Results 1 to 22 of 22
Thread: cutting front struts for Konis
    May 2001
    Texas
    E36
    all of the writeups i've read online say to cut right below the weld. on my strut, there doesnt seem to be any weld. should i still try to cut about 22mm from the top edge?
    i have attached a pic; can someone use it as a reference to suggest where i should cut?
    thanks
    Sep 2003
    Riverside/San Diego
    95 M3
    I cut off about this much...
    Dinan supercharged
    May 2001
    Texas
    E36
    did you use a hacksaw? i am thinking of starting with the dremel, and then continuing and finishing with a hacksaw.
    also, i don't have anything to hold the strut in place; i'm worried about drilling the bottom hole off center. does anyone have any suggestions for making the hole?
    thanks again guys
    Oct 2001
    Lake St. Louis, MO
    328i, 330i ZHP, X3
    Quote Originally Posted by Loud_TIGER
    thanks again guys
    The hole doesn't need to be perfectly centered. Just center it by eye, and enlarge it until you can insert the bolt into the end of the strut insert.
    I started cutting with a hack saw, but it was going pretty slow. I ended up using an angle grinder - much faster.
    '08 328i E92, '05 330i ZHP, '04 X3 3.0, '96 DASC 318is (gone), '96 M3 AA C38 (gone), '07 335i (gone)
    Philly
    95 M3, '86 Grand Marquis
    Quote Originally Posted by calypso
    damit, why didn't I think of that?!?!!!?! We were using my buddies cutoff wheel on his air compressor. The compressor didn't have enough balls, so we'd cut, wait for it to fill, cut, wait for it to fill.
    I tried using my pipe cutter, but with the flange on the outside of the strut, I couldn't get it low enough to actually cut it free.
    Jun 2001
    Hilliard, Ohio
    1995 M3 - 1966 Mustang 2+2 - 2003 Z4
    Cut just below the crimped area. An angle grinder with a 4" cutoff wheel slices through that tube like butter.
    www.understeer.com
    Your source for:
    Stromung|UUC|Eurosport|Hawk|H&R|Koni|Apexcone HID|Short Shift Kits|and more
    UUC Evo3 SSKs are IN STOCK - free 2-Day shipping!
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    Quote Originally Posted by bimmer95
    yeah, that's what I used.
    Minneapolis, MN
    E36 M3/4, E30 M3, E39 528i
    I'd be careful about centering the hole. I drilled mine slightly offcenter and nearly stripped the threads on the insert trying to get the bolt in. Overall, what a PITA.
    I originally cursed Koni for not making a real strut for the e36 m3. But, after losing the the upper thru-bolt this weekend while driving on the track, I'm grateful that only the strut got damaged and I'll be able to reuse the shock. Remeber to torque the bolts! I'm not certain if losing the bolt was my fault or the alignment shop's fault. I'd like to blame the shop since I was using the torque wrench after I put in the Koni inserts.
    Feb 2001
    So Cal
    1997 M3 Sedan
    Dammit, I HAVE an angle grinder and didn't think to bring it to my buddy's house for the install. I tried a Dremel cutoff wheel but that was slow as hell, they just aren't made for large projects. Ended up using a hacksaw, not too bad, but not like an angle grinder ...
    Like he says, cut just below where it curves over. No need to go the 22 mm or whatever the koni instructions say.
    And be aware that you may have to use the bottom bolt to pull the insert down into the bottom of the housing. Mine would not go all the way down until I cranked on that bolt while my buddy held the housing. If you have to do that, don't use the lock washer until you have the strut completely seated in the bottom of the housing, then pull the bolt, put the lock washer on and torque the bolt to the proper spec.
    As far as centering the bolt hole, I thought I centered them perfectly, but both were off. I had to use the Dremel to enlarge the hole in the direction of the threads
    97 Estoril/Black M3/4/5
    "Although we've experienced an M3 sedan with an automatic, our test car came fitted as God intended, with a 5-speed manual ..."
    Road & Track May 1997, testing the M3 Sedan
    May 2001
    Texas
    E36
    4 hours later, and i couldn't get the insert all the way down to the edge of the housing. i banged on it with a hammer on top, pulled it in with the bolt... just wouldn't do it. i ended up just screwing the whole thing together. it's still a little off, but i figure it shouldnt affect the suspension in any way, right?
    i hope the next one goes faster...
    May 2001
    Texas
    E36
    i used a hacksaw and a dremel. they did not slice through the tube like butter. lol.
    Jun 2001
    Hilliard, Ohio
    Hit the bottom of the strut housing against a HARD surface (concrete, steel anvil, etc). Momentum will drive the insert all the way in to the tube.
    www.understeer.com
    Your source for:
    Feb 2001
    So Cal
    1997 M3 Sedan
    I had to use this just to get it where I could get the bolt onto the insert, then cranked the insert down with the bolt. (I hit the bottom of the housing on a 2x4 laying on concrete). Then I had to use some serious torque on that bolt to get it all the way down, on both struts. My buddy held the very top of the insert with a pipe wrench, using some rubber to keep it from digging into the metal.
    Mar 2003
    Massachusetts
    M3, S5
    I just bought some Koni's and this thread is making me think it was a bad idea.
    Jun 2001
    Hilliard, Ohio
    Quote Originally Posted by BMitchW 323is
    Don't worry about it, it's really an easy install.
    www.understeer.com
    Your source for:
    Mesa, AZ
    97 M3, 08 Odyssey
    Well, I think *easy* is pushing it, but I wouldn't say it's terribly difficult. Don't worry about being exact with the cutting - taking off as much as an inch won't matter at all. I'd worry more about taking off enough than taking off too much.
    The drilled hole in the bottom, however, should be as close to the center as possible. I drilled 2 of mine more off-center than they should have been, and I had to use a sanding bit on the Dremel to enlarge the holes to align the holes with the threaded holes in the bottom of the struts.
    For those of you having trouble getting the strut in the housing, there are bumps inside the housing that need to be filed down for the strut to fit in easily. They are hard to see and even harder to feel, but they are there and can be filed down smooth.
    Hope this helps...
    97 M3 - Estoril Blue 5spd Coupe
    Sound: 60GB Video iPod into Nakamichi CD-400, CDT Audio HD-642, RE Audio SE10, Phoenix Gold Xenon 600.1 and 200.2
    Handling: Koni SA, Eibach Pro-Kit, front strut bar, 245/35/18 Yokohama S.drive on RO_JA Formula 7, Rogue RSMs, GC RTAB shims
    Performance: Akebono Euro Ceramic pads, Zimmermann x-drilled rotors, DIY K&N CAI, ASC delete, Understeer SSK, UUC TMEs + clutch stop
    Appearance: OEM clears, rear lip spoiler
    Baltimore, MD
    TBSS, 90 348, 65 Mustang
    You need to cut 22mm like the Koni instructions say. You also need to use a rat tail file to file down the inside where the sway bar mount is welded on. I happen to do the cut and gut for people. If you want it done, email me john @ team-car.com
    Here's a pic for reference (cut, gut, cleaned and painted):
    Jan 2003
    Still in Seattle
    95 M3, 05 F-150 STX
    Quote Originally Posted by scoutmasterdave
    Hope this helps...
    + 1, it's not hard. but it takes a while and it helps to have good tools.
    Oct 2003
    Seattle
    99 M3
    Use tool Lisle 31530 to cut the housing just below the crimps.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Old post, but good tip for anyone doing this in the future. I used a pneumatic cutoff wheel and a dremel afterwards to deburr it.
    FL
    are slow.
    Quote Originally Posted by LockDots View Post
    Yup, great advice. I used the Gearwrench 2031 a few years ago for mine and it worked great. Just make sure to oil up the cutting wheels so they don't wear too quick.
    -Dr. Seuss
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Quote Originally Posted by bluptgm3 View Post
    Use Leslie tool LisleŽ 31530 to cut the housing just below the crimps.
    Works! And, tool of choice for CAT thieves.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
