I'm looking to replace the engine and transmission mounts but don't know exactly where to put the floor jack and wood block.
I read some posts and descriptions saying I should support it at the "strongest point" of the oil pan and transmission.
The Bentley manual and Hanynes manual are vague at best.
Can anyone tell me exactly where the supports would be?
Pictures would be very helpful if anyone has it.
The car is a 92 325is.
Thanks.
JN
I used a bottle jack. I used the arm that attaches the mount to the block. Place it right under where that baraket attaches to the block. DONT USE THE OIL PAN!! if you do your looking for trouble. The transmission mounts can be replaced without any support, just make sure your not tring to do both motor and transmission mount at the same time.
I used the oil pan without any trouble. As long as you have a 2x4 in there to distrubute the weight it'll be fine.
-Bungy.
1999 323ti
2005 530i 6-speed
2020 X5
2013 Mini Cooper S
bungy, can you relate any improvements that you saw as a result of changing the engine mounts? Also, which ones did you use? (stock? M3?)
I replaced the transmission mounts with 320i w/ aluminum cups (a la uuc enforcer) and the shift lever is substantially firmer. Of course, I picked up some additional cabin noise, but I feel the tradeoff is worth it.
Been thinking of replacing the engine mounts, and the flexible rubber coupling in the steering shaft. I really want to get that "connected" feel back into the steering that was there when the car was new. I have replaced *everything* else in the front end (including the rack) and I still am not there. Those are the only two things left...
Thanks,
Bernman
I haven't actually replaced the motor or the tranny mounts. Though I really should. At almost 200k miles I bet they're getting worn out. But anyway, I had to jack up the engine a bit to get the exhaust manifold off. It wouldn't clear the frame. Why did I have to pull the manifold you ask? Well, about a year ago my clutch died. No biggie. It happens. In order to pull the tranny, you have to pull off the exhaust (a bad design IMO). Well, as is typical with exhaust removal after 9 years and 165k miles, I broke a stud. The studs are in the exhaust manifold. I tried to drill it out, but had no luck, so I wound up having it melted out and a new stud welded in by a local "artist". (He's not really an artist, but if you saw the job he did with my exhaust manifold, you'd say he is.) So that's the story of why I had to jack up my engine...
-Bungy.
1999 323ti
2005 530i 6-speed
2020 X5
2013 Mini Cooper S
Thanks for the story
