We have a 1999 Z3 2.3L and we love the car.
Problem we've been having:
Fan blower control switch on the control panel - fan only blows on high. Does anyone know what may cause this and what the solution would be? Last week it did the same thing then i fiddled with it a bit then it worked again. Then it went out the other day.
Since it blows on high I thought maybe it would be a faulty switch, not the fan motor. Could it be a blown fuse? I hope that's all it is.
It's a common problem with the blower resistor pack on the Z3s. You can try cleaning the resistor. More info in this thread. Good luck.Originally Posted by pdw1970
http://forums.bimmerforums.com/forum...d.php?t=327242
You will until you actually try to mod it.Originally Posted by pdw1970
1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed - SOLD
2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
2013 Bianco/Rosso Abarth 500c - 5 speed
2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
I'll give it a try this weekend - your knowledge is much appreciated
Good luck! Welcome!
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
I just read about the electrical system last night trying to fix a similar problem in my 1986 535i. When set on high, the fan blower switch gets direct battery current 12v dc. So, if it works on high, there is nothing wrong with your blower motor. Settings below the high setting pass through a resistor pack, reducing current for the lower fan settings. So, you probably have either a bad resistor pack, or faulty wiring through the risistors. Good luck!Originally Posted by pdw1970
