Curious what the turbo S52's (350-450whp) are getting for fuel mileage as of lately? I know I shouldn't care but I am just wondering what to expect how it will do when im not beating on it.
'99 Estoril Blue + Dove Grey ///M3 coupe
'04 Jet Black + Cinnamon ///M3 coupe
I get 17-18 most of the time.
Highway off boost gets me mid 20s.
2.79 rearend though.
nice!
Omer I saw your name in the thread preview and thought "oh HIS reply should be interesting!" lol That's pretty good considering the power you're making. I gotta get another ride from you one of these days...last time was just a 1st-2nd gear quickie about 200whp ago!
I avg on a tank of 93 octane 340 city and about 400 hwy.
1995 M3 Custom Turbo, Turbonetics T66 BB,72lb injectors, Sias Tuning PnP Tec 3, IBM T30,PLX M250 wideband O2 sensor,Blitz SBC-iD Built low CR 8.5:1 motor CP Pistons,ARP head & main studs,Metric Mechanic HP Valve springs,walbro 255hp,BMP FPR,Modified fuel rail # 6 SS feed line,3in ss custom magnaflow exhaust,Lower level turbo intake,AA six puck disc, Spec Stage IV PP ,AA differential bracket,AA strut tower brace,UUC UD Pullies,UUC short shifter,UUC tranny mounts,UUC clutch stop,Fluidyne HP radiator.M3 LTW wheels Est..1001 rwhp!
Http://members.cardomain.com/bassmasterM3
(DIY custom turbo)
I'm boosting around all over the place, and am going through the gas. I couldn't give you exact mpg numbers but off boost its about the same. Maybe I'm just getting used to it, but the gas trigger is being constantly pulled.
TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
Prob about the same gas mileage is used, I figure. The reason is more gas to get up hills and such in a NA car. And with boost, lighter foot+more power=Same gas, I guess.
that's crazy! I average about 240-260 city and 320 highway....NA.Originally Posted by Bassmaster
Hey man, I'm a professional!
as do i, wierd, i NEVER get over 310-320 miles on a tank, a buddy of mines 94 rx7 gets 220 a tank if that guess were not tooo badOriginally Posted by themadhatter
Current: B7 S4, 100" Rigid Chopper Bobber, West Coast Choppers CFL Past: 2000 740i Sport, E60 M sport, 2002 325i Sport, 2000 Audi S4, Dinan S2 E46 M3 on BBS CH, 1995 Jetta GLS Bucket, 2003 Jetta GLI 24v 6 speed, 1999 Jetta GL, 2001 Jetta GL Auto, 2000 Passat 4 motion, 1999 Passat, 1996 Golf, 1993 Dark Burgandy Pearl Corrado SLC VR6 S/C then Turbocharged, 1998 BMW 740i (best car of all), 1999 BMW M3, 1995 Jetta GLX VR6
rotaries were never known for great mileage or efficiency.Originally Posted by jasonknezo
However, getting better mileage with a turbo just means I'm just gonna be a happier bimmerhead.
Are you guys assuming same fuel tank volume? Mine is 13.5 gal.Originally Posted by themadhatter
hmm what is an e36 fuel tank volume?, have to look today after the 33 dollar gas bill
16.5gal
That's pretty good, I get low 20's on the interstate, but the with the car sitting at 4000 for hours on end it doesn't really get good MPG, Mine's N/A.Originally Posted by OZ3M
Also, the most I've ever put in my tank was 16.43 gal
511whp/487ft-lb@17psi -- SC6176, .140MLS, AEM EMS, H2O/Meth inj.
http://www.sunshineacrossamerica.info
Makes sense w/ the turbos though. Your re-using exhaust gas and converting it back into energy for the engine, thus making it more efficient ASSUMING you drive w/ a normal foot.
M3 Sedan Club President #21
perhaps but even 3 gallons shy, that's still over 100 miles less range. still beautiful cars either way you look at it.Originally Posted by OZ3M
About 150 miles per tank.
I think some of the milage could be contributed to the larger gas tank? The other could be the tec III....Im running it a little leaner in the cruising non boosted zones... its around 15:1 TO 15:5 A/F ratio'sOriginally Posted by themadhatter
I've filled up in Atlanta and did not put any gas in the car until the day after I got home...Atlanta to Durham is about 375miles....and I was running pretty hard driving back with the NOPI crowd.
(DIY custom turbo)
I get 19-20 mpg in the city, traffic driving and 25-26 mpg on highway trips. It is not much different than stock. That i moderately boosting. I drove the car hard all week this week as my last hoorah with it and I still got over 18 mpg in the city alone.
Is it finally sold Mike?
i burnt half a tank in 75 miles once.
i am NA and if i drive with out getting on it much i can get 380 a tank.
If i speed and get on it i normally can get 275 a tnak
I get about 25 mpg on the highway.
BBS RC 18X8.5 et13:245/40/18:Koni SA/H&R Sport/M5 3mm Upper Spring Pads/M5T 25mm/20mm Swaybars/Racing King Subframe Inserts/Magnaflow High Flow Cats/Magnaflow Exhaust/3 Inch Tips/Euro Clears/32%Tint/40% on Windshield/6500K HID H1's Headlights and Fogs/Depo Smilies/Factory Shadowline Trim/Shadowline Grill/93 Octane EAT Chip/M5 License Plate Holder/UUC Short Shift Kit/3.15 LSD/ More to Come...
If you aren't breaking 300 miles per tank, you should definitely check something. Fuel filter, air filter, O2 sensor. I saw an increase of about 30-50 miles per tank after changing my air filter and O2 sensor. I can always break 300, I usually hit about 320-340 street and can break 400 on the Freeway. I drive semi-agressive. I'm not WOT every chance I get, but any onramps or bridge underpasses, definitely.Originally Posted by jasonknezo
Steve
My car says im gettin 23mpg which is bullshit I feel like im gettin 14, with AA SC..... on 19" wheels.
Does anyone know if the ~$300 Dinan control module that corrects the OBC will work with higher power/bigger injector setups than an 8psi SC? I'd like to keep the fuel consumption features accurate if possible.
I'd assume thats your problem Excidium - the OBC is no longer calibrated properly.
