Results 1 to 4 of 4
Thread: M50 misfire at full throttle
    Jun 2019
    Petaluma CA
    2001 BMW 330ci
    I have an m50tu that's bone stock, just did a head gasket and intake manifold refresh on. So far it drives fine when you're cruising but as soon as you go full throttle, it starts to misfire consistently. After I cause it to misfire , it will then occasionally miss when driving normally.
    I tried running it with the MAF unplugged to see what would happen, and found out that shortly after starting to drive, it started to misfire all the time.
    Any thoughts and recommendations are welcome.
    Sent from my CPH2451 using Tapatalk
    Jun 2010
    NY
    1997 328i
    Was the head decked and checked for cracks?
    Jun 2019
    Petaluma CA
    2001 BMW 330ci
    Quote Originally Posted by Eric93se View Post
    Yes the head was decked and inspected. Block was prepped as well
    Jun 2010
    NY
    1997 328i
    Check all your electrical connections and the grounds for the coils.
  1. E38 740iL multiple misfire after some full throttle
    By TAM 11M in forum 1995 - 2001 (E38)
    Last Post: 12-12-2012, 07:00 PM
  2. 325iT high RPM full throttle whistle noise
    By edsarkiss in forum 1999 - 2006 (E46)
    Last Post: 03-23-2011, 10:00 PM
  3. Car bucking violently when under full throttle?
    By LUIS in forum Forced Induction
    Last Post: 03-23-2003, 12:42 AM
  4. Car shakes under Full throttle
    By AJCdis3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-15-2003, 10:14 PM
  5. Lack of Full throttle
    By cpt97M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-05-2002, 11:30 PM
