Page 6 of 6 FirstFirst 123456
Results 126 to 147 of 147
Thread: DIY: Alarm install
  1. #126
    Dec 2008
    Indiana
    97 318is 5spd
    it doesn't connect to anything. put your glovebox back in and call it a day.
    Driving is a spectacular form of amnesia. Everything is to be discovered, everything to be obliterated.
  2. #127
    Sep 2010
    Brazil
    1993 BMW M3 Coupe
    Remote Control Security System
    Is anybody familiar with this Keyless Entry system?
    Uploaded with ImageShack.us
    I got it from a friend but it didn't come with the manual or instructions. I'm almost giving up on it. I can't find anything even close to this on the web.
    The plugs are all different from the ones I've seen on DIYs and I can't find any information on it's part number: 88 88 1 600 204
    Is there a website where I can find info about old parts that have been discontinued?
    Thanks,
    Diogo
  3. #128
    Menlo Park, CA
    99 estoril m3 vert
    It's an E30 alarm
    Brian - DEPOs + 6x HIDs (straight cutoff), MM Underpanel, RE RSMs + reinforcement, AKG 80A RTABs, OEM FCABs + motor mounts + sway bushings, OEM shocks + struts, ASC delete, Pioneer DEH-80PRS, BSW Stage 1 + Sub
  4. #129
    Sep 2010
    Brazil
    1993 BMW M3 Coupe
    Quote Originally Posted by firedancer414 View Post
    It's an E30 alarm
    Thanks,
    Is there any use for it in an E36?
  5. #130
    Dec 2003
    Oakland, CA
    92 325is, 01 Yamaha R1, 01 Audi A4 (wife's)
    Can anyone take a pic of where they found the horn/siren plug that is under the hood. It's suppose to be tucked somewhere near the right headlight but I haven't been able to find it. Thanks in advance
  6. #131
    Menlo Park, CA
    99 estoril m3 vert
    bump, I have everything wired up except I can't seem to find where the white molex connector is supposed to connect (I have the >96 OBDII alarm system). Is it somewhere in there, any hints / pictures of where to look? Thanks! Brian
    I FINALLY got this working today. It was the hood microswitch, of course. I ended up having to order one from Tischer (getbmwparts) for like $40. It totally works and has that badass oldschool alarm chirp.
    A few other notes to those who were struggling like me:
    - The tempo of how fast you turn the car on and off DOES matter. Ultimately, about 1 on/off a second worked for me. I was doing it too slow, thinking that the car needed a second to recognize that it was on.
    - The LED and alarm did illuminate and chirp for me when it worked (in the middle of programming it), exactly when the alarm programming guide says it should
    - The new microswitch I received from Tischer did NOT look the same as the old one already in there. I ordered part number 65-75-1-391-850.
  7. #132
    Mar 2010
    Ventura CA
    e23's, e24, e28's & e36
    Quote Originally Posted by Lawrence1 View Post
    fredo328 ... here's a diagram with the adjustment settings
    http://www.circlebmw.com/service/access/82111469444.htm
    scroll down at that link and look at the diagram ... don't mind that its for a Z3 as the alrm control units are all the same.
    Mr.M seeing how you have a 95 ... you program your remotes by insterting the remote chip into the alarm brain.
    the remote programming procedure is different on OBD I cars because they use a different alarm system. if you open up your remote you will see what im talking about(a small chip that you need to insert into the alarm brain. )
    your alarm should also use a 3 button remote instead of the 2 button ones used by the OBD II systems shown here.
    Is there is anymore info on this? The link is dead. I have this alarm and would like to program a new remote. Do I follow the trunk open/door close/key turn procedure while the remote chip is inserted into the alarm brain or is there something different? Or do I just plug it in and it does it on its own?
    Great write up old skool! Thanks
  8. #133
    Dec 2010
    Russia
    BMW 325i Coupe 1993 e36
    Could you help me, please. Does anybody know how to program for my BMW key? I have old style 2 button IR key. 325i coupe, 1993, e36
    I've tried many methods, but couldn't find the correct for my car.
    Sorry my English!
  9. #134
    Menlo Park, CA
    99 estoril m3 vert
    Quote Originally Posted by muzzle View Post
    Sorry my English!
    You need a 3 button fob.
  10. #135
    Dec 2010
    Russia
    I don't understand. What does it mean? I have 2 button key, but now I need 3 button?
  11. #136
    Guate
    M3 2005, 328i 2000, X5 2006
    perfect diy! tnks!
  12. #137
    Aug 2011
    Atlanta, GA
    1994 BMW 325i ...Black..
    Thank you so much! This looks great. I will let you know how it goes! :-)
  13. #138
    Sep 2012
    San Antonio,Tx
    2001 3.0 turbo
    2000 3.0i
    I got a unit out of a 2000 M and installed it in my car but no luck on getting it to work.. any help?????
  14. #139
    South Carolina
    2004 330 vert 2004 X5
    Quote Originally Posted by The Possum View Post
    What car did you install it in? As far as I know the only OEM or Genuine BMW units that work in an e36 are the ones originally supplied for the e36. The wiring in a e46 is very different.
    These work in an e36
    http://forums.bimmerforums.com/forum....php?t=1792200
  15. #140
    Pa
    BMW
    Subbed. Going to work this out tonight.
  16. #141
    Jun 2012
    New Jersey
    E36 328i sedan
    I cant find the black power wire in my glove box i got the 12 prong but i just cant find the single black one can someone help me out
    Found it
  17. #142
    Mar 2011
    Illinois
    99 E36 Vert
    I have a 99 E36' made in 9/98. It has the factory alarm installed, I have no fob for it. Which fob should I be looking for? My key won't work will it? Maybe it needs programmed.
    BMW...
  18. #143
    Nov 2012
    Pacific Northwest
    1997 BMW M3
    Quote Originally Posted by LoE36 View Post
    That is your factory key, that's programed with the EWS system for security. that will not control any functions of the alarm. You need the 2 button Alpine FOB. Hard to find
    ///M
  19. #144
    Mar 2011
    Illinois
    99 E36 Vert
    Quote Originally Posted by Rhino7200 View Post
    thanks mate, I'll start searching
    BMW...
  20. #145
    Nov 2012
    Pacific Northwest
    1997 BMW M3
    Yep, EWS is the anti theft system that has the ECU programed to it so unless you have the key with the programmed chip, the car will not start. The alarm just makes noise and can lock /unlock remotely, which needs to me programmed separately
    ///M
  21. #146
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Pinout of the 12 pin plug, part number for the plug and the pins is here from a Z3: Pic-request-OEM-Alarm-harness-car-side-plug-pins-and-wire-colors http://www.bimmerforums.com/forum/sh...nd-wire-colors
  22. #147
    Stamford, CT
    2 e30s, e34, e36, e39,
    So I installed the factory alarm brain and single power wire successfully, but can't find the glass break sensor connector. Any hints? The alarm won't program without the glass break sensor being attached, apparently.
