Ok Guru's - (or someone with a wiring diagram)
I have an odd problem with my 98 M Roadster. My interior light(s?) as well as my drivers side parking and tail lights all stopped working at the same time.
Anyone have an idea if these three items are on a common wiring circuit?
I am due some good karma today, as I just met a fellow to use my SRS tool to pull his airbag code and reset his SRS light.
Tal
go through and check every one of your fuses
same thing happened to me...it was the fuse
Could be this?Originally Posted by talisbell
'00S52 RETIRED
'07 Silver Gray E86 MCoupe
No, when the rheostat fries, you only lose instrument and center console lighting (everything dimmable).Originally Posted by tripleM
Check fuse 33. As to why it tripped, I'm gonna take a wild guess and say water in the taillight?
I don't know about the original complaint, but the linked problem is true. When I purchased my car the first night I had it I realized I had no illumination on my instrument cluster. The shop replaced the headlight switch. Super! For a short time. It shorted and died again. Turns out it was the wiring for the shifter, it isn't stock and the wiring for the illuminated knob was shorting out.Originally Posted by dwm
98 ///M Roadster - Sharked, FDK, twin Magnaflows, UUC Stage II Flywheel, OEM M5 Clutch, UUC TME Red & Enforcers, Zimmerman rotors, Cosmos CAI, ProjectorZs w DDE, 6K HIDs, fatter rubber on the corners, UUC Underdrive Pulleys, and Stewart High Performance water pump
Thanks for the leads. I will check the fuses this evening.
The odd combination of inoperable lights led me, apparently erroneously, to think that the problem was downstream of the fuse box. I would have expected all tail and parking lights to be on the same circuit.
It appears that the only lights I have currently lost are: Interior light, driver’s tail and parking light, under hood and in trunk illumination. The dash, shift knob and switch lights are all illuminated.
Tal
We have a winner. Seriously, thanks for pointing me in that direction. I would have probably eventually figured it out, but the odd combination of outages did not lead my mind towards the simple solution - the fuse box.Originally Posted by dwm
There was a little bit of gunk and moisture on the tail light bulb housing when I removed it but not an extraordinary amount. I am hopeful that is the extent of my problems.
Again, thanks.
Tal
