Results 1 to 7 of 7
Thread: Would 235-45/17 be good plus 2 upgrade....more
    bmwmsport Guest
    Question
    on a 94 325is? 235-40-17 is smaller in overall diameter than the stock 205-60/15, that is why I was considering the 45 series tire.
    Which is a better sized tire for the plus 2 upgrade?
    The car will not be lowered.
    Chris K.
    Feb 2001
    Orange County, Southern California.
    BMW 530i
    i believe u're suppose to run 235/40/17 tires....
    someone correct me... cuz on 18s, when you run 235s, it should be 235/35/18s...
    so i believe you should run 235/40/17
    good luck.
    Richard
    Feb 2001
    Bergen Co. Morris Co.
    e36 328is,T4R, is250AWD
    45 series tires with my 17's gave me same diameter as stock 15's.
    Feb 2001
    BMW 530i
    with what width tire?
    225 tires should run 45 profile...
    235 tires should run 40 profile
    Richard
    Feb 2001
    Chatsworth, CA
    I have 225/40/18's and they are the same diameter as the stock wheels.
    Feb 2001
    BMW 530i
    yup that's what im running also... 225/40/18s...
    Richard
    Feb 2001
    Home: Bay Area, California |||| College: UCSB
    On 17x8 (Im assuming the width :p ), 235/40 tires are common, however, Ive also seen them with 235/45 tires. Though a tire may state a certain size it is often plus or minus some mm. 235/40 tires are an itsy bitsy bit smaller than overall stock wheel diameter, and 235/45 are a bit bigger than overall stock wheel diameter. Personally, Id go with the 235/40s... but whatever floats your boat will do .
    - Jon, '93 325is
