Results 1 to 4 of 4
Thread: Up to running temp in less than a mile?
    Dec 2003
    boone
    1995 332is
    Im finally done with my 3.2 swap. Ive had the car taken apart for so long I forgot how long it usually takes to get the car up to temp. I dont remember it happening so fast (less than a mile). Im starting to wonder if the thermostat connections are switched. I made the pigtail in stead of tapping into the head. Would the engine even run right if they were switched?
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    The dummy gauge in the cluster isn't accurate, so yes, it should get about centered in approximately a mile or so of driving(2-3 mins). I think the center position goes from ~140-225*F or so. So the gauge will go to the center before the thermostat even opens.
    Don't start beating on the car for another 10 minutes though, the oil temp takes a long time to get up.
    Feb 2001
    North Jersey
    Rogue 3 TTs2.5 / Rubicon
    re: oil temp
    up to 10 minutes or more depending on the outside temp.
    Hey man, I'm a professional!
    Oct 2002
    Buenos Aires, Argentina
    5/94 Euro 325i coupe
    In my car, it takes around 10 minutes to get it to the running temp... and longer if it's very cold.
    Quote Originally Posted by ClintonM3 View Post
    the Audi A4 is a tweaked, cosmetically enhanced, cross platform, put-together overnight VW.
    Quote Originally Posted by joeuser528e View Post
    Staggard setups are for cars that you park at show meets. They go well with 5 screens and 3 12"s.
