Okay, so I turned the car on yesterday and my climate control is wiggin out. Its randomly going up in fan speed and down, display is bright one sec and then dim the next. Car feels as though the AC is on put the button isn't illuminated... etc etc you name it - it happened.
I just turned the fan off... anyone ever had any issues similar to this and if so what direction did you/repair shop go in getting it fixed?
Cliff
I think there will be a recall on the controller soon. Just about everyone I know is having problems with theirs. Just go to the stealer and buy a remanufactured unit. It runs about $280 and is a easy swap. shouldn't take more than 10 mins. All u need is a pair of very fine needle nose pliers to take the face off and a philips screwdriver to remove the old fan.
"The older the boy, the bigger the toy!"
<img src=http://pages.sbcglobal.net/dinan3/ar15firing.gif><img src=http://pages.sbcglobal.net/dinan3/offwall.gif><img src=http://pages.sbcglobal.net/dinan3/rocketwhore.gif>
Modifications
Yup - I just replaced mine this week. Cost me $250 with CCA discount. One thing, though - you'll have to have the new unit "coded" after install or it will read in Celsius instead of Farenheit. I think the $tealer charges an hour of labor to do this (ouch, no lubricant?). But it will work fine uncoded if you can live with the Celsius display. I will probably have mine coded soon, but I'm just happy it works again!!
Thanks all go see the stealer... anyone have a part number?
Cliff
yup - 64-11-8-379-521
Good luck!
Tom-Originally posted by tmink
Good luck!
Do you know the correct name for this part? And, where is it located? Thanks - Jay
BMW calls it a "RMFD CONTR", which I assume means "remanufactured controller". What you get is the entire unit in the dash, minus the little fan and buttons. You'll have to re-use your buttons and fan. The old unit pops right out of the dash. You can swap the whole thing out in under 10 minutes.Originally posted by LUNI2NZ
Tom-
Thanks for the help guys.
I decided to turn the fan off since it was annoying.. well I noticed today as I sat at a light that it seemed as though the AC unit was on... essentially I felt it engage. My concern as I wait for this bloody part which I hope will correct my issues. So if the AC is essentially on but not blowing air will that cause any issues? I can't get the digital display to do anything anymore (yes I checked fuses etc) its dead.
I'm wonder by not blowing air over the cooled condensor if it will freeze it thus adding to my woes?
Cliff
Thanks again. BTW, I'm looking for someone in your area that stocks SA rated helmets. Specifically Bell or Simpson. Got any tips for me. I may take a drive down if I can find a place where I can try them on. Thanks - JayOriginally posted by tmink
Where did you purchase the unit for 250.00 to 280.00 at? I can't get that price at all from my STEALER
Cliff
Thanks,
Cliff
www.cayerace.com
If its totally dead, check the OBC fuse to see if its blown. There is a couple fuses in teh aux fuse thing under the drivers side behind the kick panel with a few relays and stuff. Blew mine and it took me forever to find it. Just call it luck I saw it when installing my speakers.
Mpire
White is Right, Steel Grey is OK, but Estoril is the only color that truly matters.
I like Coupes.
Oh damn... found one in Texas and Montana... thats it as per BMW parts... sheesh.
So do I have to have it installed by the dealer, or at least "programmed" by them?
Cliff
Thanks,
Cliff
www.cayerace.com
Right at my local dealer (bmw.niello.com) You might try Pacific BMW - they ship world wide and have great prices - www.pacificbmw.comOriginally posted by carrera
Cliff
BTW, my dealer had 3 on the shelf - they sell a lot of them.
Jay -Originally posted by LUNI2NZ
I know who I can ask, but he's up at Thunderhill today. I'll ask him later when he gets back and post the info.
Thanks - I found one out of Texas and they gave me a great deal on it - $245.00 plus $20.00 to ship overnight. Works for me.
Thanks for all the help.
Cliff
Thanks Tom. I'll keep an eye out. JayOriginally posted by tmink
Jay -
Hi there,
I have the same problems....but it is not the climate control unit...it is the main wiring connector that connect to it. You need to open up the connector (Just slide out the white part from the blue housing), and push on the metal spring at each wire. This will ensure that it has proper contact with the pin when connceted to the climate control unit.
Please try this first before buying a new unit.
Cheers
