'm running a little behind. You posed a lot of questions, and I like to be thorough when answering them, so I wanted to wait until I had the time to devote to your answer.
    Now, if you don't hear from me within a week, you'd better give me a call
  21. #746
    Kent, Ohio
    1998 M Roadster
    Quote Originally Posted by Randy Forbes View Post
    Thanks, will do.
  22. #747
    Aug 2009
    Sammamish, Washington
    2004 Mustang
    I just emailed randy about checking to make sure I dont have any problems developing. In the email I mentioned that my car was an automatic. He said "I haven't yet heard of any automatic transmission equipped cars failing in that area."
    Is it true that automatic Z's dont develop this problem? I would rather be safe than sorry.
  23. #748
    Nov 2001
    Chapel Hill, NC
    2000 M Coupe, 318TI
    Quote Originally Posted by northwest View Post
    How much of this thread have you read?
    On subframe issues, Randy is The Man. If Randy has not heard of any auto cars having subframe problems, the failure rate must be either very low or zero.
    Of course, you could always be the first.
  24. #749
    Jul 2011
    Maplewood, MN
    2001 BMW Z3 3.0i
    Just bought a Z3 and this thread worries me
    I hadn't heard about this issue before buying my first Z. I don't have any weird noises yet (my car only has 40K miles on it).
    My car is one of the later Z3s (2001), but it doesn't sound like BMW fixed it by then.
    Does anyone know what it costs to have the reinforcing kit installed?
  25. #750
    Read the thread.
