I am going to be doing the fan delete/water pump/tstat install tomorrow and I was wondering if anybody had any useful tips they could give me. From what I hear it's pretty straight forward and easy to do. I was just wondering if the Fan Clutch tool is needed or will a large screwdriver work? Thanks for the help
for the fan clutch, all is needed is a big ole' flathead screwdriver and 32mm wrench.
heres a link for water pump install: http://www.logun.org/waterpmp.htm
and thermostat housing: http://www.logun.org/therm.htm
Element Tuning - 2008/2009 NJMP Redline Time Attack/Formula X Champions [Street & Modified]
RightFootDown
FS: E36 OEM fogs | UUC Chromoly RLCA's
Make sure you put the thermo in with the arrow up and the o-ring after the thermo or you'll leak and have to do it again like me.
Cheers.
Man I love those RX's. You can also use a large hex key instead of the screwdriver...and remember the bolt on the fan clutch is reverse thread...to loosen it just give that wrench a hard tap with a hammer.
Turner Perf Chip/Fan Delete/Sparco Strut Tower Brace/X-Brace/JTD Underpanel
Zimmerman X-D Rotors/Axxis Ultimate Pads/Solid Caliper Guide Bolt Bushings
UUC EVO3/DSSR SSK/3.15 LSD/Cosmos Racing CAI V2/ASC Delete
96+ M3 LCA/LCAB M3 RTAB and GC Shims
BMW OEM Alarm/Woodgrain Delete/Blizzaks baby!/16x7 BMW Style 30 Sport wheels
When you get fed up with the screwdriver/wrench trying to break the fan clutch nut loose, just put your big 32mm wrench on it, tipped towards the passenger side, and smack it firmly and quickly with a hammer towards the driver's side. It will come loose.
-Brian
Prepare to totally ruin a screwdriver...
1988 E30 M3-Garage Queen
1995 E36 M3-Track Car
2004 330i ZHP- Daily Driver
///M3 Cc #1
"Gotta Pay to Play"
$In Debt Racing$
Ditto....forget using the screwdriver, just hit a 1.25 in or 32mm wrench with a rubber mallet and it will come right off.Originally Posted by M3_boogie
yeah i started trying to do it this morning and realized i didnt have a 32mm wrench i could have sworn I had one. So i just used an adjustable wrench but it was a PITA to fit on the Fan Clutch bolt. I then got fed up with the screwdriver thing and I have to go to work now anyway so i will try that hitting the wrench with a hammer tomorrow. Thanks for the help
no fan can resist my homemade fan tool...
i ended up making this after trying all other methods in the book with no results on a very tight fan. fan was off in under a minute with my new tool.
Why don't you make a few of them and sell them to people on here?Originally Posted by beatniks325
Use a 1 1/4 inch wrench, they are much easier to find. This will fit on the fan clutch and then just give it a good hit with a mallet and it should come right off after that. I used this method and on the first hit, not swinging very hard it broke loose.Originally Posted by Luke
when i did mine, didn't screw up the screwdriver at all. i guess its all in how you do itOriginally Posted by NakNak
RightFootDown
do you have the dimensional specs on the hole pattern? If so, I could get 10-15 made at work very easily.
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
You can buy one here http://www.zdmak.com/wbstore/main.as...MW-1703&CTMP=1Originally Posted by clumpymold
I just want the specs on it so I can fab my own. Anyone?
Just measured it...here. I haven't made one but this should work.Originally Posted by old skool
Sweet. Looks like I will be sporting my own custom fan tool for this next coolant job.
Maybe I will chrome it.
Or I could have ///M laser cut or etched into the handle. This is what I get for being bored at work.
Wait how wide is it and what is the edge distance on the 1/2 holes?
Make it whatever width you want, although I would think a 1"x12" piece of stock can be readily had...I would think 1/8" aluminum would be sufficient as you really are just holding two bolts in place to loosen the 32mm nut. Center the 1/2" holes that hold the bolts, just make the 3/4" radius "cut in" centered on the 1/2 holes and 1/2" in. BTW, I edited that drawing.
The bolts are 1-3/4 inches apart on center. The custout for the 32mm nut needs to be at the center of the 1/2'' hole. That help...keep in mind that my drawing is not to scale...I did it in MS Paint
Looks like I should add a slot and this seems longer than 12"
Looks to be 1/4"
I don't think the 10mm nuts are evenly spaced
This is for my 95, I don't know if there is diff in pulley configs. But I just made a mock-up out of cardboard and it fits perfectly Make sure the 1-1/2" R cutout for the fan nut is centered and extends to the midpoint of the 1/2" holes
Doesn't have to be, but could be.Originally Posted by old skool
They aren't...I used the bigger spreadOriginally Posted by old skool
As I said, I made a mock-up, fits perfectly.
