I found a recommendation on the Audi Boards actually and found some at Tunerdomes. Cant seem to post the link, but look up the 'shop by part#' and part #6418 replacements. They have a 2 Watt bulb. They get a little warm to the touch but are bright as hell. LED technology has come a long way and unless you see little yellow surface mount LEDs on the bulb you've bought, you probably arent working with a very bright bulb at all in comparison to these. Email me if you have questions on how I installed mine in my car. They ended up looking awesome at night...not sure if they are really DOT approved or not though. LOL
I know this is a pretty old thread but I was wondering if anyone has tried using SMD leds?
I would like to see how they compare to the bulbs with 9 LED's
Try one a let us know. As long as the voltage and amp draw are similar, they should work fine. Probably outlast the 9 Bulb ones. (I've had a couple go bad over the years, but love the light)
John
'95 Hellrot M3 w/Dove
AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
Do those have resistors built in?
I have no idea.
I'm thinking about ordering one of those and one of the 9 led ones to compare. And then order a full set of those that look better.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&Item=170378790794&Category= 42924&_trkparms=algo%3DLVI%26its%3DI%26otn%3D1
6 super bright high power surface mount white LED
Voltage = 12V DC
Light Output = 80 Lumen (65 ma)
Color Temperature = 6000K
Length: 39mm
Width: 16mm
Depth: 9mm
6000K is the same as my headlights, so it should look pretty good
does anybody have a link on where I can get these LEDS for my 318ti I want to replace the lights as well for that updated look. Website and exact part# to buy? ebay or similiar websites are fine with me cheap as possible is key.
I bought the ones off of bav auto and they are expensive, but I picked up a 24-led panel for the front dome and 12-led panels for the back.
I get complimented on them all the time. They are white-ish blue and super bright. Much newer and brighter looking than the stock dull yellow-white bulbs.
I just go to ebay when I need them, 9 LED 39mm Festoon Bulbs......am interested in the SMD's for sure. My kid still needs to do it to his E36.....
John
Hey man, Id like to add LEDs to my interior, if you could help me answer a question I would appreciate it. Ive read this thread a few times, but I dont know how many and exactly which ones I need to do this....sounds like you know how to do it, if you could just tell me the sizes and how many I need i would appreciate it. Checked ebay and there are a ton listed just not sure what to get.
Joey
2003.5 BMW M3 Coupe
Options: SLICKTOP! Sterliing Gray over Black Leather, 6 MT, Manual Seats, Leather & Xenon
1999 BMW M3 Coupe
Options: Dakar Yellow over Black Manual Seats
1988 BMW M3 Coupe
Options: Alpine White over Black M Tech Cloth
Other rides: 2016 Mercedes Benz G63 AMG, Designo Matte Midnight Black (daily driver)
1987 Ford Mustang LX 5.0 Notchback Coupe, Supercharged Sleeper (garage queen)
Previous BMWs: 1995 BMW 325is/1995 BMW M3 Coupe/1998 BMW M3 Dinan Coupe/1998 BMW M3 Sedan/2000 BMW 323CI/2000 BMW 528i Sport Sedan/2003 BMW 540i Sport Sedan/2003 BMW M3 Coupe (SMG)/2009 BMW M3 Coupe (6MT)
I'll add my PM reply here in case anyone else needs help...
Just go to Ebay and search "39mm 9 LED Festoon"....a good 7 come up. I used White bulbs and they look awesome. You need 3, one for each of the the rear side and center front lights. I never found out what goes into the Map lights and almost never use them. But the others come one every time you open a door. Well worth it and they use a lot less power....
John
Just a quick quesiton:
I'm new to the whole interior modding. Is it all light bulbs that dim, or does it depend on the lightbulbs you buy. Like my bulbs dim when I lock the car. Do all bulbs I buy do this or no?
Since this is up again, I replaced mine 2 months ago with the newer SMD versions, old styles just were not lasting long enough, maybe a year or so. I'll give feedback if I run into an issue with the SMD ones....
John
looks good and clean and less heat..i am thinking about doing the same to mine too.
2000 BMW 528i / Manual Tranny / Sport & Premium package / Xenon headlight / Sport seats / Premium sound / DSC /
2011 BMW X3
has anyone done a blue led conversion?
also would color would look good with the stock dash lights?
Hey guys. 1st of all sorry for bumping a semi old thread.
2nd: after I installed the LED's, a couple hours later my comfort relay went bad and the small "reading lights" (?) next to the center dome, as well as the sun visor lights stopped working (along with my power windows). Could the LED's have caused this? Or was it just a huge coincidence?
Also, I noticed that the LED's never fully turned off, they are sort of dimmed when I leave the dome switch in the center, they only turn fully off when I turn the dome switch off.
I may have gotten bulbs a size wrong, but I stretched the metal connectors to make the bulbs fit. They all got the same voltage so there shouldn't be a problem with this, right?
Thanks.
bumping old / dead threads like a boss drunk posting.. Soo What am I suppose to do with the rear lights? I've got a 98 M3 coupe, and I know it splits in the middle so it can work as a reading light, is there anywhere to replace it or put bulbs in that'll work?
