Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 113
Thread: DIY:Removing fabric shuttle from sunroof
  1. #26
    May 2003
    oh-hi-oh
    Jetta
    I don't have any other pictures...
    Did you look at how the old ones were attached?
    Do you have any pictures you can post so that we can try to help?
    To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
    You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
    Custom watch straps for sale
    FOR SALE: watch straps!!
    E36 DIY: My articles are now located in the E36 DIY page
  2. #27
    belgium
    E36
    If you want to lift open the sunroof itself, then I recommend tilting it and then removing the two T25 torx screws on either side at the front of the sunroof. These torx screws hold the front of the sunroof in place and the slotted arms they fit into allow you to adjust the sunroof to get it flat and with the proper seal.
    Here is a picture of where they are located: (the right is the front of the car and the left is the rear)[/quote] My sunroof sits a bit too low. On this pic are the screws to raise the front, right? How do I get to the rear ones? I tried pushing back the liner but it won't budge. Other than that the roof works just fine
  3. #28
    May 2003
    oh-hi-oh
    Jetta
    Quote Originally Posted by baghram View Post
    too low in the front or the back?
    Those screws control the front height.
    The rest of the height is controlled by tightening all the bolts that hold it to the roof of the car.
  4. #29
    Jul 2005
    NH, USA
    1993 325i
    Just wanted to say thanks for this thread while it's bumped, to old skool and autocross97 both. The headliner on my shuttle has come apart and I need to re-glue it. I was hoping to be able to do this without tearing out the whole car headliner and it looks like it can be done; a project for me to tackle once the rain goes away since I don't have a garage.
    -- now allen603, with more NH goodness.
    Just piss on it. I got stung on my arm this summer so i "self medicated" it, and my mouth -- 3.2Powerslut
  5. #30
    belgium
    E36
    Quote Originally Posted by old skool View Post
    It's too low both at the front "and" at the back. It's depressed. The whole sunroof should come up about 3mm. Right now when it rains, it doesn't run off, but it rather puddles up in one of the corners.
  6. #31
    May 2003
    oh-hi-oh
    Jetta
    interesting. I would pull the headliner and take a look at the sunroof assembly. If the bolts are tight, it should sit flush with the roof.
    I get a lot of PMs about this sort of stuff. I do my best to recall how these things work. It wasabout 2 years ago that I did all these DIY articles. I think I responded to everyone. If I haven't addressed your concerns, feel free to post them up.
  7. #32
    belgium
    E36
    I'm kinda hesitant to pull the headliner as I read numerous threads about sagging headliners and I don't want mine to start doing that too. The sunroof doesn't rattle or anything and it works just fine, is there no way to adjust the height at the back? I remember seeing something about it in a bentley's manual, but the pics were too dark to make out what was being done.
  8. #33
    Florida
    06 Speed 6 // 93 330is
    when my sunroof is "closed" and supposed to be flat, it sits about 3/4" lower than the rest. Would getting into it this way let me re-position it so it sits flat and level with the roof of the car?
    my "shuttle" slides freely when sunroof is closed or tilted up.. is that bad?
    All men's souls are immortal but the souls of the righteous are immortal and divine. -Socrates
    Wake up determined, sleep satisfied. -George Lorimer
  9. #34
    belgium
    E36
    From what I understood, you should be able to slide the inner part backwards by hand when you drop the sunroof a lil.
  10. #35
    PANAMA
    530i 11/00
    i just did this now my sunroof wont open it just tilt is like is stuck with the shuttle becuase if i take out the shuttle it will close open and tilt perfect how can i fix this!!!!!!!!
  11. #36
    Mar 2004
    FL
    97 M3
    We need a sunroof specialist. I'll pay $75 to whoever can come to my crib and take care of this.
  12. #37
    Jun 2006
    Vancouver, WA
    Dakar M3, Silver 328
    I cant tell if you covered what I amasking, I wish to remove item number 5 from my sunroof, would I need to take out the whole sunroof to get too it?
    http://www.realoem.com/bmw/showparts...87&hg=54&fg=05
  13. #38
    May 2003
    oh-hi-oh
    Jetta
    #5 is what this is all about. You don't techinically need to remove the entire sunroof. It is difficult to get to everything with the sunroof installed but it is possible. You can remove the entire sunroof if it makes it easier for you. That is your choice.
  14. #39
    Mar 2004
    Toronto, ON
    M3/28is
    I have the whole sunroof assembly out of the car. Can I still remove the shuttle this way? (I believe the motor is still inside the car, so the first couple steps of this DIY are invalidated)
  15. #40
    May 2003
    oh-hi-oh
    Jetta
    If the lid of the sunroof is closed, I am not sure you will be able to open it to access the hardware you need. You may need to remove the sunroof motor (just a screw or two) and attach it to the sunroof. You can use an allen wrench to manually move the sunroof this way.
  16. #41
    Dec 2004
    Annapolis
    1990 325is
    This is really chaffing my ass. So far I have the sunroof completely removed from the car, so I have to use the hex wrench to turn the motor (pain). The two front screws are removed. From this point I'm stuck. I can't get the shuttle free to slide back, even when the "key" is out of it's notch. I also can't figure out how to remove the top metal/painted section of the sunroof. I can't see any screws/bolts that seem to be involved with it. Anyone help me out?
  17. #42
    Mar 2004
    FL
    97 M3
    The metal top is removed by removing the 2 screws on the front sides of the sunroof (first thing covered in the DIY). Then the front can be lifted and then theres 2 more screws at the back (dont know how to remove those exactly, I just yanked it out (not recommended))
  18. #43
    raleigh, nc, usa
    1992 325is
    The 4 tubes attached on the corners?
  19. #44
    Dec 2004
    Annapolis
    1990 325is
    Quote Originally Posted by MJFX328 View Post
    You don't by any chance have a picture for this do you? And when you say the front can be lifted, is this still while in the tilt position?
  20. #45
    May 2003
    oh-hi-oh
    Jetta
    The front can be lifted after you remove those two front screws. Swing it back and you should see the screws for the back.
  21. #46
    Dec 2004
    Annapolis
    1990 325is
    When you say the front can be lifted, should I have to use force? It definitely doesn't just swing back freely. And I assume when you say swing, it should open as if it were hinged in the back?
  22. #47
    May 2003
    oh-hi-oh
    Jetta
    yeah. Once you disconnect those two front bolts, the sunroof should be free to gain access to the back bolts. The front should flop around a bit if it is disconnected because those front bolts hold it in place and control the tilting.
  23. #48
    Mar 2004
    FL
    97 M3
    Quote Originally Posted by btl1990 View Post
    Your somewhere else. Were talking jsut about the sunroof lid part. The tubes attach to the entire cassete, and should be removed before unscrewing.
  24. #49
    Dec 2004
    Annapolis
    1990 325is
    Are the two screws in the 'back" really small philips head screws? Those are the only ones I can find but I'm having trouble accessing them as they're very small and in a tight area.
  25. #50
    Mar 2004
    FL
    97 M3
    The screws that hold the lid on are on the sides and are hinges. Actually theyre more like pins not screws - those are the ones i forced off.
    The phillips screws at the back are what hold the fabric shuttle piece
