So nobody knows what a legit fix of this seat/weight/tensioner or whatever the hell it is, costs? Not everyone can fear the dealer, somebody must have took the plunge. Lets say your all cheap, so lets fix it ourselves. Lets start with the part, what number is it? I'm determined not to be putting duct tape over the light.
Winter – First, you need to interrogate the SRS module and retrieve the fail code(s). So, you’ll need the Peake Reader/reset tool or visit the dealer. There are dozens of possible failures.
Most common failures are the seat belt L/R tensioner/restraint and the passenger present sensor (mat) in the passenger seat.
I’ve changed both – the passenger seat mat is the bigger challenge, but very doable.
P/N for the sensor mat is 65776921952. The cost was ~$85 shipped from Crevier. Not absolutely certain, but I believe the dealer charges about $500+ to remove and replace. You’ll need small hog rings and hog ring pliers to reassemble the seat upholstery. Otherwise, no special tools are needed for either job.
P/N for seat belt tensioners: Left 72119119551, Right 72119119552. These guys are about ~$95 shipped.
Both chores require seat removal. Good luck.
I think vstol answered both. The airbag light is similar to the SES light: A number of different fault codes can cause it to turn on. The first step would be to somehow get that code to know what component(s) of the system triggered the light. The dealership, a well-equipped indy shop, or the Peake tool (I didn't know that!) will be able to read the codes and get you started in the right direction.
If the fault is in the seats, vstol has provided a great start.
Another common cause is the air bags in the door. If you have the door disassembled - say, for replacing a window regulator - and you turn the key while the side airbag is disconnected, the light will come on. The light won't turn off by itself, even after you plug the airbag back in. It must be explicitly reset, either by the dealer or well-equipped indy shop (I don't know if the Peake tool can).
nathancarter - info on the Peake SRS tool.
http://www.peakeresearch.com/srstool.htm
Aha, I see. This is a separate tool than the one used for OBDII codes, then? I hope to not need it any time soon; my local indy shop was very reasonable - $20 to reset my airbag light.
I got an Equus/Innova OBDII tool for Christmas, I'll be satisfied with it for a while. The Peake OBDII tool would be nice for the BMW, but I like the flexibility of being able to plug in to different cars. My wife's Volvo S60 will display OBDII codes on the dash. Anwyay, getting a bit off-topic.
This is funny. Everyone has their airbag light on. Mine is on too. Maybe the light on is telling you everything is A-OK? People without the light are the ones with the problems.
i have the same problem, it comes and goes... maybe BMW should fix this free as its so common... its not our fault, its not considered as wear and tear is it?! how about a recall to fix this problem along with many others lol
BMW E46 330ci M ClubSport - Estoril Blue - Bi-Xenons - Heated Leather - Facelift - OEM Style 71 18" 2 Piece Alloys - Carbon Style Cubed Trim - OEM LED Rear Lights
2000 323i - my airbag light is on, there are No codes present with the Peake REsearch Tool and I just had a State inspection (Massachusetts) and the airbag system (OBD) checked out fine. Thoughts anyone?
Tom Lesko
Hingham, MA usa
No OBDII codes or SRS codes? In other words what Peake tool are you using? The engine codes and SRS codes are independant. If the ABS light is on there should be a SRS code and the tool should be able to reset the light (even if the light and codes just come right back next time the car is started.).
Must have the SRS peake reset tool to read the airbag codes (or some other form of top secret super sexy software)
The passenger seat mat is usually the culprit. That's about $1k to replace (high labour cost). I bought a bypass unit from eBay ($25) and a B800 Scanner ($30). Put the bypass unit in myself (lots of DIY out there) and the scanner reset the light. The airbag will now deploy even though there is no passenger. It will also deploy if there is a passenger, of course.
jeeez, almost 8,000 views. Most be a common problem. (Mine is lit too as well)
Mine too. But Im not able to find a DIY on how to change the mat sensor.
Sahara Beige 323i 5MT, Bilstein struts, Carbon Fiber BMW Performance Strut Bar, Carbon Fiber DINAN Cold Air Intake, BMW BBS Style 124 staggered 18" rims, Michelin Pilot Sport 225/40 & 255/35, Front plate delete, Debadge, LED Eagle Eye Tailights, BMW Clear corners, BMW rear License Plate PDC sensors
Monaco Blue 318i Auto, Bilstein struts, BMW front grills and finisher trims of 335i, BMW Style 366 staggered 19" rims, No runflats just M mobility kit, BMW M dead pedal, Front plate delete, Debadge, AC Schnitzer replica rear trunk spoiler, BMW OEM accesories:Umbrella, Rubber floor mats, Trunk Bag Hook, 1st aid kit, Tire preasure gauge, Oil storage bag, Tire tote spare wheel for trips
I decided against changing the mat sensor. If it takes BMW technicians at least 3 hours to do it, it's not something I was willing to attempt. In any event get it wrong and you will probably discharge the air bag and that is very very expensive. I did a lot of research before I bought the bypass unit and the scanner. As has already been said, these are old cars and if the air bag goes off it's pretty much a write off anyway.
Thanks for the info, I don't think I can pass the annual inspection again with the light on (Massachusetts) however, last year it did pass with the light on because the readout did not show a fault.
There are several sellers on Ebay for the bypass, from Ireland, UK and Lithuania. I will most likely go with the UK seller, $20 incl. shipping. Who did you buy from? Thanks again.
Tom L.
I bought mine in Australia, because that's where I live. Just read up a bit to make sure you get one that does the job. Remember that you will have to buy a reset tool as well because you have to reset the air bag light after you bypass the mat sensor.
Mine is still on, tried to find someone locally via groups to reset it for me after i bought and installed the "resistor" module from Ebay. Also cleaned the connector under the seat. Will probably take it to Bimmers in Kennesaw and pay the piper for resetting it.
"Pay dat myan his myoney" Teddy KGB
My passenger side airbag light comes on as well. Only if someone sits in the passenger seat that is. When they get out, it stays on. I have to pretty much punch the passenger seat to get it to turn off.
My car is in the shop right now because of some asshat who hit my car while it was parked at night. When i called to get an update, they said they are checking an airbag code my car is throwing. If it was caused by the accident (car got hit on the front passenger door) they will replace the faulty sensor. Heres to hoping they do.
Member #2 of the unofficial Bf.c OT ĢI hate peopleģ club
Can u provide more info on this bypass please?
Specific name, part #, etc so I can find one.
M driver, RSV4 Rider, Powerstroke roller
i have an extra bypass module that is to bypass the seat sensor within the abs system. i think i paid $20 if you include international shipping, i'll sell it to you for $15. It plugs into the connector under the passenger seat, easy as pie. This did not work for me and i believe it is my seat belt tensioner.
PM inbound. I ran my code and it says its an intermittent break in seat sensor. Comes and goes depending on how the passenger sits. Sometimes it goes away a little into the drive sometimes it stay.
Seats empty no lights.
Bevo. I got the bypass. Works perfectly no error light. Easy install.
Thanks bud.
