CAR WON'T START:
http://www.bavauto.com/newsletter/2007_n407_newsletter.pdf
Starts on page 4
OR MAYBE THEJLEVIE CAN HELP YOU!!:
The DME, engine harness, coil, and CPS are all that is required to run the engine. The car provides power to the coil and the START input of the DME via C101 and the fuel pump relay output is routed via C101. Since the ICV doesn't buzz with the key in RUN, my first suspicion would be that the DME has no power or isn't getting a START signal. A trouble shooting guide is:
For the engine to run the following conditions must be met:
Power on DME pins:
27 Start Input
18 Un-switched Power input
37 Power Input from Main Relay
Ground on DME pins 2, 14, 19, 24
Timing data from the CPS on DME pins 47 & 48 from a rotating engine
To have spark power must be present at the coil positive and ground pulses
from the DME's pin 1 must reach the coil negative. Power to the coil is
controlled by the ignition switch via C101.
When checking for spark, use the output lead from the coil to eliminate the distributor, rotor and plug wires.
To have injector firing power must be present at each injector and ground
pulses from the DME's pin 16 (Bank1) and pin 17 (Bank2) must reach the
respective injector bank. Note that the injectors are wired as two banks of
three. With cylinder 1,3,5 being bank 1 and 2,4,6 being bank 2. Power to the
injectors is controlled by the main relay.
The fuel pump relay must have power on pin 86 (relay coil) from the main relay
output (pin 87) and power on pin 30. The DME will ground pin 85 to turn on the
relay and power the pump(s) via pin 87. Of the above, only the fuel pump power
is fused. So if the there's power at pin 87, but not at the pump, check fuse
11.
The main relay and DME pin 18 receive power from the smaller of the to wires
that connect to the battery's positive terminal. That wire incorporates an
in-line fuse. When the DME is presented with a start signal, it grounds the
main relay pin 85 and furnishes power to the fuel pump relay, injectors, and
DME.
Troubleshooting:
Disconnect the battery and the DME.
Then:
1) Disconnect the coil negative and check continuity from that connector to
DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
2) Check the resistance across DME 47 & 48, which should be 500-560
ohms. If the CPS is dismounted, the resistance can be seen to change
from about 500 to 540-540 when a ferrous object is brought to the face of the
sensor. Neither pin should be grounded.
3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
pump relay 85.
Reconnect the coil, remount the CPS (air gap should be 0.040"), plug the
relays back in, reconnect the DME, and connect the battery. Then do the
following checks:
1) With the key off, verify that power is present at DME pin 18 and main relay
86 & 30.
2) With the key on, verify that power is present at DME pin 27 and pin
18. Power to pin 18 is from the main relay and there should be power to the
injectors and fuel pump relay.
3) With the key on, verify that no voltage is present at the DME grounds (2,
14, 19, 24).
4) Verify that power is present at the coil positive and at fuel pump relay
pin 30. Those get switched power from the ignition switch via C101.
The engine will start and run (if poorly) with only those connections to the
DME in place. The other signals from Cylinder ID, AFM, temp sensor, etc., are
necessary for proper operation. But they won't prevent the engine from firing.
IMPORTANT:
A power check means seeing a voltage within about a tenth of a volt of what
you measure across the batter terminals, which should be at least 12.6v on a
charged battery.
A continuity check means seeing less that 1 ohm of resistance.
An open circuit means seeing a resistance of at least 100k ohms.
A good quality auto-ranging Digital Multimeter will make these tests much
easier.
After so many times people asking what bulb goes where, I decided to create a comprehensive list of lamps and where they are used in the car. This should be fairly accurate. Please post any corrections in this thread and I'll update the chart.
In a number of places, the 2721 lamp is fitted into a socket with wire leads. For example the rear ashtray and the auto shifter. If yours breaks, the repair part is PN 64111366170. (Thanks H.J. 1981)Code:Osram/ Location Qty Specs Generic Sylvania BMW Comments ========================================================================================= Headlights - Sealed Beam, Low 2 35/35W H5006 H5006 63121468226 Headlights - Sealed Beam, High 2 50W H5001 H5001 63121468272 Headlights - US Ellipsoids, Lo 2 51W HB4 9006 63217160786 Headlights - US Ellipsoids, High 2 60W HB3 9005 63217160785 Headlights - Euro Ellipsoids, Low 2 55W H1 64150 63217160777 Headlights - Euro Ellipsoids, High 2 55W H1 64150 63217160777 Headlights - Euro Ellipsoids, City 2 5W W5W 2825 63217160797 Fog 2 55W H3 64151 63217160779 Front Marker/Turn (US) 2 21/5W P21-5W 7528 63217160793 Front Turn (Euro) 2 21W P21W 7506 63217160789 Lateral Turn (Euro) 2 5W W5W 2825 63217160797 Side Markers (Early) 4 4W T4W 3893 07509063576 Side Markers (Late) 4 5W W5W 2825 63217160797 Tail (Early) 2 10W R10W 5008 07119905337 Tail (Late) 2 5W R5W 5007 07119905336 Rear Turn 2 21W P21W 7506 63217160789 Stop 2 21W P21W 7506 63217160789 Back-up 2 21W P21W 7506 63217160789 High Stop 1 21W P21W 7506 63217160789 High Stop - Cabrio 1 18W 921 63251372632 Euro Rear Fog 2 21W P21W 7506 63217160789 License Plate 2 5W C5W 6418 63217160805 Festoon 37x11 Glove Box 1 5W C5W 6418 63217160805 Festoon 37x11 Dome 2 10W C10W 6411 63217160912 Festoon 41x11 Dome - Convertible 1 5W H5W 64111 63311374798 Light next to check panel Trunk 1 5W C5W 6418 63217160805 Festoon 37x11 Ashtrays - Front and Rear 2 1.2W W1.2W 2721 63217167000 Analog clock back light 3 1.2W 2721MF 62111368299 Mirror Map Light 2 10W H10W 64113 63311375003 Mirror Map Light (Alternate) 2 5W H5W 64111 63311374798 I've seen recommendations to reduce wattage to 5W Instrument - Wedge Base ?3 1.2W W1.2W 2721 63217167000 Instrument - Plastic Base ?13 1.2W 2721MF 62111368299 Instrument - Illumination 2 3W W3W 2821 07119905358 Light Switch 1 1.2W W1.2W 2721 63217167000 Shifter - Automatic 1 1.2W W1.2W 2721 63217167000 Check Panel 1+ 1.2W 2721MF 62111368299 1 + 1 for each large indicator (e.g. seatbelt) Digital Clock 1 1.2W 2721MF 62111368299 Digital Clock/Temp 1 1.2W 2721MF 62111368299 OBC - Buttons 1 1.2W 2721MF 62111368299 OBC - Backlight 1 65811375461 Light bar HVAC Panel 2 1.2W W1.2W 2721 63217167000 If a bulb is not listed here and it's one of the tiny lamps, it's most likely a 2721 or 2721MF. Some switches have replaceable bulbs that are not listed.
The OBC panel backlight light bar is expensive. If you're handy with a soldering iron, you can try replacing the lamps yourself. From what I have been able to gather, the lamp specs are bi-pin mount, T-1 3/4 base size, 6.0V/.02A. The catalog number I see associated with those specs is 7328.
Last edited by richardodn; 10-28-2020 at 09:41 AM. Reason: Added analog clock ligh
"Howdy, Folks!"
Link to rebuild of antenna mast.
http://forums.bimmerforums.com/forum...schmann-6000EL
"Howdy, Folks!"
BMW EBA document (9750880) for an is style spoiler. I don't know for sure if the same drill pattern is used for the M-tech spoiler, but it's likely it is. Sorry, but it is slightly over the size limit to upload directly here.
https://drive.google.com/file/d/0B_y...ew?usp=sharing
"Howdy, Folks!"
Getrag 260 overhaul and installation
http://www.bimmerforums.com/forum/sh...d-installation
"Howdy, Folks!"
E30 youtube DIY
playlist thanks to rbelton!
https://www.youtube.com/playlist?lis...j_RiNL9aEPy8w6
"Howdy, Folks!"
