Well I tackled the job this last weekend with the aid some friends power and air tools. Here are some brief factoids/thoughts.
INSTALL:
1.) as another post referenced accurately, you need air tools with about 400LBS of pressure, a regular old portable just won't do. I ended up using my long breaker bar and ratchet and did just fine.
2.) definitely use a power grinder with a rotary wheel to cut the stock strut tubes. It slices through like butter. I can't imagine trying to do the job with a hack saw, let alone a dremmel.
3.) definiely use a floor jack to hold up the rear trailing arm when doing the rear struts. BTW - I installed the Rogue Engineering RSMs and they were beautiful.
4.) The first round of trying to figure out the necessary tools and procedures for the first front strut took about 6 hours (keep in mind I had to eat lunch, dinner and get interrupted by my 5 year old). The second only took 45 minutes total.
RESULT:
I installed the KONIs along with the Rogue RSM and four new Fuzion tires (225/45 and 245/40) and the car is transformed. These run in conjunction with H&R OE Sport springs and stock sway bars plus an X-brace.
Settings: I decided to use another members suggestion of setting the rear shocks to medium firmness. I kept the fronts at soft.
Ride: The ride is taught and comfortably firm, the way it should have been from the factory! It feels like a stock 911 does off the showroom floor. Not by any means bone jarring or too stiff. On the freeway the car is glass smooth and rides much better than the factory shocks did. All of the little up and down bounces are gone. Note that you feel cracks in the road and uneven surfaces give more of a rumble, but I still prefer the ride any day. Also, the stiffness of the shocks also make the car "jar" more over large cracks or lips in the concrete, but you learn to expect it and it is well worth the tradeoff.
Handling: The handling is again what it should have been out of the factory. I'm used to an e30 M3 with Bilsteins and Eibach Sports and now the handling of the e36 is getting closer its big brother. I now feel that I can throw the car into turns with out fearing that I am going to plow through the turn or just mush through the tires past their limit.
The Medium setting on the rear shocks has also helped reduce the understeer drastically. The car is much mire well balanced now. I am still interested to see what I can do to improve the handling via adjusting the front or possibly messing with stiffer sway bars or stiffer springs. The weight of the car is just its biggest drawback. Anyone who has driven an e30 M3 knows that those cars are jsut more "tossable".
Good luck.
'98 M3 Sedan, Cosmos Black w/ Dove
Good info! I'm planning on getting these and have heard they're not as stiff as the Bilsteins. I found a contact that can get me a set for $360... does that sound like a good deal?
That does not sound like a good deal, it sounds like a great deal. I just picked up mine for $539 to my door.
Wow where can you get them for 360 a set, i'm definetely in at that price.
Also Jengah, what springs do you have with the SA?
I am about to do the same mod to my 99 E36 M3. I wondered how the RE RSMs would install. I am glad to hear that went well. I will use your tips in mind!
Did you or do we have to worry about camber adjustments because of lowering the car? I would hate to wear out my tires early. I plan to do this modification this weekend. I can't wait to have the ride you felt, since I feel my suspension is sloppy (especially with the blown RSMs that I have).
Can you post a picture of how your car looks now? Front, back , and side?
CAscrnwrtr74
I too am interested in the source for $360 a set, if it is not too much trouble.
Thanks!
Me too!! Please let us know!!Originally Posted by DRIFTART
BMW E28, E30, E39 M5
Ferrari F355 GTB
Guys, I met another bimmerforums guy at a cruise-in in Cincinnati last night. His friend has a friend that works for a Bob Sumeral, and that's his price. I don't think I can really buy more than one set at that price, but I'll ask.
Well, thanks and if anyone reading this knows of any low priced sources for Konis, please let us know.
btw: RE RSMs were the best IMO, i also had GC RSMs and these felt a lot more sturdy
[SIZE="1"]1997 M3/4/5 18x8.5 Hartge Classics, F1 Stage 2 Clutch Kit
:one This Year :: Koni inserts, HR Sport, Rogue RSM, Ball Joints, Powerflex LCAB, Adjustable Sway Links (DIY), Headliner, MM Underpanel, 3 spoke wheel swap, BavSound Speakers, Bluetooth radio adapter
is $805.oo for Koni Sport and H&R Sport springs from shox.com for a 99 E36 M3
A few answers....
a.) I have the H&R OE Sport Springs
b.) I searched high and low and found the best price hands down is from a guy on ebay that sells a LOT of KONIs. Do a search, you'll find him.
c.) I'll try to post a picture in the next day or two.
d.) re Bilsteins, these are not as jarring as the Bilsteins and the best part is they can be if I need them to be when I go to the track or take the baby seat out for some backhill twisties!!!
I went into the install without knowing the specs of my car, but my tires were wearing perfectly flat. My fronts were a different story though. I am going in for an alignment tomorrow AM and will report back what they were at and what I chose. The right front tire was totally worn away, almost 1/4 inch of the rubber just wore away after a few months of some heavy driving, but the majority of the tire had good meat left on it after 10,000 miles. I think I might have a bent steering arm or a toe adjustment that is out of wack.
Can anyone tell me where the adjustment knob is for the rear shocks? Is it accessible from under the car, or do I have to pull the trunk liner back?
The standard rear Konis don't have external adjustment. You have to remove, disassemble, and compress them to adjust.Originally Posted by uansari1
I got the TCKline revalved and converted rear shocks so they are externally adjustable. If you did this as well, the way to adjust them is to peel back the carpet and go to town. I cut a tiny hole in the carpet for this reason.
JV
I was actually referring to a set of the adjustable Koni's, not the standard.
They're all adjustable. I gave instructions for adjusting them if you have the TCKline externally adjustable ones.Originally Posted by uansari1
JENGAH
What PARTS did you find you needed to have outside of the Koni SA, H&R Sport springs, and RE RSMs to do the complete job (i.e., gaskets, nuts, bolts, lube, anything)?
I am afraid I will be stuck Sunday without something I will need.
Thanks!
Best advice I can give you is to do a search and look for the really good write ups. I remember druidhill being one of them and also on on the FAQ list.
Critical Tools List:
- (2) Jack Stands
- Floor jack
- 18mm Socket (make sure you have one 'cuz most tool sets don't come with one)
- Long Ratchet
- Vice
- Bucket for shock oil
- Drill
- 1/8" and 1/2" drill bits for metal
- metric wrench and socket set
- spring compressors for front springs
Recommended Tool List:
- Rotary Grinder/Cutter (this is way better than using a hacksaw or Dremmel tool)
- Air gun or impact rench (helps in freeing shock bolt and putting bolts back on)
- Torque wrench
- rat tail file
- Red and Blue Loctite
- strong wire or rope to hang front caliper (or a paint can is about the right height to support it)
- liquid wrench
Good luck
I FINALLY ordered my suspension! Koni Sport and H&R sport setup. I don't track so I didn't go for the coilovers.
Getting ready to cut some metal..... I can't wait for the (ala Beastie Boys) "mmmm..drop!"
Ground Control also sells the rear external adjustables.Originally Posted by John V
If you want a very good deal on a spring/Koni shock kit, check this one out:
http://www.pure-motorsport.com/produ...63/CA=187/PA=7
I started a thread on this kit a while back, you can do a search for it. The rear shocks are "standard" adjustable, not externally adjustable.
97 Estoril/Black M3/4/5
"Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
Road & Track May 1997, testing the M3 Sedan
That is a great price. Are the struts in the Vogtland M3 kit M3-specific, in that they have welded-on w/sway bar tabs?Originally Posted by M3 Pete
Grant
Sold - 98 M3/4
you will not find ANY koni with those M3 tabs unless you buy the coilovers. All E36 M3 non-coilover Konis are INSERTS. You cut the top of the stock strut off, pull the guts out, drill a hole in the bottom of the strut housing, stick the Koni insert into the empty housing and bolt it in through the hole you cut in the bottom. THere are a ton of DIY websites on this, and countless threads here.Originally Posted by Grantbo
If you read the first post, this is what he's talking about.
Yes, all the Konis or non-coilver pkgs that I've seen to date use Koni inserts. That said, it's been some time since I looked into the Vogtland kit, so I had to ask. Many folks, such as myself, would be interested in a true bolt-on, non-coil over kit. Chris at understeer and Edge motorworks both cut/gut Konis for a fee, so there are at least 2 options out there.Originally Posted by M3 Pete
Grant
Sold - 98 M3/4
