Here are the facts:
- Bought a 2000 M Roadster last fall with 48K miles, the car appears to be completely stock
- The car sat all winter and I started driving it this spring, shortly thereafter got the CEL light
- Bought the Peak tool and pulled three codes:
- 1)cylinder 2 misfire 2) Secondary air supply low cyl 1-3 3) Secondary air supply low cyl 4-6
- Reset all the codes and only the two codes for the air pump came back within a week or so.
- The secondary air pump was dead, replaced it and verified that it works upon startup and the codes associated with it (2 and 3) have not come back for a few weeks now
- The code for the cyl 2 misfire has not come back either, but the symptoms persist
- I replaced the original plugs(which looked perfect) and moved the coil and injector from cyl 2 to cyl 3 and 4 to see if the problem follows
- No oil in the spark plug holes, everything appears normal
- I don’t know how to test the coils, but I checked their resistance (ignition off) and the resistance is the same for all 6.
- The misfire code has not come back, but the symptoms persist
Symptoms:
- Every morning or only if the car sits for several hours and fully cools down, it runs very rough for about a minute or so.
- If I tap the gas, it seems like the car is chocking
- The idle however, stay nice and low and doesn't bounce or anything, during that minute, but it seems like for that one minute it is misfiring
- After about a minute it completely stops running rough and runs perfectly; the throttle response it normal
- Also after it warms up it run great
I don’t know what else to check or how to proceed. Any ideas?
Ditch the PEAKE and buy and ODB-II cable and laptop software...
My initial thought is the coolant sensor but you'd more then the peake tool to see.
Also for shiets and giggles you can try to let the fuel system fully pressurize before starting and see if that fixes the problem. ie turn the car for a few seconds before starting.
2010 E60 M5
2001 M Roadster
2001 E39 M5
Are you talking about the Coolant Temperature Sensor? Would that have it's own code if it was faulty? Do you know if it is easily accessible?Originally Posted by Ferris
Vaccuum leak.
Tighten down your intake manifold. Shoot brake cleaner where the manifold meets the head, see if it stops/revs higher as the manifold sucks the brake cleaner in.
1999 Cosmos Black/Dove Grey BMW ///M3 convertible - 5 speed - SOLD
2005 Atlantic Blue Pearl/Taupe Leather Subaru Legacy 2.5 GT Wagon - 5 speed - SOLD
2014 Tenorite Grey/Black Mercedes-Benz GLK 250 - bone stock.
2013 Bianco/Rosso Abarth 500c - 5 speed
2016 Oxford White/Grey Ford Transit 250 Powerstroke 148 MR (DIY RV conversion)
Wouldn't a vaccuum leak have an affect on the engine at all times and not just for a minute on cold start up?Originally Posted by Hugo
The coolant sensor reading a wrong but valid value wouldn't trigger a fault. The DME uses coolant temp to help determine a cold start vs warm start. Though as MDEX said there is a cold start TSB and it could very well be that.
Like I said it may help to hook up with someone with and ODB-II converter and a laptop to help eliminate that. Plus you could see if the idle smooths at the open loop closed loop switch. It's a lot more data to help narrow things down.
2010 E60 M5
2001 M Roadster
2001 E39 M5
yep, i have the same thing and even posted a video clip of it. The cars there, spits and spudders for aboutr 45 seconds then smooths out. If I try to drive it in the first 45 seconds or so it will try to choke and die. I always let it run its course then take off. I drive it gently for about 5 minutes then don't really get into it for about 10 minutes.Originally Posted by ///MDex
-Jason
Weekend Car
'99 Boston Green M Roadster - intake, M50 manifold, schrick cams, magnaflow exhaust, TCK D/A Coilovers 500/600, RD front bar, ltw flywheel & clutch, harddog rollbar, schroth harnesses, zionsville radiator, S54 oil cooler, stewart pump, etc ..... ~245rwhp
Possibly, unless the leak is caused by a veri small defect in a seal that expands when the engine heats up and the leak is then plugged.Originally Posted by submit
Has anyone here replaced the coolant sensor? What were your symptoms?
Coolant temp sensor is very cheap and easy. It's located beside the overflow canister on the passenger side of the rad and it's actually threaded into the rad. You could try to replace it, can't hurt. You just have to drain the rad to do it which by the sounds of your post you're more than capable of. It would be wierd for this to be the issue though.
It will not be a vacuum leak. A vacuum leak (if big enough to affect the operation of the engine) will always be felt with seemingly poor throttle response. What actually happens it that it deosn't respond untile it gets fed the fuel it needs to burn the unmetered air leaking into the intake tract.
Plugs were all bown or black to the colour?
Throttle response and power are completely normal when warm?
No CEL's for a missfire since?
It could be just the cold start issue. The remedy for this is to install a blower!
(Just kinddin) Try a Shark injector that will richen up the mixture a little or just deal with it.
Just so you know, if you had noticed reduced power both warm and cold I might have suggested the cats might be clogged up. They have a habit of biting the dust right around 80K miles. Usually just after warranty!
Modifimied Z3 2.8
Faster than you think
Thanks for replying.
Why do you say it would be wierd for this to be the issue?Originally Posted by StouffvilleZ3
I didn't think it would be a vaccuum leak for the same reason.It will not be a vacuum leak. A vacuum leak (if big enough to affect the operation of the engine) will always be felt with seemingly poor throttle response. What actually happens it that it deosn't respond untile it gets fed the fuel it needs to burn the unmetered air leaking into the intake tract.
Plugs looked good..not much color...somewhat tanPlugs were all bown or black to the colour?
When the car is warm the throttle response is great and the car runs like a beast.
No CEL's for a misfire since March.
I have been thinking of a way to convince the wife that I need one...She wants one for her car :-)It could be just the cold start issue. The remedy for this is to install a blower!
Full power when warm...is there a way to check if the DME has been reprogrammed?(Just kinddin) Try a Shark injector that will richen up the mixture a little or just deal with it.
Did someone say coil packs? I see that you swapped them out but they have been know to do some funny things and cause some strange issues.
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
nope, being in Florida and having warm weather, it never did it. As soon as I got back to Ohio it did it again.Originally Posted by ///MDex
-Jason
Weekend Car
Anyone know how to test the ignition coils?Originally Posted by clintjg
well, to me i would say if you aren't getting a consistant misfire then the coils are fine. if one cylinder isn't firing you would know.Originally Posted by submit
-Jason
Weekend Car
Agreed. Maybe not the coils themselves, maybe a loose/corroded connection?
My thinking is along those same lines as far as the coil and the injectors...so needless to say I am somewhat stumped...Originally Posted by JBgotM
roughness at cold start = par for the course
just don't drive it for the first 30 seconds or so
-Jason
Weekend Car
