Results 1 to 25 of 25
Thread: Misfire cylinder #6 : WTF?
    Jan 2002
    Québec City
    '14 GLK250, '13 Abarth
    Why, oh why?
    Got a check engine code yesterday, had it looked up this AM... msifire in cylinder #6. What causes that?
    1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
    2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed
    - SOLD
    2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
    2013 Bianco/Rosso Abarth 500c - 5 speed
    2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
    Jul 2004
    Ireland/France
    Z3 coupe 2.8l 99' & euro E36 M3 3.0L
    faulty coil? broken sparkplug, faulty lead?
    Jan 2002
    Québec City
    It hasn't come back. coils are new (4 months old, plasma ones), so are plugs (iridium).
    - SOLD
    NY
    e30, e46, Super Duty
    Pull the plug and check the gap
    1991 e30 318is Slicktop - Gone
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    2014 F-250 CC- Mostly stock
    Jan 2002
    Québec City
    Quote Originally Posted by JoeZ
    Try replacing the plug.
    Meh... Boring.
    Tired of spending. beside, I'd have to remove your crappy HMS strut brace for that.
    - SOLD
    Jan 2002
    Québec City
    I don't have a feeler gauge. And I don't even know what the gap is supposed to be.
    - SOLD
    Jul 2004
    Ireland/France
    then get a feeler gauge and compare 5 to 6?
    Does your stepdaughter not know how to do that? delegate!
    NY
    Quote Originally Posted by Hugo
    Isnt' it in the bentley?
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    Jan 2002
    Québec City
    Perhaps. But I have the Haynes and I'm not sure that from one iridium brand to the other, the gap is the same.
    - SOLD
    NY
    I used to get cyl misfire: unknown cyl followed by misfire cyl 1, cyl 2, cyl 3, cyl 4.
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    NY
    Then I replaced my NGK's and it went away
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    NY
    But these days I can't get my idle right
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    Jul 2004
    Ireland/France
    samer here, idling problems!
    NY
    My idle is somewhat decent now (had some vacuum leaks after re-installing the dasc), but after about 800 miles stuff started going wrong.
    I received CEL (Idle Speed Actuator - Open, and another Closed)
    In neutral I can idle at 800rpms, touch throttle and revs jump to 2200...there is no middle ground
    If I press the clutch at 1500 rpms or higher and let revs fall, it is as if computer doesn't know where to stop them. Sometimes I stall, sometimes it sputters and then jumps to it's regular 700-800rpm idle
    Help
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    Jan 2002
    Québec City
    My idle is silky smooth. Post whoring your way through the day, aren't you?
    - SOLD
    Jul 2004
    Ireland/France
    Help
    did you try another MAF?
    Jul 2004
    Ireland/France
    I don't know the 4 cylinder too much but ar you sur the intake pipe to the idle actuator is not leaking or not properly set up? I didn't pushed mine all the way in once and it didn't work properly
    NY
    I'm actually very busy today....but i'm on top of my muli-tasking game.
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    NY
    Quote Originally Posted by byl
    nope, but i've replaced all clamps/hoses as well as
    pressure regulator valve
    idle control valve
    throttle valve switch
    Thing that really bugs me is how i kiss the throttle and it jumps to 2200, no way to control anything in between.
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    NY
    sorry for the hijack
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    Jan 2002
    Québec City
    Yeah right...
    - SOLD
    Dec 2003
    Northern Va
    E36/8, K12R, E91
    Throttle position sensor Joe?
    Hugo call the ignition solutions guys and ask to speak w/ Ulf. He'll help you out.
    2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
    Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
    Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
    Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
    ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
    Coming soon: and a visit to Randy Forbes
    NY
    Quote Originally Posted by clintjg
    Part # for M44 please
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    NY
    Yeah right...
    Damn, I thought I came across as pretty sincere on that one
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    Jan 2002
    Québec City
    You did, to the untrained eye. But I know you.
    - SOLD
