To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
I did this today, It turned out Really nice!
I just ended up putting it on-top and useing some adhesive sparay. I used this nice suede & velvet black material and it blends in nicely to the interior and with a clean look from tucking in the courners to get it on smooth.
First post here... really do appreciate the work that has gone into this forum, you guys are awesome.
So I have everything out of the car. Question is about re-covering the pillars. Factory material is proving to be extremely difficult to remove. Would I be an idiot if I simply glued & covered (new material to match the headliner) over the factory covering? Or should I do whatever needs to be done to get the factory stuff off? Anybody got any tips there?
US
Read this write-up a couple times before the attempt, everything went almost perfect. I did have fun removing it with the drivers seat recline gear broken, but it worked and the rear decklid rivets came off very easy for me. I would add a couple of pointers:
-Don't push any of the loose wires through the holes, some back right to the metal frame and can get lodged. I "lost" two for a few minutes, finger fishing retrieved the wires.
-Double check other wires while your at it, found one of my antenna wires had disconnected explaining my poor reception.
Now I wait for my material and prep the parts.
Thanks again,
Brent
How do you get the sunroof switch off?
I've tried to pull and pry everything I can think of, but I'm afraid I'm going to break something.
Sunroof switch just pops out. It snaps into the plastic ring and that ring slides into the fabric insert. On the back there is a plug that just pulls out.
Just put your fingernail under the edge of the plastic trim and pull down...or you can remove the entire fabric insert that is the motor access and simply disconnect the switch then.
Thanks, worked perfectly, I was just scared about breaking the switch...
I've taken all of the interior out except the rug and the dash, and I've broken so many old plastic tabs.
My car is a '92, but the plastic seems to have deteriorated badly.
Can you tell me how to remove the fabric shuttle from the sunroof.
Hello,
Thank you for this: very good. I am trying to install the two rear screen hooks and am having to do a bodge job cos the screen is too big. Am I right in saying that even to pull down the rear of the headliner I have to pull the headliner forward: so have to free it all points just to get at the back? ? Do you see what I mean?
Thanks.
Can you post a picture of what you are talking about?
dude you're awesome. My saggy headliner is off. Thank you.
Old Skool, this is the best DIY write up I have followed from this site. Very detailed, good pictures. Thank you for taking the time to write this. It's appreciated.
I put up some Alcantara (micro suede) I bought on eBay. Looks very good. I guess I need to do the sunroof next. The old fabric stands out. Will be looking for your DIY for that too.
One comment regarding the rubber seal along the windows and doors. I took down some of the rubber seal on one side of the car. On the other side I just pulled ithe headliner out from under it and pushed it back in when I was done.
just completed it now, getting too dark, so im gonna roll around tonight with a bare ceiling, and remove the foam from the liner and spray it in the morning
THANKS A BUNCH your write-up rocks!
Great write up. It helped me a ton when I replaced the headliner in my car
1997 BMW 318i
New Sig in works
Seems like a complicated process. this is my first DIY car, and everytime I read instructions like this, it puts me off, but I guess, one has to start somewhere.
Actually, the headliner,rear parcel shelf will be tasks for next Spring, but this is a create write up for sure...
Paul
Current Cars:
1995 BMW 325i
2013 BMW X3
2017 Infiniti QX30
Past Cars:
1997 BMW M3
2011 Chevrolet Avalanche LTZ
2010 GMC Terrain
1998 BMW 328is
2006 BMW 325i
2007 Saab 9-3ss AERO
2004 Saab 9-3ss Linear
2003 PT Cruiser
2001 Volvo S40
1990 Honda Accord EX-R
It's not hard to get the headline out, I did it in less than 5 minutes. However, I am about the sell the car over the fact that by the time I started to reuse the material it shrunk and wont glue back worth a damn. The stuff that they sell at Pelican Parts comes in running yards? lengths of 3' wide? WTF...the width of the headliner is more than 3 feet so does that mean I will have a seam?
If so, screw it, I will use black spray paint on the fiberboard and put it back in.
actually, the pieces I ahve are complete w/ the fibreboard. So the process of re-installation should not be difficult. I just need to snap the fibre-board into place again.
Paul
Current Cars:
1995 BMW 325i
2013 BMW X3
2017 Infiniti QX30
Past Cars:
1997 BMW M3
2010 GMC Terrain
1998 BMW 328is
2006 BMW 325i
2003 PT Cruiser
2001 Volvo S40
After completing the 18-button OBC DIY and installing the Microfilter (PITA), I am right now about to embark on the interior swap.
The only suggestion I was given was to remove the seats for the headliner swap as I was told it makes it easier to move about in the car and also remove the old headliner....
So....I will probably tackle this "next" Saturday and let you all know how it goes.
Paul
Current Cars:
1995 BMW 325i
2013 BMW X3
2017 Infiniti QX30
Past Cars:
1997 BMW M3
2010 GMC Terrain
1998 BMW 328is
2006 BMW 325i
2003 PT Cruiser
2001 Volvo S40
i removed mine yesterday and am planning on doing black suede on the headliner, sunroof, and the pillars...how many yards should i get?
Just used this thread over the last two weeks to redo my headliner and pillars. I went with fabric and a shade darker than Dove Grey. I really like how it turned our, except a few spots that look darker because the damn adhesive was a PITA to spray evenly. One question for you guys, how do I get the freakin' C pillars back in? I have tried for over an hour to put them in.
~Phil
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557
Very carefully or you will break the tabs and be buying new ones
Rob
Prior projects:
1998 540i with 6.6 LS2/T56 Chevy Power
- pictures and details
1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
Hey guys, new to the forum! Thanks for the great info. I just bought my first BMW, a 318is for only $1000. The guy before me got sick of the saggy headliner hitting him in the head, so he tore it all off. That ended up leaving a nice sticky orange foam mess all over the car! Anyways...I followed your post and in about 30 minutes I had mine out and ready for recover. I went to Walmart and bought about 4 yards of material that was a REALLY close match to the factory color. I recovered the headliner, all pillars, sunroof switch panel and repainted the deck lid with duplicolor fabric/vinyl paint while I was in there. The project came out GREAT, I was so happy with it! Anyways...thanks for a great post, and to everyone else....this really isnt as big of a project as you think. Just be patient and go slow to not mess anything up!
