Bavarian Soundwerks
Results 1 to 8 of 8
Thread: Aftermarket pioneer radio resets when car is turned off then on. ALWAYS? HELP!!
    Dec 2013
    Putnam valley ny
    95 BMW 325i e36
    I have a 95 325i with. Pioneer headunit. I bought the car from a previous owner and the radio was in the car already. Everytime the key is turned on then off then on the radio would reset and i would have to change the clock back and redo everything. Every single time i got in the car. My sister had a bimmer a few years bavk and she said the same thing happened to her you cant fix it. I think that is bullshit. Thee has to be a code or something to make the radio not reset. If it helps i have no am or fm radio. I think its the signal not to sure.
    Cary, NC
    1999 740i 1999 Honda CRV
    Check the permanent hot lead to the head unit to make sure it is not on a switched circuit.
    Dec 2013
    Putnam valley ny
    95 BMW 325i e36
    Ok will do. Could there be any other reason why?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    That is 99.9999% the correct answer.
    Dec 2013
    Putnam valley ny
    95 BMW 325i e36
    Now what exactly do you mean by "switched circuit"?
    Auckland, New Zealand
    2014 F10 530d, 2014 F20
    Your headunit has a wire that connects to a switched power source ie ignition, and a wire connecting to constant power ie battery. I seem to remember some Pioneers have 2 constant power wires. If you don't have the constant wire connected then you lose all your setting when ignition is switched off.
    Note: I assume the wires are red and orange. Check your owners manual to be sure.
    Mutual Admiration Society
    Founding member
    Stereoinstaller1 is offline Senior Member Supporting Vendor
    Feb 2010
    Centralia, WA
    All of them!
    Pull the deck, swap red and yellow, as everyone else has said, that is 99.99% it
    @rogan: they went IEC 20 years ago, no more orange constant
    Closing SOON!
    "LAST CHANCE FOR G.A.S." DEAL IS ON NOW
    Luke AT germanaudiospecialties DOT com or text 425-761-6450, or for quickest answers, call me at the shop 360-669-0398
    Thanks for 10 years of fun!
    Apologies, we're a bit behind the times down here. Either that or early onset dementia.
    Founding member
