Results 1 to 4 of 4
Thread: Question on Windshield Washer Motor?
    Apr 2002
    The Woodlands, Texas
    1986 BMW 325es
    Question Question on Windshield Washer Motor?
    Does anyone know if the Windshield Washer Motor has a fuse? If so what size is it? My washer motor stopped working today and I hate to pay the dealer a $50 deductable on my CPO if all I need to do is change a fuse. My Check Status Light reads everything is OK.
    Thanks in advance.
    <i><b>
    Mike Chapman
    <img src="http://members.roadfly.com/mike_chapman/3dflagsdotcom_us_tx_2fawl.gif">
    Feb 2001
    East Bay, CA
    M5, E61
    Someone with an ETK should be able to look up the parts for this!
    Apr 2001
    In Bentley, it looks like the washer pump is hooked up through fuse 44, so you might check that. Otherwise, I'd get out a meter and check the connector to see if you have power, and to see if the other terminal goes to ground when you pull the stalk. If you have power, and the other terminal goes to ground, then my guess is that you need to replace the pump motor - should be a fairly simple fix to do yourself.
    One thing that you might want to check before going too much further - on my car, the washers stopped working because one of the hoses popped off the nozzle under the hood. The pump still worked fine - it just pumped fluid between the hood and the liner instead of out the nozzle. Couldn't see anything, so it looked like the pump wasn't working, until I opened the hood and all the fluid came pouring out...
    Jim
    Apr 2002
    1986 BMW 325es
    Thumbs up Thanks for the Help
    Thanks for the help.
    So far I have check the hoses leading to the nozzles. They seem to be connected and intact. The fuse on #44 looks to be ok. I will next eliminate any chance of electrical failure going to the pump motor. The last step if this is not the case will be replacing the motor itself. I looked up one on Bavarian Auto last night and it was ~$38.00. Looks like an easy repair if that is the case.
    <i><b>
    Mike Chapman
